Slimming your car down - Page 4 - TCCoA Forums
 1Likes
post #91 of 139 (permalink) Old 10-12-2008, 06:56 PM
94TchikinV8's Avatar
Send a message via AIM to 94TchikinV8 Send a message via Yahoo to 94TchikinV8
Originally Posted by 94 Thunderbird XX View Post
Seriously though, has anyone put a fairly stock MN12 (steel body, no fiberglass) on those 4 wheel scales that racer shops have? What were those results?
I put mine on a truck scale and it weighed 3460 lbs without me in it. That was without the back seat and about 1/4 tank of gas. The only other weight reduction was the explorer engine with the AL block and plastic intake. So I'm only a little bit heavier than an automatic mustang.
-Rob
1994 Thunderbird LX V8
Still in pieces in the garage awaiting body work, paint, and a drivetrain...
Currently driving a 98 Mustang GT convertible:
02 Explorer engine, Comp 262ah cams, Steeda underdrives, aftermarket H-pipe with high flow cats, SLP LM1 exhaust, MGW shifter, RAM clutch
13.89@100.81mph, 2.17 60ft(stock 2.73s, worn-out trac-lok)
94TchikinV8 is offline
post #92 of 139 (permalink) Old 10-12-2008, 09:15 PM
paintme205's Avatar
thanks for the picture racecougar. guess i need to look up how thick it needs to be in the nhra rule book. is that one alum or steel?
paintme205 is offline
post #93 of 139 (permalink) Old 10-12-2008, 10:01 PM
NHRA requires a minimum thickness of .024" if using steel or .032" if using aluminum. I used .040" aluminum. Don't forget to do the package shelf as well.
rodsv6cougar@cs.com
post #94 of 139 (permalink) Old 10-14-2008, 11:50 AM
paintme205's Avatar
can i do on top of the package shelf or does it have to be down bottom? i appreciate the quick response..saves me some trouble looking it up.
post #95 of 139 (permalink) Old 10-14-2008, 05:42 PM
You can go over the top of the existing package shelf. The main thing is that you're sealing the trunk off from the drivers compartment.
rodsv6cougar@cs.com
post #96 of 139 (permalink) Old 10-14-2008, 09:48 PM
97grnbird's Avatar
Send a message via AIM to 97grnbird Send a message via MSN to 97grnbird Send a message via Yahoo to 97grnbird
what about the heater core and dash what would that remove
1997 tbird sport alpine green 4.6 auto minor mods so far
former taurus sho owner now turned to the bird.
97grnbird is offline
post #97 of 139 (permalink) Old 10-15-2008, 04:29 PM
paintme205's Avatar
i think the heater core and all heater parts is around 32-35. the dash total has been debated many times. i would estimate a minimum of fifty pounds if you truly want to pull every unnessesary wire and bracket and .......
post #98 of 139 (permalink) Old 10-15-2008, 10:00 PM
Slightly Disjointed
i'd say an assembled dash with the frame, sound deadening, harnesses, passenger airbag and misc. modules it is probably around 80 lbs. the earlier dash's seem to be a bit more, at least thats what my "arm scales"" seem to tell me lol
post #99 of 139 (permalink) Old 10-24-2008, 09:00 PM
Thread Killer
midwestbird's Avatar
-Rob
I also put mine on a truck scale and it was 3820. Thats with a full tank of gas, no driver, 2 amps in the trunk(no sub box yet), Mark DOHC-lower rear control arms-diff and aluminum drive shaft. It also has 18" Speedstars(wich are a bit heavier than the stock 16 inchers. So is my car just heavy like me?
As of 10-20-06 DOHC POWERED
Painted Vista blue as of 08
242hp/251tq
14.39@96.01mph 5-17-08@ Byron Il
RobertP plate modded: 5-23-08
midwestbird is offline
post #100 of 139 (permalink) Old 10-24-2008, 10:02 PM
Ok, thanks! Nice to have a general idea for some kind of baseline to compare against....mine has no added stereo/sub/amp equipment, stock block and intake, fan blade rims, no MKVIII parts, power seats..both drivers and passenger side, etc.
Based on your own given weight and description, should I guess I'm sitting at 3,500-3,600 with said 1/4 tank of gas?
Delete my account.
94 Thunderbird XX is offline
post #101 of 139 (permalink) Old 10-25-2008, 12:12 PM
I'd say probably aound 3600-3700. There's only one way to find out for sure.
-Rob
post #102 of 139 (permalink) Old 10-25-2008, 09:20 PM
paintme205's Avatar
im at 3400 with no spare tire, race seats, alum block, 15 inch rims, no rear seat, and other minor weight reduction. just got weighed yesterday.
post #103 of 139 (permalink) Old 10-25-2008, 10:49 PM
Ok thanks. I do know someone who builds and races circle track cars, and he does have those wheel scales. But it's not very convenient for me to just swing by for that since I moved away from that general area. Just wanted a general idea where my car is sitting at for weight, since I'm not planning on making that kind of a playtoy out of it. If I can get another bird though......that sucker will be street legal by the barest of margins.
Delete my account.
post #104 of 139 (permalink) Old 01-18-2009, 01:36 PM
billboehm's Avatar
when i get mine back from the shop with my hood on it, i'm just gonna take a trunk full of crap to the dump and weigh it on the way out.
9mm Spark Plug Wires
MSD Ignition Coils
Mac Cold Air Package
Hypertech Programmed
Magnaflow Mufflers
Clear Corners
Sandblasting any aluminum parts i can get to without removing the engine
SCP 3.5" Cowl hood
and of course, PAINT!!!
billboehm is offline
post #105 of 139 (permalink) Old 01-20-2009, 09:57 AM
Red-Resurected97_4.6's Avatar
Send a message via AIM to Red-Resurected97_4.6
Originally Posted by thunderbird96 View Post
the stock 96 hood was 60 pounds and my cobra r hood was 30
that sounds about right. my scp cobra r ram air hood doesnt feel as light as it should when im holding it up. honestly it didnt feel much lighter than my stock one. but thats just me. idk. im sure its somewhere around that 30. i thought it felt a little heavier. my guess would be about 40lbs.---i should take it off. set it on a stool thats already on the scale. and subtract the stools weight fromt that...just for you guys haha.
1997 T-Bird 4.6l V8-- Rear mufflers swapped for 2" straight pipes, Air silencer removed and K&N panel filter. SCP Cobra R Ram Air hood.
Red-Resurected97_4.6 is offline
post #106 of 139 (permalink) Old 01-20-2009, 12:50 PM
billboehm's Avatar
some people have heavier "stools" than others...
MSD Ignition Coils
Magnaflow Mufflers
Clear Corners
SCP 3.5" Cowl hood
post #107 of 139 (permalink) Old 03-31-2009, 03:26 AM
Nice write up.
Omega47 is offline
post #108 of 139 (permalink) Old 03-31-2009, 04:43 PM
I just bought some Lincoln LS wheels... 14.4 pounds each....
kustomizingkid is offline
post #109 of 139 (permalink) Old 07-07-2010, 12:25 PM
This thread could use some updating again.
post #110 of 139 (permalink) Old 08-22-2010, 04:52 PM Thread Starter
shaken, not stirred
stangboy7's Avatar
Throw some numbers at me , i'll be happy to update, or if there are newer products that are lighter I will add them to it
-C.Hill
'97 Laser Red T-bird w/ Option 66S - 125,000 miles, stock except for 3.73s Best ET 15.6 @ 88.3
'94 Electric Red T-bird LX V-8- 212,000 miles- SOLD
2005 Ebony Black Excursion Limited 6.0 Diesel STUDDED
"Thinking is the hardest work there is, which is the probable reason so few engage in it."
- Henry Ford
"Opportunity is missed by most people because it is dressed in overalls and looks like work."
- Thomas A. Edison
http://www.tailofthedragon.com <---- A test of driving ability and nerves.
stangboy7 is offline
post #111 of 139 (permalink) Old 08-22-2010, 05:06 PM Thread Starter
shaken, not stirred
stangboy7's Avatar
What size were these rims? Was this the Spare? It sounds pretty light. If you could verify these numbers I will be more than happy to add this in, thanks
-C.Hill
- Henry Ford
- Thomas A. Edison
post #112 of 139 (permalink) Old 08-22-2010, 07:33 PM
MN12 / FN10 Rear Sub-Frame
I weighed a complete 1998 Mark VIII LSC 3.27 open rear sub frame including two Mark VIII spares and it weighed ~355 lbs.
I installed previously mentioned Mark VIII sub frame, then weighed my 1995 Thunderbird LX 3.08 open rear sub frame with the same exact two spares and it weighed in at ~409 lbs.
So the differences were disc vs drum brakes, aluminum pumpkin and lower control arms, and I don't know the differences in the the sway bars or axles for a savings of about 54 lbs. If I remember, I will measure the axle and sway bars and edit this post...
~Rick
TCCoA Sig
post #113 of 139 (permalink) Old 08-24-2010, 09:18 PM
Nice weight data. I can confirm a great deal of that from all the pieces I've taken off my '97 TB-LX.
ProphecyG is offline
post #114 of 139 (permalink) Old 10-21-2010, 10:09 PM
paintme205's Avatar
So here is stuff no one removes or weighs except me and one other person (you know who you are)
Cruise control solenoid and cable 6lbs
aluminum mark 8 spare no tire 10 lbs
abs pickup rings on hubs 5.9 oz each so 1.5 pounds total of rotating weight (for the desperate).
I will keep editing this post as I weigh more things.
post #115 of 139 (permalink) Old 10-22-2010, 08:09 AM
I hardly take weights anymore......that, and I can't find a whole lot to take off anymore...
post #116 of 139 (permalink) Old 10-22-2010, 09:22 AM
paintme205's Avatar
I can relate to the not weighing things anymore. I did a couple since I was curios. Try stripping a street car lol. It's much more of a pain in the butt since I need to drive it everyday.
post #117 of 139 (permalink) Old 10-22-2010, 11:09 AM
FWIW: My '97 in "ready to race" trim weighs 3670 lbs with a half tank of fuel and no driver. This is with full interior and A/C, but everything out of the trunk and Mark VIII aluminum spares with skinny drag tires on the front. The car now has an aluminum block engine and fiberglass hood, but the SVO blower, chassis stiffeners, etc added mass. For comparison, the car weighed 3780 when new.
MikeB
1997 Thunderbird Sport
5.0L-2V NPI S/C
375 RWHP / 416 RWTQ
11.959 @ 117.17 MPH
MikeB is offline
post #118 of 139 (permalink) Old 10-22-2010, 02:02 PM
I probably would stop when you start going over in your head you could save 50 lbs by hacking off a leg.....
I would have thought you'd be lighter!
~Rick
TCCoA Sig
post #119 of 139 (permalink) Old 10-22-2010, 02:28 PM
or a gallbladder, or pancreas (sp), etc
post #120 of 139 (permalink) Old 12-11-2010, 10:13 PM
Ballenxj's Avatar
It sure could.
Has anybody managed to get close to, or under 3000 lbs with their Tbird?
-Bruce
Ballenxj is offline
