Slimming your car down - TCCoA Forums
 1Likes
post #1 of 139 (permalink) Old 10-27-2007, 07:44 PM Thread Starter
shaken, not stirred
stangboy7's Avatar
I have been reading several different websites and compiling information that was consistantly reported. If I was leary about the information I didn't use it. I originally was searching for my own purposes and realized there wasn't really a one stop place for all this information, so I decided to do something for my community. If there is any major discrepencies please let me know and I will adjust. Also I am sure there is some things I have missed or couldn't find, so I would appreciate that information as well.
Spare Tires
-Stock steel T-Bird doughnut 27lbs
-Mark 8 alluminum spare 18lbs
-Mark 8 alluminum spare WITHOUT Tyre 10lbs
Drive Shaft
-Stock T-bird/Cougar driveshaft 21.5lbs
-Mark 8 Driveshaft 14lbs
Differential
-Stock Iron T-bird/Cougar 3.27 trac lock pumpkin 80lbs
-FRPP 3.73 trac lock pumpkin 62lbs
Engines
-Explorer/Mountaineer complete aluminum 4.6 100lbs lighter
-96+ Romeo iron blocks: 154lbs, fully assembled 500lbs
-96-99 cobra / 93-98 mark 8 Teksid block: 85.40lbs, fully assembled 425lbs
-2001+ WAP block (NA Cobra) 80.40lbs
-Early cast crank = 46lbs (93 and 97 tested)
-Late cast crank = 44lbs (2002 tested)
-2V heads = 46lbs each
-4V B Heads = 60lbs each
-2V Plastic PI Intake = 12lbs
-2V Bullitt Intake = 37lbs
-Cast iron flywheel = 21lbs
-Spec Aluminum dual pattern flywheel = 12lbs
Doors
-Stock T-bird door 70lbs
-Fiberglass T-bird door 17lbs
Battery
-Stock T-Bird/Cougar 48lbs
-Optima Red Top 33lbs
-Odessey battery 12lbs
Hood
-Stock Hood 58lbs
-Fiberglass Hairyglass hood 18lbs
Trunk lid
-Stock T-bird deck lid 37lbs
-Fiberglass Hairyglass deck lid 9lbs
Lower Rear Control A-arms
-Stock A arms 27lbs (each side)
-Aluminum A arms 14lbs (each side)
Seats
-Electric Seats w/leather 56lbs
-Manual Cloth 30lbs
Engine Cradle
-Stock MN12 cradle ***lbs
-Tubular cradle ***lbs
Brake Calipers (unloaded)
-Stock Front non-sport 8.75 lbs (each side)
-Stcok Front Sport 8.3 lbs (each side)
-Stock Rear Sport and non-sport 9.2 lbs (each side)
-PBR GT Front 10.4 lbs (each side)
-Brembo Cobra R Front 8.4 lbs (each side)
Brake Rotors
-Stock Front non-sport 15.7 lbs (each side)
-Stock Front Sport 17.5 lbs (each side)
-Stock Rear Sport and non-sport 9.6 lbs (each side)
-Brembo GT Front Slotted/Vented 15 lbs (each side)
-Brembo 13” Front Slotted/Vented 18.6 lbs (each side)
C.Hill
'97 Laser Red T-bird w/ Option 66S - 125,000 miles, stock except for 3.73s Best ET 15.6 @ 88.3
'94 Electric Red T-bird LX V-8- 212,000 miles- SOLD
2005 Ebony Black Excursion Limited 6.0 Diesel STUDDED
"Thinking is the hardest work there is, which is the probable reason so few engage in it."
- Henry Ford
"Opportunity is missed by most people because it is dressed in overalls and looks like work."
- Thomas A. Edison
http://www.tailofthedragon.com <---- A test of driving ability and nerves.
stangboy7 is offline
post #2 of 139 (permalink) Old 10-27-2007, 10:00 PM
Slightly Disjointed
some of those numbers dont sound right, and the cradle is nowhere near 250, in fact the tubular one listed would weigh more than the actual stock one
post #3 of 139 (permalink) Old 10-28-2007, 12:46 AM Thread Starter
shaken, not stirred
stangboy7's Avatar
Untill verified, I will take it out. Thanks.
C.Hill
- Henry Ford
- Thomas A. Edison
post #4 of 139 (permalink) Old 10-28-2007, 02:43 AM
Fry Rice Specialist
Casper's Avatar
i believe stock mn12 angine cradle without suspension just bare cradle is about 50-60 lbs.
CarDomain Page
Casper is offline
post #5 of 139 (permalink) Old 10-28-2007, 04:36 PM
The stock front K-member, with the LCA's and strut rods still attached weighs 82 lbs.
-Rod
rodsv6cougar@cs.com
racecougar is online now
post #6 of 139 (permalink) Old 11-13-2007, 01:57 AM
Are those arms an economical weight loss with the cost of those spring perches that are custom parts? I have thought about buying them though, but the cost of the spring perches seems prohibitive.
post #7 of 139 (permalink) Old 11-13-2007, 08:34 AM
High-Mileage 4.6L Thrasher
Johnny Langton's Avatar
A stock ''94-'95 model hood is 74 lbs,and the '96-'97 is 75lbs. Both measured without the hood liner.
JL
1997 Thunderbird-4.6L/4R70W.....12.16@111.77
2010 Lincoln MKT-3.5L EcoBoost V6/AWD....14.41@96.27-stone stock
Fuelly
Johnny Langton is offline
post #8 of 139 (permalink) Old 11-13-2007, 08:37 AM
In time, I can get you the weight of the stock spring/shock combo, and the weight of the QA1 coilover combo.
post #9 of 139 (permalink) Old 11-13-2007, 08:00 PM
Slightly Disjointed
sometime this week i'll have the seat tracks out of my car, i'll try to weigh the electric and manual one
honestly i dont see it being more than 5-10lbs, i held a both types on each arm, wasnt much difference
post #10 of 139 (permalink) Old 11-13-2007, 09:28 PM
sCrEaMiN BiRd's Avatar
Where would one get the "aluminum a-arms"?
sCrEaMiN BiRd is offline
post #11 of 139 (permalink) Old 11-13-2007, 09:30 PM
Slightly Disjointed
mark VIII
post #12 of 139 (permalink) Old 11-13-2007, 09:35 PM
JNT
JNT's Avatar
I didn't realize someone was making fiberglass doors and trunk lids.
1997 Thunderbird 4.6L LX
SCT XCAL 2 From Lonnie, 02 Mustang MAF and air box, Dynomax Cat Back Exhaust, Steeda U/D Pulleys, 70MM FRPP TB, Dual Piston Calipers, KVR Rotors, Alpine CD, Polk Speakers
1994 Thunderbird SC (Needs Work)
1996 Bronco XL
2003 Escort ZX2
1996 Bronco XLT Sport
Mid Atlantic MN12 www.mamn12.com
Project Cars: 69 Lincoln Continental, 81 Ford Thunderbird
post #13 of 139 (permalink) Old 11-13-2007, 09:35 PM
mark VIII
what year? 93?
post #14 of 139 (permalink) Old 11-13-2007, 09:39 PM
coggonobrien's Avatar
all of them
coggonobrien is offline
post #15 of 139 (permalink) Old 11-13-2007, 10:32 PM
Refrigerator Raider Hater
GreenBird's Avatar
rear lower control arms, stock and mark 8?
two piece rotors (aluminum hat)?
forged aluminum wheels?
manual steering rack (no more pump)?
removing front and rear bumpers (metal)?
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #16 of 139 (permalink) Old 11-13-2007, 11:38 PM
Are the stock fan blades heavy?
post #17 of 139 (permalink) Old 11-14-2007, 01:06 AM
Originally Posted by coggonobrien View Post
all of them
Thank you!
post #18 of 139 (permalink) Old 11-14-2007, 10:40 AM
BlackbirdSport's Avatar
Send a message via AIM to BlackbirdSport
Anyone want to venture a guess at what the whole of the dash assembly weighs? Unfortunately, I took mine out in peices with cutting tools. I should have wighed it. I would guess that it's a 100lb unit.
Also intesting to see would be fold-down vs regualr rear seats, exhaust systems, sound systems, carpets and plastic, etc.
I dont suppose anyone was diligent enough to collect all of the sound deadener and weigh it? Mine was mostly turned to dust.
"Keep making it thinner until it breaks, then go one size bigger."
My Cougar XR7
BlackbirdSport is offline
post #19 of 139 (permalink) Old 11-14-2007, 10:58 AM
no......my stock fan blades with et drags weigh as much as my brothers weld drag lites with 275/50/15's drag radials.
post #20 of 139 (permalink) Old 11-14-2007, 11:00 AM
I'm in the process of taking out all the sound deadener, by heating it up and scraping it out....I'm throwing it all into a box, and will weigh it when done.
Also, the dash is not a 100 lbs....I my self can take the dash in and out of the car myself, if it was a 100lbs, I don't think I could.
post #21 of 139 (permalink) Old 11-14-2007, 11:26 AM
Not just the structure, though. Does yours have all of the HVAC and stereo stuff in it? You may still be right. Weigh it if you can, I'd be interested to confirm.
If my fuzzy math is right, I should be under 3000lb once the glass is replaced with Lexan....not counting the weight of the cage.
My Cougar XR7
post #22 of 139 (permalink) Old 11-14-2007, 12:16 PM
thats without the stereo/airbag/vents/glovebox.....so you might be right then....
The weight is great!
Same here though, I'm hoping to be under 3000 myself, but that with all the glass, stock hood, cast iron heads and intake....but no cage, yet
Last time it was 3080 with me out of the car, and since then, I've done a bunch more weight removal..
post #23 of 139 (permalink) Old 11-14-2007, 12:23 PM
Do tell!? I need to weigh mine, I've taken all of the big crap out, everything the car doesn't need to go and stop. Maybe I'm better off than I thought.
My Cougar XR7
post #24 of 139 (permalink) Old 11-14-2007, 12:36 PM
well, recently, I've been dissecting all the unnecessary wires...I'm gutting the doors, taking out all the power window crap, cutting the inner door material out, removing all power lock stuff....replacing the inside door skin with very thin sheet metal...beleive it or not, the wiring in the car adds up a ton, but since its a track only car, and carbed, I can take out a bunch of wires I don't need....only wires that are going to be left are for lights, brakes and blinkers(in case I drive down the road for a bit).
I'm removing all the sound deadening, cutting away unnecessary panels(like where the rear side speakers mount), I know its not a whole lot of weight, but it adds up over time.
I'm probably not removing as much weight as I'm thinking, its just very time consuming, and it feels like it should be more than I'm doing.
I'm also moving my battery back up front with a lighter weight one, and taking out the huge 1/0 power cable I had running from front to back.
hope this helps, as I'm sure you've done most of this already...
post #25 of 139 (permalink) Old 11-14-2007, 12:58 PM
I've done all of that. I searched back and read some of your stuff, and I'm thinking I've removed more at this point than you have. You've gotten me very optimistic about my weight. You've removed some suspension stuff that I still need, though.
I wasn't careful with my wires....as a result I not only took out 15lb of wire, but also my 50lb TEVES braking system. I ate the harness and fudged the system. Rather than try to rewire, I just went with a booster and master cylinder. The TEVES ABS unit is a PIG!
My Cougar XR7
post #26 of 139 (permalink) Old 11-14-2007, 03:56 PM
Pedal Faster
Josh_Keady's Avatar
Anyone weigh the Tbird badge vs. the Cougar badge? /smarta$$
Nice list, though. The steel spare really weighs 27 lbs?
Josh Keady
Josh_Keady is offline
post #27 of 139 (permalink) Old 11-14-2007, 04:49 PM
thunderbird96's Avatar
Send a message via AIM to thunderbird96 Send a message via MSN to thunderbird96 Send a message via Yahoo to thunderbird96
the stock 96 hood was 60 pounds and my cobra r hood was 30
thunderbird96 is offline
post #28 of 139 (permalink) Old 11-15-2007, 06:45 PM
Battery's Avatar
Send a message via AIM to Battery
Does anyone know the actual weight on these?
"It's all in the reflexes"
LE RIP
Now 96 Mark VIII
Battery is offline
post #29 of 139 (permalink) Old 11-15-2007, 06:47 PM
Slightly Disjointed
cougar badge is lighter
post #30 of 139 (permalink) Old 11-15-2007, 10:44 PM
Send a message via AIM to tstats
so who makes fiber glass trunk lids
tstats is offline
