Common Acronymns - TCCoA Forums
post #1 of 64 (permalink) Old 08-24-2009, 08:29 AM Thread Starter
Common Acronymns
In response to some older threads (namely, this one) I've compiled a list of some of the more commonly used acronyms you might find on the site, in the context of how they're likely being used on the site. I've tried to omit the silly/less useful ones, but if there are some you can think of that I've missed, let me know and I'll add to the list.
Technical/Car Related Acronyms/Abbreviations
2V = 2-Valve (SOHC)
3V = 3-Valve (SOHC)
4V = 4-Valve (DOHC)
AC = Alternating Current
A/F = Air to Fuel
A/T = Automatic Transmission
ABS = Anti-lock Braking System
ACT = Air Charge Temperature
ATDC = After Top Dead Center
BHP = Brake Horsepower
BOO = Brake On/Off
BSFC = Brake Specific Horsepower
BTDC = Before Top Dead Center
CAI = Cold Air Intake
CCRM = Computer/Constant Control Relay Module
CEL = Check Engine Light
C[K]PS = Crankshaft/Camshaft Position Sensor
COP = Coil On Plug
CTS = Coolant Temperature Sensor/Sender
CV = Crown Victoria/Constant Velocity
DC = Direct Current
DIS = Distributorless Ignition System
DMM = Digital Multimeter
DOHC = Double Overhead Camshaft
DPFE = Differential Pressure Feedback EGR
DS = Drive Shaft
DTC = Diagnostic Trouble Code[s]
EATC = Electronic Automatic Temeprature Control
ECT = Engine Coolant Temperature
ECM = Engine Control Module*
ECU = Electronic Control Unit
EDIS = Electronic Distributorless Ignition System
EEC = Electronic Engine Control*
EFI = Electronic Fuel Injection
EGR = Exhaust Gas Recirculation
EGT = Exhaust Gas Temperature
ET = Elapsed Time
EVAP = Evaporative Emissions
EVO = Electronic Variable Orifice
EVTM = Electrical and Vacuum Troubleshooting Manual
EVR = EGR Vacuum Regulator
FFS = Feedback Fuel System
F/I = Forced Induction [engine]
FN10 = Full-size North American Project #10
FP = Fuel Pump
FPDM = Fuel Pump Driver Module
FPR = Fuel Pressure Regulator
FSM = Factory Service Manual
FSSB = Front Suspension Support Brace
HCI = Heads/Cam/Intake
HEGO = Heated Exhaust Gas Oxygen Sensor
HO = High Output
[H]O₂S = [Heated] Oxygen Sensor
IAC = Idle Air Control
IAT = Intake Air Temperature
IRCM = Integrated Relay Control Module
IRS = Independent Rear Suspension
IMRC = Intake Manifold Runner Control
J-mod = Jerry's transmission modification
KOEO = Key On Engine Off
KOER = Key On Engine Running
LCA = Lower Control Arm
LECB = Lower Engine Cradle Brace
LTFT = Long Term Fuel Trim
MAF = Mass Airflow [sensor]
MIL = Malfunction Indicator Lamp
M/T = Manual Transmission
MLPS = Manual Lever Position Sensor
MN12 = Mid-size North American Project #12
N/A = Naturally Aspirated [engine]
NPI = Non-Performance Improved
NOS = Nitrous Oxide System/New Old Stock
NSS = Neutral Safety Switch
NVH = Noise/Vibration/Harshness
OBD-I = On-Board Diagnostic system Rev. 1
OBD-II = On-Board Diagnostic system Rev. 2
OD = Overdrive
ODA = On Device Adjust
OE[M] = Original Equipment [Manufacturer]
P/A = Power Adder [engine]
PC/ED = Powertrain Control/Emission Diagnostics
PCM = Powertrain Control Module*
PCV = Positive Crankcase Ventilation
PFE = Pressure Feedback EGR
PI = Performance Improved
PnP = Ported and Polished
PTV = Piston to Valve
RKEM = Remote/Keyless Entry Module
RPM = Revolutions Per Minute
RTLB = Rear Torsional Load Bracing
RWHP = Rear Wheel Horsepower
RWTQ = Rear Wheel Torque
SATC = Semi-Automatic Temperature Control
SC = Super Coupe/Supercharger
SOHC = Single Overhead Camshaft
STB = Shock Tower Brace
STFT = Short Term Fuel Trims
TB = Throttle Body
TC[C] = Torque Converter [Clutch]
TDC = Top Dead Center
TOT = Transmission Oil Temperature
TTY = Torque To Yield
TPS = Throttle Position Sensor
TSU = Temperature Sending Unit
TV = Throttle Valve
UCA = Upper Control Arm
VAPS = Variable Assist Power Steering
VMM = Vehicle Maintenance Monitor
VSS = Vehicle Speed Sensor
WOT = Wide Open Throttle
Misc. Acronyms/Abbreviations
AED = Allen Engine Development
AFAIK = As Far As I Know
BTW = By The Way
SCCoA = Super Coupe Club of America
FRPP = Ford Racing Performance Parts
FWIW = For Whatever It's Worth
IIRC = If I Recall/Remember Correctly
IME = In My Experience(s)
IM[H]O = In My [Humble/Honest] Opinion
N/m = No Message/Nevermind
NIB = New In Box
OP = Original Poster
PBR = Paton's Brake Replacements
QFT = Quoted For [the] Truth
QH = [Moates] Quarterhorse
SCT = Superchips Custom Tuning
TCCoA = Thunderbird and Cougar Club of America
TSB = Technical Service Bulletin
TY = Thank You
TTT = To The Top
X2/X3/+1 = Showing agreement with a previous statement
YMMV = Your Mileage May Vary
* = A reference to a computer. For MN12s and FN10s, many of the different functionalities of specific types of computers in other cars was combined into the single unit PCM.
post #2 of 64 (permalink) Old 08-24-2009, 08:37 AM
Seasoned Geek
Very nice B MODS this needs to b a sticky
post #4 of 64 (permalink) Old 08-24-2009, 10:03 AM
Don't forget J-mod or Jmod.
The Jmod is an abbreviation for the Jerry Wroblewski transmission Modification. Jerry was an transmission engineer with Ford and was instrumental in the development of the 4R70W Transmission that came out in 1993.
The Jmod will firm your shifts up considerably. It consists of drilling the separator plate, removing the spring from the 2-3 accumulator, and removing the lower spring from the 1-2 accumulator and replacing the upper spring in same accumulator.
http://www.tccoa.com/articles/tranny...on/index.shtml
post #5 of 64 (permalink) Old 08-24-2009, 10:41 AM Thread Starter
Initially I left J-mod off because I considered it more an abbreviation than an acronym, but I'll add it.
post #6 of 64 (permalink) Old 08-24-2009, 01:52 PM
Moderator & Teksid Whore
guitar maestro's Avatar
CV also stands for Constant Velocity
also, ECU, ECM, and PCM need to have some notation added that they, in effect, refer to our car's computers
guitar maestro is offline
post #7 of 64 (permalink) Old 08-24-2009, 01:59 PM Thread Starter
Done!
post #8 of 64 (permalink) Old 08-24-2009, 02:05 PM
peace keeper v8's Avatar
I learned something today!
-J.D.
1995 Thunderbird 4.6L V8 OHC
Titled "Project Thunder-Phoenix" From the ashes, we shall rise!
Check out my site here
peace keeper v8 is offline
post #9 of 64 (permalink) Old 08-24-2009, 02:50 PM
Slightly Disjointed
EATC - Electronic Automatic Temperature Control
SATC - Semi Automatic Temperature control
post #10 of 64 (permalink) Old 08-24-2009, 07:34 PM
ice217's Avatar
im sure everyone knows it but i seen NOS on the list so its ill add it:
OEM - Original equipment manufacturer
MMMMMMMMMMMMM..........MMM..........MMMMMMMMMMMMM
.......MMMMMMMMMMMMMMMMMMMMMMMMMMMMMMM........
MMMMM........................................
THUNDERBIRD: because everyone else drives a mustang.
ice217 is offline
post #11 of 64 (permalink) Old 08-24-2009, 07:36 PM
You forgot the two I'm always having to say to my wife when I buy more parts for my T-Bird:
"OMG, whats' the BFD?!!"
post #12 of 64 (permalink) Old 08-24-2009, 07:38 PM Thread Starter
I'll add it since OE/OEM is occasionally used in documentation for parts and equipment, or references to equivalents.
I will not be adding silly/profane/insulting acronyms to the list, such as "lol", "rofl", "wt*" etc. This is supposed to be a quick reference to acronyms that are used on this site that hold a lot of importance and meaning in posts that new (or old) members might not recognize. The more complex web slang stuff can be deciphered easily enough via Google if it is so desired.
post #13 of 64 (permalink) Old 08-24-2009, 07:41 PM
Very Nice!
post #14 of 64 (permalink) Old 08-24-2009, 07:51 PM
* slides the frosty mug allll the wayyyy down the bar to theterminator93 without spilling any.
Delete my account.
94 Thunderbird XX is offline
post #15 of 64 (permalink) Old 08-24-2009, 08:30 PM
A/T - Automatic transmission
M/T - Manual transmission
ECT- Engine coolant temperature
HO2S - Heated Oxygen sensor
CKPS - Crankshaft position sensor
AC - Alternating current
DC - Direct current
A/C - Air Conditioning
EFI -Electronic fuel injection
HVAC - Heating, ventilation and Air Conditioning
Just to clarify the differences between ECU, ECM and PCM. An ECM is Engine only while a PCM is Engine and transmission (ie: the powertrain). ECU mean electronic control unit, not engine control unit and can mean any module that is controlled electronically not just the ECM.
Rob Burns is offline
post #16 of 64 (permalink) Old 08-24-2009, 09:03 PM Thread Starter
Revised! Yes, your distinctions between the terms regarding the computer are correct, but in our case they all generally refer to the same physical component (with the exception of ECM, which technically would apply but as you stated, covers a much more broad spectrum of components).
post #17 of 64 (permalink) Old 08-24-2009, 10:26 PM
SignofTheCat94's Avatar
Send a message via MSN to SignofTheCat94 Send a message via Yahoo to SignofTheCat94
Definately sticky worthy. Nice job.
Mods? Do the ones in the garage waiting to go on the car count?
Many thanks to my fellow Veterans; I am honored to be a part of your ranks.
SignofTheCat94 is offline
post #18 of 64 (permalink) Old 08-25-2009, 12:46 AM
ACT= air charge temperature (same as IAT in an N/A engine, but in F/I, it means air temps post-compressor/blower
might as well add..
N/A= Naturally aspirated engine
P/A= Power-Adder engine
F/I= Forced induction engine (within the power adder group, but usually denotes super/turbo-charging)
post #19 of 64 (permalink) Old 08-25-2009, 01:04 AM
AED (Allen Engine Development)
-J.D.
post #20 of 64 (permalink) Old 08-25-2009, 08:47 AM Thread Starter
List revised. Thanks everyone for the positive input and more especially for chipping in!
post #21 of 64 (permalink) Old 08-25-2009, 02:19 PM
No problem Glad I could help!
-J.D.
post #22 of 64 (permalink) Old 08-25-2009, 02:59 PM
Now, if people will read it!
post #23 of 64 (permalink) Old 08-25-2009, 03:02 PM
Haha, I doubt it lmao, you stickied it
-J.D.
post #24 of 64 (permalink) Old 08-25-2009, 03:04 PM
Not me, must have been one of the other big hearted mods!
post #25 of 64 (permalink) Old 08-25-2009, 03:13 PM
So just how many acronym lists does the internet really need?
I can see acronym that are unique to the MN12/FN10 platform, but do we really need to reinvent the wheel?
http://www.motorera.com/dictionary/
http://www.autoworld.com/news/glossary.htm
http://www.buyingadvice.com/abbreviation.html
69 F100 LWB w/460 Engine
post #26 of 64 (permalink) Old 08-25-2009, 04:30 PM
cougar_fan's Avatar
Nice job terminator93. I have already found this very useful ! ! !
United States Navy - Honorable Discharge
Nashville Predators - ENOUGH SAID!
See what we've been up to:
http://forums.tccoa.com/95-tennessee-chapter/
cougar_fan is offline
post #27 of 64 (permalink) Old 08-25-2009, 04:48 PM
Seasoned Geek
x2
post #28 of 64 (permalink) Old 08-25-2009, 05:00 PM
cougar_fan's Avatar
Originally Posted by ThunderChecken View Post
x2
Thunderchecken,
I see the "X2" all the time. What does it signify?
http://forums.tccoa.com/forumdisplay.php?f=95
post #29 of 64 (permalink) Old 08-25-2009, 05:03 PM
Seasoned Geek
Thunderchecken,
That I agree with what was said
post #30 of 64 (permalink) Old 08-25-2009, 05:27 PM
bowez's Avatar
MN-12: Midsize North American chassis number 12
FN-10: Fullsize North American chassis number 10
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
