Slimming your car down - Page 3 - TCCoA Forums
 1Likes
post #61 of 139 (permalink) Old 12-11-2007, 07:04 AM
BlackbirdSport's Avatar
Send a message via AIM to BlackbirdSport
If I remember whent he swap-time comes allong, I'll weigh them. I dont have a scale at the momenet.
Consider, though the calipers may be lighter, ther rotors will be heavier. That's an extra 40 cubic inches of steel rotor.
"Keep making it thinner until it breaks, then go one size bigger."
My Cougar XR7
BlackbirdSport is offline
post #62 of 139 (permalink) Old 12-11-2007, 07:21 AM
You know they felt like they where just about the same, take a pound or two.
post #63 of 139 (permalink) Old 12-11-2007, 06:37 PM
Only if we're talking about the Cobra rotors here. Going with the GT PBR setup definitely sheds a bit of weight, as you keep the stock rotor diameter.
-Rod
rodsv6cougar@cs.com
post #64 of 139 (permalink) Old 12-16-2007, 04:56 AM
sCrEaMiN BiRd's Avatar
Took a bit of weight out of the car today... Went ahead and did some winter cleaning in my trunk... The only thing i had to weigh was my bathroom scale which isn't all that accurate i'm sure, especially for weighing things oddball shaped that don't quite fit on the scale well.... anyways...
Alpine Type S 12 + Ported Box = 58 lbs
Steel Spare Tire = 31 lbs
E Jack + Misc. Tire Changing Tools = 11 lbs
Cardboard piece of crap covering the spare tire = 4 lbs
Thinking about taking out the entire trunk interior trim next, especially since i have holes cut in mine for my shock tower bar. Back seat and rear seat belts may come out as well, less weight and an excuse to not give those certain people a ride...
sCrEaMiN BiRd is offline
post #65 of 139 (permalink) Old 12-16-2007, 06:40 PM
V8ThunderCat's Avatar
I don't know if you thought of this or not but to weigh things that don't exactly fit on a scale I do this; I weigh myself, I weigh myself while holding the item, and then I subtract my weight from preivous reading. I hope that helps.
-Randy-
V8ThunderCat is offline
post #66 of 139 (permalink) Old 12-16-2007, 10:04 PM
I thought about that as well. I just decided to throw the things i needed to weigh on the scale and go from there. Some things such as the sub box would be hard to weigh while holding because the box would block my view of the gauge. Thanks for the advice though, i'm sure it will be helpful to other members.
post #67 of 139 (permalink) Old 02-14-2008, 04:54 PM Thread Starter
shaken, not stirred
stangboy7's Avatar
Updated the Brakes section. And i seen that fanblades weigh about 17.5 lbs each, any confirmation on this. Ans what about sport/SC rims. Anyone got the weights on those?
C.Hill
'97 Laser Red T-bird w/ Option 66S - 125,000 miles, stock except for 3.73s Best ET 15.6 @ 88.3
'94 Electric Red T-bird LX V-8- 212,000 miles- SOLD
2005 Ebony Black Excursion Limited 6.0 Diesel STUDDED
"Thinking is the hardest work there is, which is the probable reason so few engage in it."
- Henry Ford
"Opportunity is missed by most people because it is dressed in overalls and looks like work."
- Thomas A. Edison
http://www.tailofthedragon.com <---- A test of driving ability and nerves.
stangboy7 is offline
post #68 of 139 (permalink) Old 02-29-2008, 09:44 PM
Reaper 94lx's Avatar
Send a message via Yahoo to Reaper 94lx
I agree we need to find out the weight of the SC/Sport rims I have a full set on my V8. I also have a set of early SC rims. I'll check and see what they weigh when I can.
94 Thunderbird 4.6 4R70W 3.08 Died on 12-13-05 rearended and totaled
87 Thunderbird Turbo Coupe 2.3 T5 3.55 Locker!!! Stock and needs a cam
95 Thunderbird Black 4.6 Richard M Intake K&M 4R70W about to get a 2003 J-mod 4R70W 3.08 new owner since 4-22-06
Reaper 94lx is offline
post #69 of 139 (permalink) Old 02-29-2008, 10:02 PM
JNT
JNT's Avatar
16" 89-93 SC wheels are 21 lbs
1997 Thunderbird 4.6L LX
SCT XCAL 2 From Lonnie, 02 Mustang MAF and air box, Dynomax Cat Back Exhaust, Steeda U/D Pulleys, 70MM FRPP TB, Dual Piston Calipers, KVR Rotors, Alpine CD, Polk Speakers
1994 Thunderbird SC (Needs Work)
1996 Bronco XL
2003 Escort ZX2
1996 Bronco XLT Sport
Mid Atlantic MN12 www.mamn12.com
Project Cars: 69 Lincoln Continental, 81 Ford Thunderbird
post #70 of 139 (permalink) Old 02-29-2008, 11:03 PM Thread Starter
shaken, not stirred
stangboy7's Avatar
I know they look similar but are these the same as '96/97 Sport rims as far as weight?
C.Hill
- Henry Ford
- Thomas A. Edison
post #71 of 139 (permalink) Old 02-29-2008, 11:11 PM
JNT
JNT's Avatar
Not sure what the weight is on those. The 94-95 SC wheels are the same as the 96/97 sport wheels. The 89-93 wheels are different.
1996 Bronco XL
2003 Escort ZX2
post #72 of 139 (permalink) Old 02-29-2008, 11:17 PM
Slightly Disjointed
dont forget, theres an extra 0.000000000001 lb weight advantage of the 93-95sc wheels over the 96/7 ones because of the notch for center cap removal
post #73 of 139 (permalink) Old 05-03-2008, 05:01 PM
Great topic!
But.....I threw those center caps off cause it looks a lot sportier. Was missing 1 of 4 anyway so I took the other three off and was pleased with the look.
Haven't gotten an Indecent Exposure ticket yet either because of my nuts showing!
Seriously though, has anyone put a fairly stock MN12 (steel body, no fiberglass) on those 4 wheel scales that racer shops have? What were those results?
I'd love to pair my 'bird down as much as I could; tons of kickass ideas here already. But realistically I'd have to save those kind of plans for a second 'bird. The one I have has to stay in Daily Driver status.
Delete my account.
94 Thunderbird XX is offline
post #74 of 139 (permalink) Old 05-03-2008, 05:28 PM
just an update, the car originally weighed 3,940 lbs.
Current weight with me out of it, 2,960 lbs.
Still have more to come off.
post #75 of 139 (permalink) Old 05-03-2008, 05:54 PM
Yikes! I kinda figured it was high though....
Wooooow. Cool!
Delete my account.
post #76 of 139 (permalink) Old 07-07-2008, 02:54 AM Thread Starter
shaken, not stirred
stangboy7's Avatar
Updated, new engine part weights.
C.Hill
- Henry Ford
- Thomas A. Edison
post #77 of 139 (permalink) Old 07-19-2008, 02:26 PM
Wow, you lost 980lbs in a year or so! I have a friend who is 6'4" and 450, I'll have him join the thread. Seems like your diet plan works wonders. Might save him $30K over lap band surgery.
(/smart aleck remark)
He could probably use some tips on lightening his '79 Thunderbird as well.
Alan Moore
Wichita Falls, TX
2000 Dodge Durango Sport, 318/44RE
1976 Ford Gran Torino sedan, 351C/FMX
occupant is offline
post #78 of 139 (permalink) Old 07-19-2008, 03:29 PM
Well, what are his plans for the car?
Street or race?
post #79 of 139 (permalink) Old 07-25-2008, 11:13 AM
quikbird's Avatar
Well i weighed my dash last night its about 39lbs with out stereo, AC/heater controls, insturment gauge, and glove box. Weighed it with bathroom scale
quikbird is offline
post #80 of 139 (permalink) Old 07-25-2008, 12:38 PM
I'm hopefully going to drop a little over 100 more lbs.
It adds up on paper...
switch out the C6 for a C4....should be right around 100 lbs lighter, and switching to a fuel cell, should knock off another 20 lbs.
And, maybe an aluminum DS....which I think I'm going to need another anyway, cause I had to cut down my original one to fit for the C6.
post #81 of 139 (permalink) Old 07-25-2008, 08:07 PM
quikbird's Avatar
i have a c4 but it was for my 88 t-bird(gone now) and I'm switching to a fuel cell too.
They don't make a bell for 4.6 to c4 do they?
quikbird is offline
post #82 of 139 (permalink) Old 07-25-2008, 08:29 PM
Yes, I believe they do....but I do not rememebr who the "who" is?
post #83 of 139 (permalink) Old 08-15-2008, 12:39 AM
Thursty_Turtle's Avatar
Hey great thread awsome info i wanna put my bird on a diet but how far can i go and still bear to drive on street/hiway on that note what about the sound deadner does taking this out make it horrible to drive
Thursty_Turtle is offline
post #84 of 139 (permalink) Old 08-15-2008, 08:55 AM
tbirdtess's Avatar
3500??
Hello
Well my car weights about 3500lbs
That is with a 351W & AOD. oh yeah a full interior roll cage + 2X3 frame added.
fuel cell, added rear weight. No wiring for lights, No lights, No glass, Lexan windshield or even door guts, cut half the front bumper off, gutted most of the inner hood.
PBR's on the way. No seats, except Aluminum racing drivers seat.
I need to shed about 75lb from the front. looking at the inner fenders but worried
about structural stiffness. Just cut some vents behind front fenders, inner Wheel wel.
Note: PBR's came today! But must be fitted before I can use them.
Paul
Mach1Motorsports likes this.
Paul Nm12tbirdracer@aol.com
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #85 of 139 (permalink) Old 09-10-2008, 07:49 PM
TRickert's Avatar
did anybody figure out the weight of the A/C junk?
TRickert is offline
post #86 of 139 (permalink) Old 10-10-2008, 04:03 PM
paintme205's Avatar
the ac stuff ie compressor, condenser, lines etc was around 30 pounds...
pbr and cobra calipers weigh almost exactly the same. Only difference is in the rotors.
i need ideas to lose weight....its NOT a street car. the following i have removed so far.
hood latch
hood latch mounting bracket
wiper fluid resevoir
abs sensors on wheels. no further than that.
trac loc sensors on diff all the way to drivers foot area
alum driveshaft
alum block
back seats /seat belts
door panels
front speakers
all ac stuff
passenger seat/ seatbelt
rear panels on the inside
racing seat
some ideas i have are
front crash guard? anyone have pics?
alum lower control arms (waiting on perches)
alum diff (need to install)
trace the rest of the abs sensors/wires and remove
trace the rest of trac loc wires and remove
fuel cell in trunk? anyone have pics of the firewall that is required if you do this?
race battery
remove front swaybar? (will it drive ok around corners since i have lowering springs the 5 miles to the track?
remove air bags?
lighter steering wheel?
Im open to any suggestions people have.
i would love to lose some more weight so when i put a 6 point cage in it kinda compensates. that and its the poor mans horsepower.
paintme205 is offline
post #87 of 139 (permalink) Old 10-12-2008, 03:31 PM
JNT
JNT's Avatar
The steering wheel isn't heavy but the airbags are. I would take out the window motors if its just a track car
1996 Bronco XL
2003 Escort ZX2
post #88 of 139 (permalink) Old 10-12-2008, 03:50 PM
Slightly Disjointed
you want to ditch just the abs sensors? the effort of taking them off is not worth the weight lost(which is pretty much nothing) if you want to lose weight from abs ditch abs all together.
same with the front swaybar, thats a huge job taking it off and putting it back on just to go down a track for a few seconds.
i think 392bird has pics of his rear firewall on his members page somewhere.
post #89 of 139 (permalink) Old 10-12-2008, 04:02 PM
rodsv6cougar@cs.com
post #90 of 139 (permalink) Old 10-12-2008, 04:32 PM
Your best choices to drop weight and retain all the DD comforts is the switch from iron/steel to all aluminum parts. These are the aluminum parts that will eventually be on my car Pumpkin/LCAs/Driveshaft/aluminum engine block with plastic intake its about 150 lbs in weight credit to stock. The goal to keep the car at a stock weight or less. Weight added includes a few braces, heavy duty spare tire cover, stereo system with relatively 2 small amps and subs, heavier sway bars. This is my DD and the latest weight to be added is a pair of SC seats. LOL This might sound like I'm going backwards to most people here but it should be about stock weight in the end. I'm not going to race anytime soon but if I go to the track it would be cool to bump the subs on the track during staging and waiting. Run whatcha brung type of idea. Whats the point in taking out something you drive around with all the time just to show a slightly lower ET?
