Mustang PBR Calipers to Thunderbird Conversion and problems - Page 5 - TCCoA Forums
post #121 of 130 (permalink) Old 04-08-2014, 12:34 PM
Dave,
I'm not sure about the Cobra caliper, but the grinding needs to be done if you're using the PBR Mustang V6/GT calipers. That's what this thread is about, adding the PBR Mustang V6/GT calipers to the MN-12.
post #122 of 130 (permalink) Old 04-08-2014, 02:40 PM
Slightly Disjointed
Grinding has to be done with Cobra calipers too. Grind the banjo block, not the caliper.
MN12 performance archives has a good illustration of it http://www.tccoa.com/articles/mn12ho...ke_upgrade.htm
Oh and the threads should be the same, 03/04s used coarse thread rather than fine thread.
post #123 of 130 (permalink) Old 04-08-2014, 04:12 PM
Traveler's Avatar
Well.. unless you are using 17" wheels (or bigger) you can't use the cobra brakes. They are not the same as the standard mustang brakes they've been talking about.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #124 of 130 (permalink) Old 04-08-2014, 04:22 PM
Yeah I will be upgrading to Mustang hubs and 17" wheels at the same time.
1995 Thunderbird LX 4.6- 20% tint, removed air silencer and not much else! (Mustang hubs, Cobra brakes, Vogtland springs, Mark VIII LCAs, Sport shocks and more waiting to be installed)
2013 DIB GT 301A 6-speed- 15% tint, Kooks 1 7/8 mid lengths, off-road x and cat back, Barton 2-post bracket, JPC clutch line, Koni Yellows, Maximum Motorsports C/C plates, BMR K-member, A-arms, UCA & Mount, LCAs and relo brackets, Steeda Ultralites and PHB, Shaftmasters DS, Brembo wheels- Tuned by AED
Dave_6 is offline
post #125 of 130 (permalink) Old 04-08-2014, 05:30 PM
I'm not sure the Cobra calipers fit - the replacement are usually from the Mustang GT or the Mustang V6 of that era.
And I wouldn't grind the brake hose any ... it's a LOT easier to relieve the caliper!
(Or do the smarter thing - grab a set of the stainless lines from Classic Tube - albeit I'd buy them from Victor at SpinningWheels-SC.COM - and replace those rubber hoses with the better hoses.)
Fuelly
RalphP is offline
post #126 of 130 (permalink) Old 04-08-2014, 05:41 PM
The Cobra calipers fit; XR7-4.6 (Matt) has them on his car, as do many others from pics I've seen. Just haven't come across much info on putting them on.
Do the stainless lines that Spinning Wheels SC sell bolt right up with no grinding required?
Dave_6 is offline
post #127 of 130 (permalink) Old 04-08-2014, 05:47 PM
Slightly Disjointed
Yeah stainless requires no grinding since the block is so small.
There's no right way to do the grinding, I just prefer the block because you simply mirror the non ground side of the block to get the clearance you need, and it looks much more proffessinal IMO
post #128 of 130 (permalink) Old 04-08-2014, 05:47 PM
Yes they do, for the GT PBRs. They SHOULD if the Cobra PBRs can use the Tbird stock lines.
What they have is a round end, so you can turn it where it clears and fits.
Fuelly
RalphP is offline
post #129 of 130 (permalink) Old 01-03-2015, 10:05 PM
BIRDMANLX281's Avatar
Great write up,,,, i plan on getting my p.b.r calipers tomorrow.. There's alot of good info here...
lowered 1.5'' with vogtlands,, tokico ''blues'' on all 4 corners... 28% mirror tinted windows,, P.I.Intake swapped,, S.C side skirts and rear bumper..
BIRDMANLX281 is offline
post #130 of 130 (permalink) Old 01-14-2016, 06:40 PM
This is an awesome upgrade; I'll be doing it to all my cars.
The calipers are available powdercoated from RA for less than $100 per pair, less if you have a core to return.
I bought slotted and drilled rotors as well; these brakes really Rock!!
These clear 15" wheels, BTW.
