More weight removal. - Page 5 - TCCoA Forums
post #121 of 760 (permalink) Old 02-23-2009, 07:53 PM Thread Starter
Update with pics....
Some pics of welding I have been doing along the way..
post #122 of 760 (permalink) Old 02-23-2009, 07:55 PM Thread Starter
Engine back out....
How my car looks right now
post #123 of 760 (permalink) Old 02-23-2009, 08:06 PM
SuperNewbie
supergordo's Avatar
Whats your goal for doing all the seam welding? Strength? Noise? Just curious.
1995 Cougar XR7 4.6
1997 Thunderbird LX 4.6
1977 Country Squire 460
1985 Capri RS 5.0, 5spd
1997 Thunderbird 4.6
1984 Capri RS 5.0,5spd
supergordo is offline
post #124 of 760 (permalink) Old 02-23-2009, 08:07 PM Thread Starter
Forgot to add, I'm about to drop the whole rear assembly as well.....its about to be a shell.
strength mostly.....most of the interior welding will be dressed up to look better.
post #125 of 760 (permalink) Old 02-23-2009, 08:13 PM
rbrown's Avatar
I know why the right side wasn't cathing on fire like the left......I didn't weld up 1 seam on the right side like I did on the left.....sooooo, I need you to come by again today and watch that side so I don't have to keep getting out and putting the fire out.
btw, I got the roof all welded up too, along with the dash....I finally started on the back end.
And I also started grinding in the front wheel well.
Go get you some disposable diapers, use the stuff inside to make a paste. Really cuts down on the fires and what areas get scorched and burned. Protects paint pretty well on surrounding areas too.
rbrown is offline
post #126 of 760 (permalink) Old 02-23-2009, 08:22 PM Thread Starter
post #127 of 760 (permalink) Old 02-23-2009, 09:12 PM
SuperNewbie
supergordo's Avatar
Are you going to seam weld the subframe?
1995 Cougar XR7 4.6
post #128 of 760 (permalink) Old 02-23-2009, 09:24 PM Thread Starter
More than likely....I would like to find some aluminum rear lowers as well.....maybe even an aluminum pumpkin...
post #129 of 760 (permalink) Old 02-23-2009, 09:25 PM
rbrown's Avatar
I'm serious.
I made me some a while back to protect some areas where I was using a flame and it kept all the paint underneath nice and purdy.
rbrown is offline
post #130 of 760 (permalink) Old 02-23-2009, 09:29 PM Thread Starter
I'm serious.
I know you were
I haven't needed that yet though....but I will keep it in mind......
.....what was cathing on fire was the foam crap that is still in the fenderwells...that sh1t stinks when it burns!
post #131 of 760 (permalink) Old 02-23-2009, 09:40 PM
SuperNewbie
supergordo's Avatar
Im getting ready to weld and detail my subframe and K member. I already have the aluminum pumpkin. I haven't bought the LCA's yet, though I do have the spring perches on the shelf for them.
1995 Cougar XR7 4.6
post #132 of 760 (permalink) Old 02-23-2009, 09:41 PM Thread Starter
cool.....maybe you can send me some dimensions of those perches....should be easy enough to make..
post #133 of 760 (permalink) Old 02-23-2009, 10:12 PM
SuperNewbie
supergordo's Avatar
Yeah thats no big deal
1995 Cougar XR7 4.6
post #134 of 760 (permalink) Old 02-27-2009, 10:11 AM Thread Starter
Roll bar is on order.
post #135 of 760 (permalink) Old 02-27-2009, 10:21 AM
rbrown's Avatar
Shouldn't this be in the "Weight added" thread?
rbrown is offline
post #136 of 760 (permalink) Old 02-27-2009, 10:43 AM Thread Starter
yep
post #137 of 760 (permalink) Old 02-27-2009, 11:55 AM
Yeah, right alongside the 10lbs of welding wire that is now melted into his car.
post #138 of 760 (permalink) Old 02-27-2009, 11:57 AM Thread Starter
its only about 4 lbs right now...
guys, when I started this thread, I didn't know I was going to get this far into it....so, its just a "build" thread now.
post #139 of 760 (permalink) Old 02-27-2009, 11:59 AM
Custom User Title
Im in the same boat here .. got a couple subframes on the side of the house for welding, one of them is complete from a Mark with control arms and everything .. just need perches to top it off.
I dont know about pulling apart diapers .. thats not fire retardant, its a water absorbant; but hey I have plenty here. Plus I cant imagine that stuff would be good to breath while welding. That body sealer really can be a pain to work with .. I always keep a fire extinguisher handy while welding - got 3 of them in my garage.
dDUBb is offline
post #140 of 760 (permalink) Old 02-27-2009, 12:04 PM Thread Starter
I've got a few too....a couple Halon ones as well
(I work as a building engineer, and every year, an extinguisher either needs replaced or something..so I get as many as I want)
and you're right...that crap stinks to high heaven!!!
my wife used to complain when I would rebuild a diff or whatever, but now, holy crap...this stuff just stinks when its heated!
post #141 of 760 (permalink) Old 02-27-2009, 12:08 PM
Custom User Title
I have one of those also, but all the rest are ABC. My buddy was a fire inspector, so thats why I have so many also.
They used to get recharged once a year, but not anymore .. luckily I havent had to use one yet.
dDUBb is offline
post #142 of 760 (permalink) Old 02-27-2009, 12:09 PM Thread Starter
sounds like the same boat as me!!
free stuff is great!
post #143 of 760 (permalink) Old 02-27-2009, 12:24 PM
Custom User Title
LOL no kidding .. even better when your buddies leave tools like a Lincoln Powermig 215 and some more goodies in your garage. Plasma cutter comes in handy.
dDUBb is offline
post #144 of 760 (permalink) Old 02-27-2009, 12:28 PM Thread Starter
damn, I wish I had a plasma cutter right now....would make things so much faster.
post #145 of 760 (permalink) Old 02-27-2009, 01:07 PM
SuperNewbie
supergordo's Avatar
Don't we all want plasma cutters?? Useful buggers they are!
1995 Cougar XR7 4.6
post #146 of 760 (permalink) Old 03-06-2009, 06:54 PM Thread Starter
Here are a few quick pics....gotta run and make some side money to pay for this crap!
and my monkey cage..
post #147 of 760 (permalink) Old 03-06-2009, 10:08 PM
tbirdtess's Avatar
Cage?
Hello
Who did you buy the cage from?
Mine came from CSC.
I cut my front bumper in half. kept the top, removed the bottom.
Paul
Paul Nm12tbirdracer@aol.com
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #148 of 760 (permalink) Old 03-06-2009, 11:45 PM Thread Starter
It came from S&W racecars.
post #149 of 760 (permalink) Old 03-19-2009, 07:49 AM Thread Starter
Originally Posted by MC94XR7 View Post
i guess its too late now but what about structural adhesive that the air craft industry uses instead of mig? anyone work with that stuff?
nah, if I was to use that, I wouldn't have done any of this.
update on the car, I've got almost the whole left side under the hood welded up....also the core supprt is getting a makeover as well....I have still yet to start the roll bar, but I should be starting on it this weekend...I needed a few more tools and an nhra rule book.
I'll post some progress pics later.
post #150 of 760 (permalink) Old 03-24-2009, 09:08 PM Thread Starter
lots more welding!
smoothing some things out to see how it looks...
changing the look of the core support some..
not much bumper left....I might actualy remove the whole front piece, and make something a little closer to the engine bay..
anyway, lots to do still.
