5.0 V8, is this the low side A/C connector? - TCCoA Forums
post #1 of 5 (permalink) Old 03-17-2017, 09:53 PM Thread Starter
Natesriv's Avatar
I've some R-12 to put in the car this weekend. Which side is the low side on a 5.0. I think it's the passenger's side.
Am I correct??
Thanks amigos!
Nate
Natesriv is offline
post #2 of 5 (permalink) Old 03-17-2017, 11:21 PM
That one's HIGH side; it's between the compressor and the condensor.
Try the other side; it's over by the compressor.
Fuelly
RalphP is offline
post #3 of 5 (permalink) Old 03-18-2017, 07:44 PM Thread Starter
Natesriv's Avatar
Gotta be this one then, it's the only one my kit will fit, and the only connector besides the other one I posted a pic of.
Natesriv is offline
post #4 of 5 (permalink) Old 03-18-2017, 09:38 PM
Yep, that's low pressure.
It becomes obvious if you follow the hoses ... compressor --> HP fitting going into condensor --> outlet hose to evaporator --> evaporator to accumulator --> to high pressure fitting and compressor.
BTW, the expansion valve is in the hose from the condensor to the evaporator. I've found it's cheaper to just replace the whole line.
Fuelly
RalphP is offline
post #5 of 5 (permalink) Old 03-21-2017, 08:06 AM Thread Starter
Natesriv's Avatar
pulled in the R12 when it was 78° no problem. Then added the 2oz oil...
System's running fine. No click on click off every 10 seconds...
Natesriv is offline
