MUST READ: A Guide to Common Searches - TCCoA Forums
post #1 of 4 (permalink) Old 08-14-2005, 02:28 PM Thread Starter
CEO Red Sox Nation
DMcBrideBoston's Avatar
Classic Searches....Done For You
NEWBIE VIDEO (LINK UPDATED 4/28/2007)
__________________________________________________ _______________
DO NOT BUY THE K & N FIPK! 100+ dollars, for a 40 dollar filter, so that leaves 60+ bucks for the Bolt and Bracket......You do the cost evaluation...
Just buy the filter, and don't bother with the FIPK, many of us didn't know this and we wasted 60 bucks on this POS for no good reason, other than we were uninformed. Now you are informed...
Compiled here will be a list of search options and the threads which go with each search.
Removing the Air Silencer
Tech Article from MN12 Performance
Another Air Silencer Thread
How to get rid of the 1994 - 1995 Violin Case Intake Tube
ShadowDragons Write up on the GT Intake Tube
Audiobahn Birds Write up on the Civic Tube
Richard M's Violin Case Modification
How to Clean the MAF Wires
Technical Article on the MAF Cleaning
There have been more ways used recently which have been proven safer than the Q-Tip method. The most popular; Using electrical contact spray cleaner will reduce the chances of messing up the little wire contacts.
The Infamous J-Mod "Shift Kit"
Black Ice LSC's Cardomain J-Mod Write-Up
The Technical Articles, The top 3 are MANDATORY reading
PRICES FOR J-MOD PARTS
F75Z-7F284-AA Spring $ 3.39
F4AZ-7F247-A Retainer Cover $ 4.26
F7AZ-7F251-AA 1-2 Accumulator $11.09
F7AZ-7H292-AB 2-3 Accumulator $ 5.61
F6AZ-7A098-A Tranny Filter $19.86
F5AZ-7D100-A Separator Gasket $ 3.44
F2VY-7C155-A Separator Gasket $ 5.72
PI Intake Swap / Parts Gathering for 1994/95 T birds and Cougars
Whitecoug's Write - Up
Whitecoug's Part's Listing for PI intake onto 94/95's
How to tell if your car has Trac-Lok and not the "One Tire Fire"
Technical Article for Axles and Gears
Torque Converters............
Johnny Langton's Stock Stall Speeds for TC's
MAURADER TC PRICES
2003 Marauder T/C $159.95 plus $50.00 core charge
2004 Marauder T/C $239.95 plus $50.00 core charge
MarkVIII Flex Plate $54.08
Converter Nuts $0.95 each x 4
Flex Plate Bolts $1.21 each x 6
A Bunch of Links to certain performance/maintenance parts for the 4.6's
Performance Parts Section of My Website
Horsepower / Get up and Go Combo's for the with Approximate Pricing
SCT EEC Performance Chip - Blue Oval Chips
$ 300 - 450 depending on modifications and number of programs.
Comp Cams - 550 a set new from Comp Cams, or try Corral or Modular Depot for used camshafts.
Gears - FRPP Gears will run abround 150 - 175 for the ring and pinion new, another route is the FRPP 3.73 rear end which will have to be used as it is no longer made. Price will be anywhere from 300 - 600 used on one of the above forums.
Headers - The only good option for the 4.6 are Kooks Headers available only at Super Coupe Performance and run 535 bucks uncoated, and 695 dollars Jet Hot Coated. Don't forget your Stage 8 Header Bolts and the 2000 degree coating upgrade
Underdrive Pullies - Options are Steeda, ASP, March and Ford Racing. Steeda and ASP are the same pullies, ASP makes them and Steeda re packages them and increases the price. Pick up the ASP's for better value. The UD pullies will run between 50 (Used) and 150 (new) from Steeda
U/D Thread
Nitrous - The nitrous kit most use is the Dry Kit, due to the fuel puddleing in the plastic intakes which may cause it to blow up the intake, not saying that a Wet kit is bad, just not AS safe as a dry kit.
Nitrous Express - Zex - NOS
Used Kits: Corral, Modular Depot, Ebay - They usually go for around $300 - $350.
New Kits: Ebay $475.00 or Summit Racing.com $509.00
Part Number for Zex Kit is: 75 - 125hp shots = 82015
55 - 75 hp shots = 82011
1996 - 1997 Headlight Swaps for earlier years 94 - 95's.
Here is a webpage with instructions
Buy your header panel here
Headlights will be best found on Ebay.
Standard Audio Questions
Speaker Size on all 1989 - 1997 Thunderbirds and Cougars will be either 6" x 8" or 5" x 7" .
2005 Infinity Kappa 6 x 8's
IKE SOUND 6 x 8's
Transmission (4R70W) Swap Info
When swapping the 4R70W out of your Thunderbird, Cougar and Mark 8 you have several options. Swapping for a stonger transmission will be the best option when yours fails. You will want to choose one with a Mechanical Diode and the newer updated valve body.
1998 - Lincoln Mark 8 Transmission ( doesn't have the updated valve body)
1999 to 2004 - Mustang GT transmission
1999 to 2004 - Crown Victoria transmission (Non-police package)
1999 to 2004 - Grand Marquis transmission
Most of the transmissions after 1998 used in cars have 8-tooth speedo gears on the output shaft, so if you're running 3.73's or steeper; You'll need a speedcal to get the VSS output right. (Courtesy of JL)
You can get a speedcal here
or here....
Most find their used transmission deals here.
When using the newer transmission, you will want to update these parts:
5.4 EPC selenoid is -
XL3Z-7G383-AB = 45.38 (list 60+)
Your year Transmission MLPS -
Your year Transmission TCC Selenoid -
You will also want to use a Magnetic Inline Filter for extra protection after blowing your old trans. These can be bought here. You want the 5/16th's size lines, unless you upgraded to the bigger 3/8th size lines.
Transmission Coolers
B&M Transmission Coolers Sizes 16K GVW to 28K GVW
Possible Sources for Coolers
www.bulkpart.com carries Hayden coolers - www.haydenauto.com is the company's site
www.summitracing.com carries B&M coolers - www.bmracing.com is the company's site
(Lil Tip) The top line at the radiator is the return line, the bottom line at the radiator is the hot line.
2003 Mustang Cobra Radiator Swap
03 Cobra Radiator Thread
Cobra Fan and Shroud - 3R3Z-8C607-AA
Wiring Loom - 1U2Z-14S411-AGA
Cobra Radiator - 3R3Z-8005-BA
2003 Infiniti G35 Sport Package with Navigation
Best Auto Insurance | Auto Protection Today | FREE Trade-In Quote
DMcBrideBoston is offline
post #2 of 4 (permalink) Old 10-20-2005, 02:16 AM Thread Starter
CEO Red Sox Nation
Thunderbird and Cougar Exterior Modifications
Clear Corners on Ebay(Cheapest Around)
Vent Visors on Ebay
Thunderbird Decals
VFN Thunderbird 3" Smooth Cowl Hood
Pricing can be seen through VFN's Website
__________________________________________________ ______________________________________
BRAKE PROBLEMS
If you have some braking issues; here are some common reasons:
1. Spongy Pedal
(Air – Bleed from the furthest bleed screw from the master cylinder and work in . Bleed screws up)
(Caliper brackets not square to rotor causing caliper deflection)
(Rubber brake lines deflecting)
(Brake fluid too hot)
(Pedal ratio too high)
(Silicone brake fluid – highly compressible)
2. Low Pedal – Have to pump the pedal to get it hard
(Master cylinder too low causing fluid drain back to reservoir – install 2 lb. Residual pressure valve or move reservoir higher than calipers)
(Warped rotor causing piston knock back)
(Excessive rotor runout causing piston knock back)
Excessive piston retraction – install square seals)
3. Low Pedal – Won’t Pump Up
(Bad caliper seals, leaking)
(Leak in hydraulic system)
(Balance bar too far off center)
(Badly worn pads)
4. Pedal Hard – Car Won’t Stop
(Master cylinder too large, too much volume)
(Pedal ratio too small – Insufficient pressure on master cylinder)
(Glazed rotors)
(Glazed pads)
This information was taken from Outlaw Racing Disc Brakes
1. Stonger Half-Shafts:
www.raxles.com
2. Solid Rubber Motor Mounts:
http://www.mn12performance.com/mn12parts/em/em.html
3. Steeda Polyurethane IRS Bushings
http://www.mustangwarehouse.com/must...gory_Code=V8L3
4. Ported and Polished Cylinder Heads:
http://www.steenracing.com/portandpolish.htm
Jim Oneil @ Renegade Racing
5. Oil Filter Relocation Kit:
http://www.northernautoparts.com/Pro...ctModelId=9480
6. Blue Oval Performance EEC Chips:
www.blueovalchips.com
7. Nitrous Oxide Accessories:
http://www.speedshop.org/store/Scripts/default.asp
8. Rail Mounted Fuel Pressure Gauge
http://store.summitracing.com/defaul...06;=SUM-800160
9. Camshaft Timing Chain Retention Tool:
http://www.andersonfordmotorsport.co...ts/new-46.html
10. Inline Transmission Filters:
http://www.bulkpart.com/Merchant2/me...ry_Code=Inline
11. Lo-Tek Triple Gauge Pods:
http://www.gaugepods.com/ford.html
12. Street Tires:
http://www.tirerack.com/
13. Hoosier Drag Slicks:
Summitt Racing Part Number HOO-18120
14. Transmission Oil Cooler:
http://www.bulkpart.com/Merchant2/me...ory_Code=TCCHD
15. Fuel Rail AN Adapter:
http://store.summitracing.com/defaul...06;=ATM%2D3280
16. ART True Dual Exhaust System:
http://www.speedfreak.cc/products/texhaust/
post #3 of 4 (permalink) Old 02-28-2012, 09:18 PM
Bird1554's Avatar
Man---This was a great post. I have been wondering about getting rid of the violin case. Great stuff man, thanks!.
Bird1554 is offline
post #4 of 4 (permalink) Old 09-20-2014, 07:02 AM
Just FYI, the link for the cam tools (9. Camshaft Timing Chain Retention Tool:
http://www.andersonfordmotorsport.co...ts/new-46.html) has been deleted or moved by the company.
Tghanks
Jesse
379parker is offline
