Belt Tensioner/Idler Pulley Thread Direction? - TCCoA Forums
post #1 of 3 (permalink) Old 02-22-2017, 08:00 AM Thread Starter
Natesriv's Avatar
Question Belt Tensioner/Idler Pulley Thread Direction?
I'm thinking I need to replace one or both. I'm hearing that chirpy wobble wobble sound on light acceleration. It's not a slipping belt, I think it's a bearing. I'm assuming it's the belt tensioner as it only does it when I give it gas.
I've done them on my old Riviera, BUT the threads on those were reversed, so they wouldn't unscrew themselves should they fail.
Are they reversed on my 93 5.0?
Thanks!
Natesriv is online now
post #2 of 3 (permalink) Old 02-22-2017, 11:49 AM
MaddMartigan's Avatar
Thanks!
Nope. Both of the pulleys are standard thread. The direction the belt runs would tighten them if it worked that way.
1993 Ford Thunderbird LX
Coast High Peformance 342 Stroker
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.73 gears
Custom aluminum driveshaft
Built Darrin/dirtyd0g AOD with wide ratio gearset
dirtyd0g 9.5" Custom Torque Converter
Quarterhorse ECM from Moates
Zeitronix ZT-2 WB O2
No times under new system.......yet.
OMGHI2U
MaddMartigan is offline
post #3 of 3 (permalink) Old 02-22-2017, 02:17 PM Thread Starter
Natesriv's Avatar
Cool!
I didn't actually look at the direction the belt moves.
