Slimming your car down - Page 5 - TCCoA Forums
 1Likes
post #121 of 141 (permalink) Old 12-11-2010, 10:16 PM
Slightly Disjointed
The guy you quoted does
post #122 of 141 (permalink) Old 12-11-2010, 10:22 PM
Stock 94-97 passenger side airbag - 12 lbs.
That's the only thing I've weighed lately.
rodsv6cougar@cs.com
post #123 of 141 (permalink) Old 12-13-2010, 08:49 AM
Originally Posted by Ballenxj View Post
It sure could.
Has anybody managed to get close to, or under 3000 lbs with their Tbird?
-Bruce
by the scale at the track, I was 2,960 lbs with me out of the car.
I'm hoping to be around 2750-2800 car weight when I go back....that will have an 8 point roll bar with it.
post #124 of 141 (permalink) Old 12-13-2010, 10:14 AM
Ballenxj's Avatar
That's impressive for a Thunderbird.
I had a Chevy Vega many years ago that had a 327, turbo 350 trans, and a 10 bolt differential. If memory serves, it was somewhere in the neighborhood of sub 2800 lbs.
-Bruce
Ballenxj is offline
post #125 of 141 (permalink) Old 12-13-2010, 02:01 PM
Slightly Disjointed
The squib is actually removable from that airbag, and it's a little more than half the weight of the assembly. Not that I recommend removing it
post #126 of 141 (permalink) Old 12-13-2010, 03:20 PM
squib?
when I had mine removed, I just cut the front cover of the bag off, and attatched that back to the dash.....
which does me no good now, as I don't run the stock dash anymore.
post #127 of 141 (permalink) Old 12-13-2010, 03:29 PM
Slightly Disjointed
The part that explodes
post #128 of 141 (permalink) Old 12-13-2010, 04:19 PM
oh.....hmm, that reminds me....I need to go blow something up!
post #129 of 141 (permalink) Old 12-13-2010, 05:32 PM
Why do you think I was weighing it?
My "airbag" only weighs 2 1/2 lbs now.
rodsv6cougar@cs.com
post #130 of 141 (permalink) Old 12-13-2010, 06:58 PM
Roadrunnner's Avatar
Video?
Will
Roadrunnner is offline
post #131 of 141 (permalink) Old 12-14-2010, 02:41 AM
55f350's Avatar
video only if it's new gm products aka camaro and vette's being blown into many little pieces ................................ just to ruffle a few peeps feather's !!!!!!!!!!!!!!!
i used to think i knew a lot , now with the trials and tribulations with the old and the modern i have i realize .... I DON'T KNOW JACK SH-- !!!!!!!!!!!!!!!!!!!!!!!!!!
55f350 is offline
post #132 of 141 (permalink) Old 02-01-2011, 08:40 PM
S4gunn's Avatar
For reference,
the stock tbird (non-sport) calipers + brackets = 12.125LB
I just measured them today.
The PBR calipers+brackets are significantly lighter but I forgot to weigh them before I put them on the car.
Online, I see a reference that each PBR caliper, loaded, weighs 10.4LBs. No mention of the bracket though...
-g
S4gunn is offline
post #133 of 141 (permalink) Old 02-01-2011, 08:56 PM
Miakehl's Avatar
Is there anywhere I can find some info on the tubular k members for our cars? The only post I can find is from 2004.
1994 Ford Thunderbird LX - 120xxx Mi
3.8L of leaking fury
1995 Ford Thunderbird LX - 108xxx Mi
Stock 4.6
Miakehl is offline
post #134 of 141 (permalink) Old 02-02-2011, 07:01 AM
High-Mileage 4.6L Thrasher
Johnny Langton's Avatar
The only tubular k members ever made for a Tbird are garbage. Poor fitament, very little weight savings over a factory piece, and less strength that stock.
JL
1997 Thunderbird-4.6L/4R70W.....12.16@111.77
2010 Lincoln MKT-3.5L EcoBoost V6/AWD....14.41@96.27-stone stock
Fuelly
Johnny Langton is offline
post #135 of 141 (permalink) Old 03-06-2011, 12:03 AM Thread Starter
shaken, not stirred
stangboy7's Avatar
Anyone have any WHEEL weights other than the stated Lincoln LS rims of 14.4 lbs
C.Hill
'97 Laser Red T-bird w/ Option 66S - 125,000 miles, stock except for 3.73s Best ET 15.6 @ 88.3
'94 Electric Red T-bird LX V-8- 212,000 miles- SOLD
2005 Ebony Black Excursion Limited 6.0 Diesel STUDDED
"Thinking is the hardest work there is, which is the probable reason so few engage in it."
- Henry Ford
"Opportunity is missed by most people because it is dressed in overalls and looks like work."
- Thomas A. Edison
http://www.tailofthedragon.com <---- A test of driving ability and nerves.
stangboy7 is offline
post #136 of 141 (permalink) Old 04-03-2011, 01:58 PM
S4gunn's Avatar
I keep finding other random stuff to remove off the track car.
For example, this morning I pulled off the cruise control servo and all the associated wires.
Cruise Control Servo Weight (including throttle cable and the vacuum hose that goes from the servo to the driver's compartment - I believe to the brake pedal): 3.7LB.
All I need to add was a vacuum cap to the "T" next to the brake booster.
-g
S4gunn is offline
post #137 of 141 (permalink) Old 12-17-2011, 02:47 AM
S4gunn's Avatar
More items:
Blower motor (not including assembly): 14.3LB
Driver and Passenger Door Windows (each): 9.9LB
Rear Side Windows w/ frame (each): 5.7LB
Rubber Door Molding surrounding door sill (each): 3.95LB
Front Fender Liner (each): 3.3LB
Center Console (w/ armrest): 7.9LB
Subjective:
Weight removable by skinning hood from a 94-95 car: 14.6LB YMMV
Weight removable by cutting out spare wire well: 7.9LB YMMV (you will likely want to/need to put something over hole)
S4gunn is offline
post #138 of 141 (permalink) Old 12-17-2011, 08:18 AM
tbirdtess's Avatar
Weight removable by cutting out spare wire well: -7.9LB YMMV (you will likely want to/need to put something over hole)
Well I have my fuel cell in that hole.
Paul Nm12tbirdracer@aol.com
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #139 of 141 (permalink) Old 12-19-2011, 11:41 AM
S4gunn's Avatar
More items:
Power Window Motor & scissor frame assembly: 6.6LB/each
Rear Window Trim (all 4 pieces): 2LB
Door window guides (front and rear set, per door): 4.1LB
Subjective (YMMV):
Skin off Passenger Door (where the speaker & interior door release attach. Not including brace): 10.4LB
Most wire for HVAC, all door-mounted controls, Speakers, Rear amp, domelight -- separated out of wiring harnesses and cut at the ground point, fuse box, patch panel, and/or engine bay connector: 8.8LB
S4gunn is offline
post #140 of 141 (permalink) Old 05-01-2017, 06:42 PM
Wile E. Coyote Jr.'s Avatar
So I was looking at the fiberglass pieces listed in the first page of this thread, but I only see trunk lids for 89-93s that had the full back tail lights. I also spent some time on google but came up empty. Does anyone know where to get a 94-97 style fiberglass trunk lid or would I have to make my own?
Lurking
Wile E. Coyote Jr. is offline
post #141 of 141 (permalink) Old 05-01-2017, 07:10 PM
Slightly Disjointed
The latter.
