1994 Mark8 ABS leak - TCCoA Forums
post #1 of 5 (permalink) Old 09-14-2016, 07:49 AM Thread Starter
1994 Mark8 ABS leak
I searched a bit, and found nothing specific to this problem...so here goes...
1994 Mark VIII 91.7k miles, car spent most of it's life around Va Beach, Va. (some mild salt air rust) In Raleigh NC now
hub swapped with dual piston Cobra front calipers put on at 88k miles 1/2016, full fluid exchange/bleed at that time.
about a month ago I noticed pedal travel was excessive (not spongy though). added about 4/5 of a pint to Mstr Cyl. no immediate change in pedal travel. about 2-3 days late the pedal firmed up real nice. In searching for the source of front end noise (total front end rebuild at ~90k miles) I noticed paint peeling from the hollow tube that spans the front of the kmember. looked up and see the ABS leakage. This was not leaking when the front end was rebuilt
someone on another site feels very confident it's the gasket plate (with silicone gaskets that relax) between the pump and valve body. That gasket is discontinued so finding one from an old unit is the solution? I have an extra ABS unit, from a 93,4 or 5 iirc. ---
I will post more pics when I pull the fender liner, just wanted to get the ball rolling with some ideas on what it'll take to fix it.
Also, year make model of units that can be used here
1) '94 Mark VIII 91k, on air, Red garnett glaze, black interior total swap; hub swapped with Cobra front calipers 18" 5 spokes, jmod with cooler, Bilsteins, tbird solid rear sway bar, aftermarket audio system with 212 sub, tint
2)'98 Mark VIII LSC 124k, on air, medium charcoal green; ivory/mocha interior; jmod with cooler, tint, Bilsteins, tbird solid rear sway bar
ddnsherrill is offline
post #2 of 5 (permalink) Old 09-14-2016, 08:39 AM
Pulling apart another unit will likely destroy that gasket as well. If the gasket is not available anymore, I would suggest swapping in a complete working used unit.
post #3 of 5 (permalink) Old 09-14-2016, 09:34 AM Thread Starter
info I'm getting from my local friendly JY is compatible ABS vehicles will be:
Tbird 94-97
Cougar 94-97
Mark VIII 94-96
for the plate gasket, discontinued part # F3LY2C254A
is beefing up my flattened out gasket and option?
post #4 of 5 (permalink) Old 09-14-2016, 03:24 PM Thread Starter
#5 in diagram
post #5 of 5 (permalink) Old 02-03-2017, 09:25 PM
EvilMooseofDoom's Avatar
Mine is leaking now as well. Hooray. Kind of hilarious that there are NOS valve bodies and pumps all over the place, but no gaskets anywhere to be found.
So yeah, I bought two Lincolns in a week.
My LarryLand Automotive Facebook Page:
https://www.facebook.com/pages/Larry...61642343862942
My Scribd.com garbage: http://www.scribd.com/larry_vanzandt
EvilMooseofDoom is offline
