1992 T-Bird LX 5.0 AOD swap - TCCoA Forums
post #1 of 13 (permalink) Old 04-27-2017, 06:54 AM Thread Starter
Hi all
I swapped a 1989 T-Bird SC AOD into my 1992 T-Bird LX 5.0 L and I reused the old TV Transmission Valve Cable. Unfortunately it is much too short, if I mount it correctly on the retainer, the Valve is always fully engaged and the tranny doesn't switch out of 1st gear. If I let it hang loose (not fixed in the retainer) it works, but shifts up too late.
Does anyone have some recoomendations, about what I can do?
Thankx
Ploppy
ploppysator is offline
post #2 of 13 (permalink) Old 04-27-2017, 07:25 AM
You reused the old TV cable out of the LX, or the old SC TV cable?
If the former, triple check your routing; it should still fit.
But if it doesn't, Lokar makes a nice generic kit you can sub in, although you may have to reroute the run a bit.
Oh, and DON'T DRIVE THE CAR. You'll burn that transmission out shortly like that.
Fuelly
RalphP is online now
post #3 of 13 (permalink) Old 04-27-2017, 07:55 AM Thread Starter
Hi Ralph
Thank you for your quick answer.
I used the one from the LX as the SC one was even much shorter, as the throttle body is much more behind than on the LX.
If I have no time to order a Lokar kit, could it be possible to just use a metal extension to be mounted on the TV Valve on one side and at the end of the TV cable brass part on the other side, as shown in my attached drawing?
Thank U a lot for helping
best regards
Ploppy
post #4 of 13 (permalink) Old 04-27-2017, 07:57 AM
The SC and the 5.0LX TV cables are exactly the same. You did something wrong on the install.
post #5 of 13 (permalink) Old 04-27-2017, 08:04 AM Thread Starter
Hi MadMikeyL
No, the one from the SC donor was over 5 inches shorter between the retainers.
But there is a 1990 SC sitting around in my backyard, I will compare those 2 again, maybe the other is longer
Thank U
regards
Bruno
post #6 of 13 (permalink) Old 04-27-2017, 09:16 PM
If it is shorter, then it wasn't from an SC. The SC and the 5.0 MN12 have the throttle body in the exact same place, use the exact same throttle cable, intake tube, and TV cable.
post #7 of 13 (permalink) Old 04-28-2017, 07:20 AM Thread Starter
Red face ...fixed
Hi all
I took all three out and:
the Cable out of the 89 is the shortest, but the difference is only 2 inches compared to the 92 LX
the Cable out of the 90 is 1 inch shorter than the 92 one
i took a picture from the 90 and the 92 one and will add it here.
What I did finally is taking a rubber water plug from a Chrysler LeBaron (cylinder hat shaped, about 1 1/2 inch long, no idea, where it was placed in this car), cutted it longitudinally, then I pushed it on the TV cable, behind the retainer, and fastened the TV cable with a long screw at the retainer and now:
The car is driving like new and all gears work smoother than ever....
See my nice drawing, please
thank U for all the kind and very appreciateable help
best regards
Ploppy
File Type: jpg Ford Thunderbird 1990 SC and 1992 LX TV Cable difference.jpg (1.08 MB, 4 views)
post #8 of 13 (permalink) Old 04-28-2017, 07:28 AM
Natesriv's Avatar
Quick question, does your TV cable run UNDER the fuel rail? On mine it does and it seems odd to route it through there, but that actually might be the shortest route.
5.0 V8 BTW, just curious. Thinking if nobody else's does, I'll reroute mine to above the fuel rail.
Natesriv is offline
post #9 of 13 (permalink) Old 04-28-2017, 08:00 AM Thread Starter
on the 5.0 B8 it runs over the fuel rail
post #10 of 13 (permalink) Old 04-28-2017, 08:06 AM Thread Starter
From my old pictures I saw, that the throttle from the '92 is a little bit more on the driver side, than it was on the '91, as the entire intake on the 92 is wider, I believe, this could make the difference in the TV cable length, but not cause the problem with the smaller end on the TV side on the transmission, this could be caused by a different gear housing (I found out, that the main problem is the position of the retainer and not the length of the cable)
post #11 of 13 (permalink) Old 04-28-2017, 08:50 AM
Natesriv's Avatar
Originally Posted by ploppysator View Post
on the 5.0 V8 it runs over the fuel rail
Looks like re-routing time!
Relatively simple...
Natesriv is offline
post #12 of 13 (permalink) Old 05-01-2017, 06:02 PM
Rayo's Avatar
It looks like you've managed to make something work..
Anyways, As long as you're using your original TV Cable from your (5.0 MN12)..I don't see how it could be too short/long??
The only thing I can think is, maybe the shift lever is not lined up correctly??
Are the levers parallel with each other like in this pic?
1991 Ford Thunderbird Sport
Rayo is offline
post #13 of 13 (permalink) Old 05-01-2017, 07:20 PM
Like I said before, all 89-93 SCs and all 91-93 5.0 MN12s have the throttle body in the exact same place in the engine bay, and in the same place relative to the transmission, and all use the exact same TV cable. There is no difference in the intake manifold on the 5.0 from 91-93. If the cable you are using is shorter, then it is not from an SC, and it is the wrong part. It may be from a N/A V6 MN12, or it may be from a Mustang, or panther car, or something else, but if it is shorter, it is the wrong part, plain and simple. Making something that works is all well and good, if it really does put it exactly where it needs to be, but the AOD is extremely sensitive to the TV adjustment, and if it is off by just a tiny bit, you could well be replacing the trans again in a few thousand miles.
Tags
aod swap tv valve cable
