PCN chip - TCCoA Forums
 2Likes
  • 1 Post By Grog6
  • 1 Post By Grog6
post #1 of 8 (permalink) Old 01-30-2017, 09:52 AM Thread Starter
PCN chip
Anyone have experience with PCN chips?
Ford Thunderbird
They offer one for 94/95 V8 Tbirds and I'm thinking about it.
jdhughes909 is offline
post #2 of 8 (permalink) Old 01-30-2017, 11:15 AM
Ford Thunderbird
That's a complete waste of money.
You want a real tune.
Get yourself an xcal2, 3, or 4 used, UNLOCKED, on ebay, and call Don Lasota at Lasota Racing.
That totals less than $300, if you get a good deal on the xcal.
And you can use it for datalogging.
Woodman likes this.
post #3 of 8 (permalink) Old 01-30-2017, 11:45 AM
Slightly Disjointed
It's a scam.
moved to newbie forum
post #4 of 8 (permalink) Old 01-30-2017, 02:12 PM
S4gunn's Avatar
Hahahahaa.
Check out some of the quotes about this "product"
I recently bought one of these chips and I made the mistake of looking at the reviews after I bought it, I popped open the "module" and all that's in there is a half ass glue job and a piece of metal, no software at all.
https://www.cargurus.com/Cars/Discus...15065_ds509816
1) It only looks like there are two wires coming out of this module in the picture. Logically speaking, the only way that a single signal could significantly affect the tune in any way that could be potentially positive (other examples would be to cut spark or cut the fuel pump -- neither of which would have the desired boost of more powah), would be to trick the MAF into underreporting the airflow going into the engine and therefore "leaning" out the engine. A resistor could do that by lowering the voltage the ECU reads from the MAF for a given airflow. Running more lean = more powah and better fuel economy but going Too lean = detonation. Not so good.
- This is much like how the MAF "re-calibration" tubes are supposed to adjust and compensate for bigger injectors. It might work for some (even maybe most) of the airflow curve but it's not going to be as exact as actually modifying the fuel/air tables in a "proper" tune.
- IIRC, except for the 3.8SC no tbird engine has a knock sensor that the ECU uses to retard ignition timing is knock is detected.. Therefore, running leaner than stock esp with a glued together chip is in no way a good idea with one of these engines since how would it know you are experiencing engine knock?
2) Realistically speaking ANY proper tune on a N/A engine will only get you 10% if the baseline ECU can still run the current setup (you WILL need a tune if you upgrade the injectors but if you do basic exhaust upgrades or even a mild cam/replacement heads as examples your stock ECU will be able to handle the new setup). You should automatically mistrust anyone who offers you more than that.
BOTTOM LINE/TLDR advice:
PLEASE buy this chip. Things have been quiet around here recently so we could all use a good laugh.
More Useful Advice: the best bang/buck for these cars performance wise are shorter rear gears. Used 3.73:1 gears can be had for $30-60 locally and while it can be a bit messy setting up a rear diff is fairly straightforward work (although a press is needed).
You can also remove the diff, farm the rebuuild work out fairly inexpensively ($200 or less in labor), and then reinstall it yourself.
-g
S4gunn is offline
post #5 of 8 (permalink) Old 01-30-2017, 06:26 PM
I found that by recalibrating the MAF/injector setup to a stock Tbird, I picked up a lot of precision, (throttle response, better shifting, etc.) but no real additional power.
I basically went thru the procedure in Don's book for mapping the transfer curves, and setting them more exactly than stock.
You have to have a wideband, and a lot of patience.
This MN12 gets ~2mpg better than the other ones, for the same drive and driving style; but the others are both modded and tuned.
Randomly tweaking the MAF to read lean is a great way to dust a motor at WOT on a cold, dry morning. Even a stock one...
I can't believe people can sell this stuff, but...
Woodman likes this.
post #6 of 8 (permalink) Old 01-31-2017, 08:04 AM
Thunderstruck95's Avatar
This would at least be better than a sealed mystery box if you wanted to play with things-
IST Products
1995 T-Bird. PI 4.6. Bullitt intake. Big MHS cams. 4,200 Dirty Dogg converter. Kooks headers. Full exhaust. 4" Drive Shaft. 4:10s.
Waiting on a tune.
1997 Lincoln Mark VIII FX2 Sand Dune Machine.
Thunderstruck95 is offline
post #7 of 8 (permalink) Old 01-31-2017, 08:55 AM
If you want to tune your car, I really see only one way to do it.
1) Pick a competent tuner to work with you, such as LaSota ( LaSota Racing Ford Tuning & Training ), Dalke ( https://www.facebook.com/pg/XR7Dave/photos/ - I thought they had a separate web page!), or our own Decipha (send him a PM here).
2) Pick up the tuner they recommend.
3) Also, pick up a wide band O2 sensor.
4) Start working with that tuner (person) and the tuner (hardware) to get your car running like you want.
But if you want to go cheap - get that wide band. NOW. And also grab something like Torque Pro (if you're running Android) and a Bluetooth OBDII reader so you can monitor what your car is doing, or at least what the ECU thinks it's doing.
Anything else, might as well be slapping V-TEC stickers on the car "cuz they give you like 50 HP!!"
Fuelly
RalphP is offline
post #8 of 8 (permalink) Old 01-31-2017, 10:36 AM Thread Starter
Perfect. Thanks for the replies and info. This gets me started in the right direction.
I've owned my 94LX for 20 years now and used to do a lot with it in the early 2000's. I haven't done much with it over the last 10 years or so. Just had it painted with SC kit on it. Hub swap and wheels/tires are next. Still lots of questions and this site is most helpful.
