More weight removal. - Page 7 - TCCoA Forums
post #181 of 760 (permalink) Old 04-19-2009, 10:02 PM
Slightly Disjointed
Its structural, I doubt he would spend all that time seam welding welding the whole car just to take out the main part connecting the subframe.
post #182 of 760 (permalink) Old 04-19-2009, 10:22 PM Thread Starter
Correct me if I'm wrong... but from what I've seen lately it looks like you're basically done modifying the car - have removed basically all the extra stuff from it that's going to be removed and done the welding and such - and are getting things ready to put back together?
Or is that a bit premature. I recall you wanted to work on the bumpers a bit and do something with a belly pan... not to mention the roll cage.
I guess you can say I'm about half way there now.
I still have a few seams to weld under the hood(these are getting welded mostly for the smoothing of the engine bay), and a lot of grinding to follow.
I still need to scrape the sound deadening from the bottom of the car and in the fenderwells, and paint all that too.
I still have half the subframe connectors to do(forgot to post pics of that).
And of course the roll bar. Then the paint inside.
Also the paint under the hood.
Then(I thought I was getting done too), I have heads to do a port job on, maybe rebuild the shortblock, and reasemble the motor.
I'm on the market for a C4 tranny, and a decent stall.
Oh yeah, I still have some of the dash to finish, rewire the car.....
okay, maybe not half way there yet...
Originally Posted by kustomizingkid View Post
Why don't you just cut off the whole front bumper brace/Impact Absorber crap....
I have given it some thought.....I have a real good idea about removing it and replacing it with something a few pounds lighter.
post #183 of 760 (permalink) Old 04-20-2009, 01:02 AM
Zero_Profile's Avatar
man this thing is a **** load of work, its looking awesome though
97 Ford Thunderbird LX
76 Ford F150 Custom
01 Ford Diesel Excursion
My soon to be completed Bird
Zero_Profile is offline
post #184 of 760 (permalink) Old 04-20-2009, 09:47 AM
rbrown's Avatar
And how much **** talking do you see me do?
And so what.....I started this last project I'm currently on in October last year....this stuff takes time.
No I'm messing. You know that.
85% of this is the journey. And you are on your journey.
91 Festiva 1.3L baby 5 speed
10 Flex Brick Twin Turbos
*Rodney*
rbrown is offline
post #185 of 760 (permalink) Old 04-20-2009, 10:08 AM
"Genius is one percent inspiration and ninety-nine percent perspiration." - Thomas Edison
This is the perspiration part.
97 Laser Red Thunderbird LX 155k, Stage 2 4.6L 2v N/A | 300 BHP (255 RWHP, 290 RWTQ) | 13.95 @ 97.58 | Build details | Pics at the Lorain Assembly plant
96 Ivory Mark VIII 233k, stock 4.6 32v on coils; New engine at 185k
post #186 of 760 (permalink) Old 04-20-2009, 10:25 AM Thread Starter
I thought you were.....Hey, did you ever sell that 83 f150?
tell me about it!
post #187 of 760 (permalink) Old 04-22-2009, 11:24 AM Thread Starter
I got 1 SFC done...it weighs in right at 9 lbs for 1 side....not to bad.
So, with the roll bar and SFC's I will be adding about 110 lbs back on the car.
I have hopefully removed at least that much weight this time around.
If I can find a C4, that alone will offset the weight of the sfc's and the roll bar, when compared to the C6 I run now.
I found the link I was looking for on this....
http://www.stangcrazy.com/forums/showthread.php?t=3367
This is what I plan on doing.
post #188 of 760 (permalink) Old 04-22-2009, 03:13 PM
I probably should have explained better.... but it seems like an understanding has been met.
kustomizingkid is offline
post #189 of 760 (permalink) Old 04-22-2009, 04:43 PM
quikbird's Avatar
that looks good, that's what i plan on doing, but i was going to use square metal. 95 "one"badbird Since you drag race the car "i guess" only have thought about making a tube k-member? i have seen the AJE k member it doesn't look too difficult to make?!someone over sccoa was making one that uses the factory lower arm and strut rod. Just a thought
Edit: And your seam welding look great i might have to do the same
quikbird is offline
post #190 of 760 (permalink) Old 04-22-2009, 05:08 PM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
*waits for nick to raise hell*
2014 GT
1990 300ZX TT
big mike is offline
post #191 of 760 (permalink) Old 04-22-2009, 06:52 PM
I have never heard much good about those tubular K frames... lots of fit and finish issues from what I read...
post #192 of 760 (permalink) Old 04-22-2009, 07:52 PM
quikbird's Avatar
oh boy, which part the tube k member in general or the AJE piece, which by the way im not saying get one. If one was to build a k member to there car it would fit and be as strong as one needs it. in drag racing it doesn't have to be strong on lateral load or does it? Im going to look for that pic of someone building thers
quikbird is offline
post #193 of 760 (permalink) Old 04-22-2009, 08:00 PM
rbrown's Avatar
Yes. To someone in Splendora. Funny story I will have to tell you sometime. Maybe at the May track meet.
Big Mike sold one not too long ago.
*Rodney*
rbrown is offline
post #194 of 760 (permalink) Old 04-22-2009, 08:47 PM Thread Starter
is what I linked what you had in mind?
When the guy on sccoa gets ready to make em, I'll probably get one built from him.
I lost my chance...I shoulda snagged it!
post #195 of 760 (permalink) Old 04-27-2009, 07:30 PM Thread Starter
Here are the SFC's.
Here is how it starts....just a square tube.
A little cut..
Then welding it...
Then the final grind before welding...
post #196 of 760 (permalink) Old 04-27-2009, 10:39 PM
To a T....
post #197 of 760 (permalink) Old 04-27-2009, 10:45 PM
Clueless Poster
v8_superbirdy's Avatar
Send a message via AIM to v8_superbirdy Send a message via Yahoo to v8_superbirdy
Here are the SFC's.
what's a SFC?
my other ride is an ambulance!
1997 V8 sport - first car - sold 6/7/10
2006 silver mustang gt premiumcustom made grill, frpp shorty headers, pypes cat back exhaust, hurst billet pro shifter,
v8_superbirdy is offline
post #198 of 760 (permalink) Old 04-27-2009, 10:53 PM
Slightly Disjointed
Sub Frame Connector
post #199 of 760 (permalink) Old 04-27-2009, 10:53 PM
I would wager that SFC's are Sub Frame Connectors
transam396 is offline
post #200 of 760 (permalink) Old 04-27-2009, 11:24 PM
Clueless Poster
oh ok. makes sence now.
post #201 of 760 (permalink) Old 04-28-2009, 03:47 PM Thread Starter
yeah, sub frame connectors.....they will get fully welded to the car.
The rear part of them will get an extra plate where it meets the rear subframe.
Also, where the connectors make their bend, there will be another crossbar that gets put in place as well.
Not sure if I'm going to weld that piece in, or just bolt it in...
post #202 of 760 (permalink) Old 04-28-2009, 03:55 PM
Motorboatin' SOB
big mike's Avatar
next time, you will lift your skirt and pull that trigger!
2014 GT
1990 300ZX TT
big mike is offline
post #203 of 760 (permalink) Old 04-28-2009, 03:57 PM
If you don't have a stock gas tank there is ass loads of room for SFC's...
post #204 of 760 (permalink) Old 04-28-2009, 07:43 PM Thread Starter
I certainly hope the ones on sccoa start production soon.
post #205 of 760 (permalink) Old 04-28-2009, 08:16 PM
MikeyB's Avatar
Looks good!
95 Cougar XR-7
Sold it...
96 Thunderbird LX
Sold it...
MikeyB is offline
post #206 of 760 (permalink) Old 04-28-2009, 08:52 PM Thread Starter
Originally Posted by MikeyB View Post
Looks good!
thanks
post #207 of 760 (permalink) Old 04-28-2009, 09:12 PM
MikeyB's Avatar
I dont know if its been asked but what brand welder are you using? jw
95 Cougar XR-7
Sold it...
96 Thunderbird LX
Sold it...
MikeyB is offline
post #208 of 760 (permalink) Old 04-28-2009, 09:35 PM Thread Starter
I have 3.
But the one I've been using the most is a Mac tools brand.
Its pretty old, but gets the job done.
And some of the welding was done with this as well.
post #209 of 760 (permalink) Old 04-28-2009, 09:36 PM Thread Starter
yes sir!
post #210 of 760 (permalink) Old 04-28-2009, 09:43 PM
MikeyB's Avatar
Good deal, I cant wait to see the sfc's done. I need to do something about the ones on my car.
95 Cougar XR-7
Sold it...
96 Thunderbird LX
Sold it...
MikeyB is offline
