More weight removal. - Page 9 - TCCoA Forums
post #241 of 760 (permalink) Old 10-10-2009, 03:52 PM Thread Starter
Got a little work done today.
Went ahead and did a little more weight removal up front...
A little plate...
About a 3 foot tube...
Caught some pretty cool pics of the welding..
post #242 of 760 (permalink) Old 10-10-2009, 03:53 PM Thread Starter
Finished bumper...
About done with the subframes..
post #243 of 760 (permalink) Old 10-10-2009, 05:26 PM Thread Starter
I forgot to say the what the weight loss was.
The bumper(what was left of it) weighed 18 pounds after I cut it off.
I put back on 8 lbs.
So this was 10 less for me. woohoo!
post #244 of 760 (permalink) Old 10-10-2009, 05:56 PM
I'm still dying to find out what the scales will tip in at if you finish when you finish this lil' project.
97 Laser Red Thunderbird LX 155k, Stage 2 4.6L 2v N/A | 300 BHP (255 RWHP, 290 RWTQ) | 13.95 @ 97.58 | Build details | Pics at the Lorain Assembly plant
96 Ivory Mark VIII 233k, stock 4.6 32v on coils; New engine at 185k
post #245 of 760 (permalink) Old 10-13-2009, 03:22 PM Thread Starter
this was supposed to be a lil project
but, it never turns out that way.
I'm hoping to be under 3,000 lbs. race weight with driver.
If I didn't put the cage in, it would be around 2900 race weight.
post #246 of 760 (permalink) Old 10-30-2009, 11:52 AM Thread Starter
can anyone tell me, has the rules changed from 08 till now on roll bar placement? Like the distance between the helmet of the driver to the bar itself?
and what about seat mounting? has anything changed in that area as well?
post #247 of 760 (permalink) Old 10-30-2009, 12:31 PM Thread Starter
Originally Posted by MC94XR7 View Post
lookin good, man. but those welds. they look like the one i did for my exhaust.lol. you running any argon or flux core?
stick welder brotha!
and who cares how they look.....the stuff will hold just fine
edit: which ones?
the ones for the bumper are arc welding, the sfc are from my mig(with gas, argon and co2)...I'm having to fill the gap that I cut to big on the floor.
This will be grinded back down for a smoother look.
post #248 of 760 (permalink) Old 10-30-2009, 02:52 PM Thread Starter
right on. as long as you got penetration.
definetly.....I wouldn't be doing this if I didn't trust my welding.
post #249 of 760 (permalink) Old 11-25-2009, 03:44 PM
392Bird's Avatar
Did you ever check the weight difference between rear drum and rear disk brakes? I was going to when I did mine, but forgot to weigh them both before I swaped it. I just completed doing the brake swap, and Mark 8 lower control arms.
-----1993 Bird 5.0------
295/45/17 MT DR on the rear
Click for Full Project
392Bird is offline
post #250 of 760 (permalink) Old 11-25-2009, 03:52 PM
RCReevesPhotography's Avatar
Getting better..
"Dream like you will live forever, live like you will die today"
RCReevesPhotography is offline
post #251 of 760 (permalink) Old 11-30-2009, 08:39 AM Thread Starter
As of right now, the stock brakes are staying.
When I do swap to rear discs, I'll hopefully be swaping to a solid rear settup.
post #252 of 760 (permalink) Old 11-30-2009, 09:11 PM
95SilverBird's Avatar
Solid rear axle? I have searched for that topic before without many results. If you dont mind me asking, what rearend do you plan on using and how hard do you think it will be to swap it in?
95SilverBird is offline
post #253 of 760 (permalink) Old 11-30-2009, 11:17 PM
rbrown's Avatar
He is using the 10.25 rear out of my truck.
rbrown is offline
post #254 of 760 (permalink) Old 12-01-2009, 02:23 AM
55f350's Avatar
the solid rear axle swap has crossed my mind a couple of times now . just in appearance a solid 8.8 or 9 inch and ladder bars and coil overs appear to be a lot lighter , and to my feeble old mind would be much easier to setup and do what i'm thinking . ................... there isn't too many places to cut high speed corners around here , and or high speed driving , but a couple of drag strips within an hour or two ....................... got an 8.8 and 9 inches here . the 8.8 is from a police package 87 crown vic and was at one time going in my 53 but .... it looks to be the right width without any mods . still haven't really measured it , but if memory recalls it's 55 inches from backing plate to backing plate .
55f350 is offline
post #255 of 760 (permalink) Old 12-01-2009, 07:14 AM Thread Starter
a couple of guys on sccoa have done the rear solid settup.
I want to use an 8.8 center with 9" axle tubes.
post #256 of 760 (permalink) Old 12-10-2009, 02:07 PM Thread Starter
anyone?
and also, anything change about the front firewall?
post #257 of 760 (permalink) Old 12-10-2009, 02:16 PM
Banned
There is a way we can probably tell right now, but it will take some time. We could essentually weigh everything that has come off the car besides the engine and trans. But, we could take the weight of everything that has come off the car, and subtract from the orginal weight he started with (which I think was 3200) of course adding back in the weight of the engine and trans.
From what I keep calculating in my head, with driver and full race weight (fuel cell, but no cage) I keep coming up with ~2800 lbs with driver.
Originally Posted by RCReevesPhotography View Post
Getting better..
What is he "getting better" at? What can you do?
96gts4.6L is offline
post #258 of 760 (permalink) Old 12-21-2009, 03:27 PM Thread Starter
note to self......don't try and take on 2 project cars at once...
post #259 of 760 (permalink) Old 12-21-2009, 03:37 PM
Slightly Disjointed
What happened? you weld them together?
post #260 of 760 (permalink) Old 12-21-2009, 04:50 PM
rbrown's Avatar
LOL.
Whatsa matter....
I have like 12 so git on it!
can't get any done, shhhhh
rbrown is offline
post #261 of 760 (permalink) Old 12-21-2009, 05:07 PM
Damn havn't seen this thread since I was in Kuwait, niiice job on the "Little" project so far. But now it's time to finish it for crying out loud!
post #262 of 760 (permalink) Old 02-08-2010, 08:28 AM Thread Starter
little update.....well, I'm still up in the air about this.....
But, these might be making their way on my car.
http://www.htownracing.com/forums/sh...ad.php?t=44324
or maybe they have....
post #263 of 760 (permalink) Old 02-08-2010, 08:58 AM
rbrown's Avatar
What a deal. Did you do it?
rbrown is offline
post #264 of 760 (permalink) Old 02-08-2010, 12:51 PM Thread Starter
Still thinking about it.
But more than likely not.
With advice from other's, and some research, these are not going to work for me. Can they work? Sure. But my budget will not allow for it. I overlook things sometimes.
post #265 of 760 (permalink) Old 02-26-2010, 01:13 AM
byrd_of_thunder's Avatar
Send a message via AIM to byrd_of_thunder Send a message via MSN to byrd_of_thunder Send a message via Yahoo to byrd_of_thunder
what kind of coilovers do you have on the front?
Nick
Byrd_of_Thunder
2012 Ford Focus SE Hatchback
**1997 Ford Thunderbird LX - RIP**
byrd_of_thunder is offline
post #266 of 760 (permalink) Old 02-26-2010, 07:56 AM Thread Starter
QA1's 12 way adjustable 90/10 valveing.
currently 325 lb springs.....might need to go lower weight here soon.
post #267 of 760 (permalink) Old 02-26-2010, 01:26 PM
i've seen their website before they have alot of interesting stuff. do they make those coilovers specifically for mn12's?
Nick
Byrd_of_Thunder
post #268 of 760 (permalink) Old 02-26-2010, 01:33 PM
Slightly Disjointed
Those springs are way too soft, 700 lb/in sounds much nicer
post #269 of 760 (permalink) Old 02-26-2010, 01:37 PM Thread Starter
no.
there was a guy making them for us a few years back.....there was actually a group buy for them.
way too soft?
I tried 175 lb springs at first....those were way too soft...
post #270 of 760 (permalink) Old 02-26-2010, 01:38 PM
dam and i missed it? well if someone does it again i'm in only maybe someone can fab up some rear coilovers too.
your car seems to be coming along just swimmingly tho, can't wait to see the end result.
Nick
Byrd_of_Thunder
