Motorcraft vs Other Brand Oil Filters - Page 3 - TCCoA Forums
post #61 of 244 (permalink) Old 03-27-2014, 03:18 PM
Any info on the bosch filters or mobil 1 filters?
post #62 of 244 (permalink) Old 03-27-2014, 03:42 PM Thread Starter
Seasoned Geek
Chris here is a bit.
post #63 of 244 (permalink) Old 04-01-2014, 11:28 PM
CDsDontBurn's Avatar
So the Bosch and Mobil1 filters seem to be just as good as the Motorcraft one. The only worry of course being the possibility of not having a proper anti-drainback valve?
CDsDontBurn is offline
post #64 of 244 (permalink) Old 04-02-2014, 12:23 AM Thread Starter
Seasoned Geek
A few things off the top of my head
The M1 has combined mixture of synthetic micro fibers and natural fibers.
The Bosch has blend of natural and synthetic materials for its media. The MC has plain ole cellulose paper.
The M1 has 55 pleats ,Bosh 63 to MC's 50 so the M1 & Bosh have more media area to filter the oil.
The ADBV is pretty much the same on them heat resistance silicone.
Canisters are thicker as well on th M1 & Bosh.
The MC has the internal PRV.
post #65 of 244 (permalink) Old 04-02-2014, 09:01 PM Thread Starter
Seasoned Geek
NAPA Platinum 41372
NAPA has a sale this month $5.00 off a NAPA/WIX Platinum filter. Had two delivered for $14.50. This is a clone to a WIX XP filter . Will be using one on the 96 this summer .
Also NAPA Silvers on the 95 & Taunus now will have them cut and inspected soon.
And will be looking into filter info for the 3.8 , 5.0 per suggestion .
Specs as follows :
Wix XP Oil Filter Laboratory Test Performance per ISO-4548-12: 32 grams dirt* - up to 100% more than Wix - 99% efficient at 35 microns** (Based on *51515XP - **51356XP, 57060XP)
Gasket Inside Diameter (In): 2.462 Inch
Top Inside Diameter (In): Closed
Burst Pressure (psi): 275 psi
Bypass Valve Included: Yes
Bypass Valve Pressure (psi): 23 psi
Flow Rate (gpm): 11 To 13 gpm
Gasket Outside Diameter (In): 2.834 Inch
Gasket Thickness (In): 0.200 Inch
Media:Glass enhanced/Wire backed paper
Micron Rating: 23 Micron
post #66 of 244 (permalink) Old 04-03-2014, 03:17 AM Thread Starter
Seasoned Geek
Champ/STP S2
And here is a very cheap filter. Paper & nylon . $2.85.
Product Details
Part Number: S2
Weight: 0.7 lbs
Anti-Drain Back Valve: Yes
By-pass Valve: Yes
Filter Height (in): 3.2
Filter Outside Diameter (in): 3.59
Filter Style: Spin-on Canister
Filter Thread Size: M22 x 1.5 Special Thd.
Filtering Material: Advanced Micro Pore Technology Filter Media
Gasket Material: Rubber
Non-slip Grip: No
Removal Nut: No
post #67 of 244 (permalink) Old 04-03-2014, 03:08 PM Thread Starter
Seasoned Geek
MotorCraft FL-400S
Specifications:
Thread Inside Diameter (in.): 3/4"-16
Outside Diameter Top (in.): 2.98"
Outside Diameter Bottom (in.): 2.98"
Seal Outside Diameter (in.): 2.75"
Seal Inside Diameter (in.): 2.40"
Height (in.): 4.14"
Length (in.): 4.14"
Spin-On Filter: Yes
Anti-drainback Valve: YES
Bypass Valve: YES
Color: White
Burst Pressure (PSI): 250 psi
Pressure Relief Valve: YES
PSI Relief: 20 PSI
Micron Rating: 80%@20um
Filter Media: Cellulose phenolic resin
Pleats: 56
post #68 of 244 (permalink) Old 04-03-2014, 04:36 PM
Darren,
Keep it up! You're a beast cutting up these filters!
It's good to see what you're actually buying when they're opened up.
post #69 of 244 (permalink) Old 04-03-2014, 05:15 PM Thread Starter
Seasoned Geek
MotorCraft IPRV disassembled
Thank you bud
This was the end cap off the 400S , Fell off in my hand, notice the small black spot on the inside of the cap this was the only glue holding it on.
Here is a MC IPRV took apart .
post #70 of 244 (permalink) Old 04-03-2014, 06:31 PM
Custom User Title
Motorcraft FL-400S ... I was a little disappointed when they switched to the "New size, same performance" case design. Although it does make it a little easier to change on the Super Coupe.
dDUBb is offline
post #71 of 244 (permalink) Old 04-03-2014, 06:50 PM
My Contour needs a filter relocation worse than the MN12's, lol.
It's a 400.
Thanks for cutting one up, Darren!
So; the filter medium was only held on that end by that one drop of glue, not embedded like the 820S?
Rekon that's a fluke, or that's the way it's made all the time?
The other end looked glued in the same as the 820...
I really hope that one just got missed by QC, and not several thousand, after the glue ran out! (No LOL, lol. )
post #72 of 244 (permalink) Old 04-03-2014, 07:21 PM Thread Starter
Seasoned Geek
Many are having issues with the end caps not adhering to the media as it should.
As one can tell there glue covers the pleat ends very well and the pressure of the end caps keeps them in place . It does get brittle as can be seen in the edges in the pic.
Purolator makes them and they are having issues of there own.
Most welcome .
post #73 of 244 (permalink) Old 04-04-2014, 05:23 PM
rushtonracing's Avatar
Man, you are an oil filter dissecting machine!
Those Wix filters just keep looking better, and better.
1995 Thunderbird LX 4.6l 97 Headlamps/Hood All Red Tails Muffler/Resonator Delete
2004 Tahoe 5.3 4x4
2008 Acadia Limited AWD
...still looking for a clean, low mileage, rust free 96/97 Thunderbird 4.6
rushtonracing is offline
post #74 of 244 (permalink) Old 04-04-2014, 05:27 PM
AH!
I've seen that before, lol.
That's what happens if you don't wash the metal after the lube for the stamping press is applied. (If you don't lube the metal, it tears.)
It acts just like mold release, lol.
Usually you run it thru a bath that cleans and etches a bit into the metal...
Someone should be fired for that; but it probably saved them 0.00001 cent apiece.
post #75 of 244 (permalink) Old 04-04-2014, 09:30 PM Thread Starter
Seasoned Geek
Yes, Rush, I do enjoy tearing them apart and getting all the information behind them.
I got that from my grandfather and it is something I've been doing since I was a teenager. Yes Wix are built very well.
AH!
Thank you for that information. What you said explains a lot.
post #76 of 244 (permalink) Old 04-04-2014, 11:36 PM
Royal purple filters? Amsoil reusable? Any input? I've been leaning towards the Amsoil reusable filters but haven't heard much about it.
post #77 of 244 (permalink) Old 04-05-2014, 01:14 AM
Mgino96tbird46's Avatar
Amsoil makes a reusable oil filter? Not sure how I feel about that. lol
Now, supposedly, you can go up to 25,000 miles on an Amsoil oil filter. At least that's what it says on the box of one I have sitting in my garage. Is there any truth to this or is it marketing hype and ill-advised?
1996 Thunderbird LX. Gone, but not forgotten Oct 1995-March 24 2016
1998 Mustang GT premium. Auto, stock, and slow. Daily beater.
Mgino96tbird46 is offline
post #78 of 244 (permalink) Old 04-05-2014, 01:42 AM
My apologies I seem to recall a reusable one issued by amsoil I guess I was mistaken. What about this whole filter bypass deal?
post #79 of 244 (permalink) Old 04-05-2014, 02:52 AM Thread Starter
Seasoned Geek
RP , Amsoil is two of the best at filtration , K&N made or still does the SS OF.
Its very possible , One reason that they are higher than the average is because of the extra filtration that one can feel safe at using for long OCI .
post #80 of 244 (permalink) Old 04-05-2014, 03:40 AM
Should the filter element ever become so clogged with contaminates that oil cannot pass through, the bypass valve allows oil to bypass the filter element and go straight into the engine.
The thinking behind this is that dirty oil is better than oil starvation, and/or cavitation.
2004 Tahoe 5.3 4x4
post #81 of 244 (permalink) Old 04-05-2014, 03:50 AM Thread Starter
Seasoned Geek
Very well said, Here is a pic to help.
post #82 of 244 (permalink) Old 04-05-2014, 04:07 AM
Ah ha, that illustration answers my question about bypass valve placement. It does make a difference.
2004 Tahoe 5.3 4x4
post #83 of 244 (permalink) Old 04-05-2014, 06:25 AM
Rayo's Avatar
Good thread Darren..
I almost religiously only use Motorcraft filters on everything I own..Looking at the comparisons between other filters..
I see that the extra $$$ spent on a Motorcraft filter is well worth it..
I would like to see a Ford Racing Oil Filter cut open to compare to the standard Motorcraft filter..If you ever get a chance..
1991 Ford Thunderbird Sport
Rayo is offline
post #84 of 244 (permalink) Old 04-05-2014, 12:09 PM
Went for the Gold!
Part number is 1516 for us 3.8L guys.
post #85 of 244 (permalink) Old 04-05-2014, 01:14 PM Thread Starter
Seasoned Geek
Good choice there Joe Ray will do , going to fine what I can.
post #86 of 244 (permalink) Old 04-05-2014, 11:02 PM Thread Starter
Seasoned Geek
Micron Rating
I have decided that about twice a month I am going to post information I feel will be useful and informative regarding oil filters, their make-up, and specs.
The article I am posting today is about the size of particles the oil filter media captures. The particles are very minute.
For example:
Amsoil is 98.7% efficiency @ 20m
Motorcraft is 80% efficiency @ 20m
I hope you all are enjoying this thread and learning about the differences in filters so that you can make informed decisions when buying filters for your own vehicles.
I wasn't sure how well this thread would be received, but I want to thank everyone participating for giving your input and feedback.
post #87 of 244 (permalink) Old 04-05-2014, 11:36 PM
So would Amsoil filters be worth the expense on my dual filter setup or should I stick to the motorcraft filters I try to change them before every race. Its kind of like a prep ritual I've always done.
post #88 of 244 (permalink) Old 04-05-2014, 11:46 PM Thread Starter
Seasoned Geek
Stick with your setup Chris, The high dollar ones are best for long OCI & with hi efficiency serves that purpose well .
About on the same path you are with OC reason I go with a GOLD.
post #89 of 244 (permalink) Old 04-23-2014, 09:38 PM Thread Starter
Seasoned Geek
NAPA Silver 31372 6K ..95 4.6 131k
Engine oil : Mobil SUPER 5K 5W30
Pleased with the looks of this filter.
Filter Details:
Media: Paper
post #90 of 244 (permalink) Old 04-24-2014, 12:58 AM
Raoul Duke
cougarcragar's Avatar
Great thread and nice work with the information and photos.
1996 Mercury Cougar XR7
cougarcragar is offline
