Motorcraft vs Other Brand Oil Filters - Page 7 - TCCoA Forums
post #181 of 244 (permalink) Old 10-28-2014, 06:24 AM Thread Starter
Seasoned Geek
I have learned that early engines did not use oil filters, but they had to change their oil about every 500 miles.
With the filters, they were able to go longer between oil changes and it greatly helped keeping contaminants out of the engine and lubricating oils.
Oil filters on a car are like kidneys in a human. It scrubs the oil of impurities...dirt, metal shavings...which if allowed to circulate could lead to big-time engine damage.
Over time, an oil filter gets so clogged with impurities that it no longer effectively cleans the oil and dirty oil just keeps recirculating around the engine.
Therefore, the oil filter shields your engine from harmful floating garbage.
B&S oil filter for lawn mowers.
post #182 of 244 (permalink) Old 10-28-2014, 07:43 PM
I run a good ole FL400-S on my mower.
rodsv6cougar@cs.com
post #183 of 244 (permalink) Old 10-28-2014, 07:59 PM Thread Starter
Seasoned Geek
Took an act of congress to get this filter off. On the mower 10 years best to there knowledge .
post #184 of 244 (permalink) Old 10-28-2014, 08:17 PM
CDsDontBurn's Avatar
unless it's internal to the casing, my mower doesn't have an oil filter to my knowledge.
CDsDontBurn is offline
post #185 of 244 (permalink) Old 10-30-2014, 11:19 PM
Urambo Tauro's Avatar
A two stage filter setup is even better, If you use a finer filter medium in the second filter.
In this kind of a setup, you might be able to go 10k miles on good oil. By changing the filters...
I like this idea. I wonder how fine the filter media can be before causing a flow problem (or activating bypass)?
I found a chart listing Motorcraft filter specs: Motorcraft Filter Specifications | Oil Filters | Bob Is The Oil Guy
80% efficiency @ 20 microns
...then I found AMSoil lists different rating for the FL-820s: AMSOIL AMSOIL Ea Oil Filters
93.7% efficiency @ 20 microns
1996 Thunderbird LX (4.6), daily driver
1995 Mustang GT (5.0), alternate daily driver
Urambo Tauro is offline
post #186 of 244 (permalink) Old 11-02-2014, 06:47 AM Thread Starter
Seasoned Geek
A Greener Antiwear Additive for Engine Oils
Titanium,
A protean element with applications from pigments to aerospace alloys, could get a new role as an environmentally friendly additive for automotive oil, thanks to work by materials scientists from Afton Chemical Corporation (Richmond, Va.) and the National Institute of Standards and Technology (NIST). In a recent paper,* the researchers established that a titanium compound added to engine oil creates a wear-resistant nanoscale layer bound to the surface of vulnerable engine parts, making it a credible substitute for older compounds that do not coexist well with antipollution equipment.
Modern engine lubricating oil is a complex, highly engineered mixture, up to 20 percent of which may be special additives to enhance properties such as viscosity and stability and to reduce sludge formation and engine wear, according to Afton specialists. For years antiwear additives for high-performance oils have been phosphorous compounds, particularly ZDDP,** that work by forming a polyphosphate film on engine parts that reduces wear. Unfortunately phosphorus is a chemical poison for automobile catalytic converters, reducing their effectiveness and life span, so industry chemists have been searching for ways to replace or reduce the use of ZDDP. It’s not a simple problem because the additive has several useful functions in addition to wear resistance.
Titanium is one candidate replacement. Mechanical tests of an organic titanium compound at Afton demonstrated that it provided superior wear resistance when added to a fully formulated engine oil, suggesting that oil chemists could use less ZDDP. Just how the titanium compound works was an open question, however. Surface analysis tests could detect titanium in the wear tracks of test surfaces but not with enough sensitivity to determine its chemical nature—and whether, for example, it was just lying there or bound to the metal surface. To resolve the issue, the researchers turned to NIST’s soft X-ray beamline at the National Synchrotron Light Source (NSLS) in Brookhaven, N.Y.
The NIST beamline instruments use low-energy (“soft”) X-rays that can be precisely tuned to specific elements to measure chemical bonds both at the surface of a sample and deeper into the bulk of the material. Powered by the NSLS, the facility is at least 10 times more sensitive than commonly available instruments. The measurements revealed that the antiwear enhancement comes from titanium chemically bound into the metal structure of the engine surface, forming a hard oxide, iron titanate. Comparing the test data to that of several possible compounds, the research team was able to identify the specific oxide. While considerably more work remains to be done, the results suggest that titanium could play an important role in future low-phosphorus lubricating oils.
post #187 of 244 (permalink) Old 11-03-2014, 08:59 AM
BLKBRD88's Avatar
It took me several days to read all of the posts in this thread, & the accompanying info & charts.
I found it to be absolutely worth every minute of time spent.
This thread answers questions that I have had for nearly sixty years about oil filters, oil, & the additives used in oil.
Thanks to ThunderChecken & all of the rest of you guys who contributed this valuable info to a newbie to your forum.
Ron
BLKBRD88 is offline
post #188 of 244 (permalink) Old 11-03-2014, 05:54 PM Thread Starter
Seasoned Geek
Ron
Thank you Ron, And "Welcome" to the site.
Four more oils from PQIA today.
O'Reilly High Mileage Motor Oil SAE 5W-30
Mobil 1 High Mileage Motor Oil SAE 5W-30
Havoline Motor Oil SAE 5W-30
CAM2 SuperPRO Max Motor Oil SAE 5W-30
http://www.pqiamerica.com/index.html
post #189 of 244 (permalink) Old 11-12-2014, 08:35 PM Thread Starter
Seasoned Geek
Thumbs up
Just passing along my experience with a filter
NAPA XP 41372 , Installed on the Ranger 4.0 for the first time. Have always had a bit on lifter noise on cold start-up with other filters ( MC 820s, Napa Gold 1372, Fram Ultra X2) but now no noise at all .
The filter is made just like the Gold except for the Sys/Wire media & a slightly longer canister.
My guess the canister made the deference.
Edit :
Done research with people in the know reason being the platinum worked better .. Higher flow rate , That being said going with one on the bird as well.
post #190 of 244 (permalink) Old 11-16-2014, 03:06 AM Thread Starter
Seasoned Geek
Ford Racing CM-6731-FL820 Oil Filter
Rayo
You were wanting to see a FR filter .I have yet to run across one but here is one took apart.
Measurements
* Filter Weight - 19.75 oz
* Can OD - 3.68" / Seam OD - 3.76"
* Overall Height - 3.99"
* Can Material - 0.019" thick steel
* Filter Element OD - 3.44" (at element)
* Filter Element Height - 2.81"
* Media - Cellulose - Synthetic Mix
* Number of pleats - 63 + 1 joint
* Depth of pleats - 0.73"
* Media length (unrolled) - 100" (seam crimped)
* Media width (glue not included) - 2.50"
* Media thickness - 0.029"
* Total media surface area - 250 sq. in.
* Total media volume - 7.25 cu. in.
* Inner Filter Support Material - 0.010" Thick Perforated Steel
* Inner Filter Support OD - 1.71"
* Gasket Retention - Multiple Crimps
* Thread - M22-1.5
* Relief Valve Location - base end
* ADBV Material - Silicon
post #191 of 244 (permalink) Old 11-23-2014, 03:42 PM Thread Starter
Seasoned Geek
WIX Master .. down the road sometime.
post #192 of 244 (permalink) Old 11-23-2014, 03:48 PM
Congratulations!
post #193 of 244 (permalink) Old 11-23-2014, 03:52 PM
Rayo's Avatar
Congrats!
Thank You for posting that info on the Ford Racing oil filter as well..I just noticed that..
1991 Ford Thunderbird Sport
Rayo is offline
post #194 of 244 (permalink) Old 11-23-2014, 04:04 PM Thread Starter
Seasoned Geek
Thanks guys .
Ray The FRF is made by Purolator...BUT to FORD specs ... so its not seeing the tearing & blow out media issues the purs are.
post #195 of 244 (permalink) Old 11-24-2014, 10:21 AM
95LX4.6's Avatar
Congrats Darren, Glad to see you doing well boss.
95 LX: "Midnight" Photo thread: http://forums.tccoa.com/30-videos-images/137962-midnight-has-arrived.html *SOLD*
95LX4.6 is offline
post #196 of 244 (permalink) Old 11-24-2014, 06:54 PM Thread Starter
Seasoned Geek
Thanks TJ , Doing fair bud , Good to hear you & yours doing well yourself .
post #197 of 244 (permalink) Old 11-24-2014, 07:21 PM
rushtonracing's Avatar
All right!
Way to go Darren.
1995 Thunderbird LX 4.6l 97 Headlamps/Hood All Red Tails Muffler/Resonator Delete
2004 Tahoe 5.3 4x4
2008 Acadia Limited AWD
...still looking for a clean, low mileage, rust free 96/97 Thunderbird 4.6
rushtonracing is offline
post #198 of 244 (permalink) Old 11-24-2014, 07:29 PM Thread Starter
Seasoned Geek
Originally Posted by rushtonracing View Post
All right!
Way to go Darren.
Thanks Race... And for the video of "Zepparella" lol
post #199 of 244 (permalink) Old 12-02-2014, 12:14 PM Thread Starter
Seasoned Geek
WIX Master
Just achieved WIX Master Level! I am not doing this(and more) to boast of my accomplishments. Quite the contrary, I just want to be well-informed about filtration as we all know, the life of the engine is vital to a vehicle and proper filtration aids in prolonging that life.
I do want to take the time to thank those who have encouraged me. It means a lot when you have friends who back you up and appreciate what you are trying to do. To you guys....Thank you.
post #200 of 244 (permalink) Old 12-02-2014, 03:44 PM
Hope you got a nice frame for that!
Congrats again Darren!
post #201 of 244 (permalink) Old 12-02-2014, 08:53 PM
Rayo's Avatar
X2
Way to go!
Rayo is offline
post #202 of 244 (permalink) Old 12-03-2014, 08:50 AM
T6Rocket's Avatar
Congrats Darren!
Al
97 T-Bird LX 4.6 - 68k miles
Previous cars:
T6Rocket is offline
post #203 of 244 (permalink) Old 12-03-2014, 09:24 AM
I admire your efforts, and achievement. A nice addition to a/your gallery wall. Congratulations.
2004 Tahoe 5.3 4x4
post #204 of 244 (permalink) Old 12-03-2014, 10:48 AM Thread Starter
Seasoned Geek
Thanks guys. Its in a folder with my Telecom Eq certs . The wife wants to make a wall sometime down the road . Just paper........ what's in the mind that's counts
post #205 of 244 (permalink) Old 12-11-2014, 04:15 AM Thread Starter
Seasoned Geek
Article on Wix
Born in NC
WIX Filters is a pioneer in the automotive filter industry that continues to innovate more than 70 years after its founding. Customers who opt for WIX are getting a quality product that is built to last from a company that manufactures more than 200 million innovative and durable filters around the world.
“Our products are in the premium category, so our customers expect premium performance,” says David McColley, vice president of marketing and product management for WIX Filters. “Our product fills that need without any trouble.
“It fits properly and performs up to expectations,” he adds, noting that WIX produces more than 30,000 types of high-performing filters globally. “The last thing anyone wants is to come back and service a vehicle and hear our product didn’t perform as it should. There is a high level of expectation for the performance, fit and function of our product, and our product line consistently lives up to that expectation.”
John Doane “Jack” Wicks and Paul G. Crawshaw founded WIX Accessories Corp. in 1939 in Gastonia, N.C., out of an old cotton mill. Keith Wilson, president of WIX Filtration, says this part of the country made it an ideal location for the simplification of the oil filter because of the abundance of scrap cotton available from the textile industry that supported this region.
From these origins, WIX Filters soon turned the industry upside down with a number of innovations to its oil filters. In the 1940s, the company added a handle to launch the WIX brand, offering an easier way to handle dirty filters. In the ’50s, the company invented filters that could easily twist on and off, simplifying the changing process. In 1992, WIX developed the first conical air filter, and in 2006, it launched its Cabin Air Nasties product, which cleans air for the interior of automobiles. In 2011, it introduced a heavy-duty oil filter that more than doubles the oil’s life.
Along the way, WIX Filters has been supported by a number of key partners and mergers that have kept the company innovating and excelling in filtration for more than 70 years. In 1966, the company became the first private-label manufacture for NAPA Auto Parts, a relationship that continues today. The company made its first acquisition in 1983 when it acquired Air Refiner to enter the heavy duty industrial segment. In 1988, it acquired a plant in Venezuela from Sivensa that remains in operation today.
WIX Filters formed a joint venture with Helsa Functional Coating, a manufacturer that brought WIX into the cabin air filtration market, in 1996. Two acquisitions in 1997 – Detroit-based Flexon and Olen Commercial Services – brought WIX into the automotive fuel filters market. The following year saw WIX acquire a Southampton, U.K., facility formerly used for General Motors’ European operations, and consolidated its own European operations with headquarters in Poland.
WIX Filters itself was owned and operated by Dana Corp., a vehicle parts supplier based in Toledo, Ohio, from 1979 to December 2004. The company now operates as part of Affinia Group. WIX Filters boasts 11 manufacturing operations throughout the world, with 40 percent of its business stemming from customers outside the United States.
Vast Product Line
McColley says approximately 50 percent of WIX Filters’ sales are to the heavy-duty segment. “That’s not a big surprise since these clients change oil more frequently and service their air filters more often,” he says. “That generates quite a few replacements on air filters.”
For this market, the company offers oil filters including: WIX XD (extended drain), WIX XE (extra efficiency) and WIX ecoLAST brands – as well as air filters, fuel filters, cabin air filters, hydraulic filters, coolant filters and transmission filters.
“Our history has deep roots in heavy-duty filtration,” says Keith Wilson, president of WIX Filters. “We understand what keeps maintenance managers up at night and we know how filtration can significantly impact the long-term profitability of an entire fleet.
“WIX premium filters enable the lowering of long-term costs by lengthening maintenance intervals while continuing to protect vital engine parts as well as or better than traditional filters changed at shorter intervals,” Wilson adds. “Our experienced engineers, who are responsible for more than 30 U.S. patents, ensure WIX stays ahead of every technological change in the industry.”
The rest of WIX Filters’ sales stem from automotive and Light Truck applications, according to McColley, as well as niche products like WIX Racing Filters, and Aqua Chek water removal filters. In terms of geographic reach, about 30 to 40 percent of sales come from overseas, with the largest portion originating from Europe, including Poland, Ukraine and Russia, where WIX has facilities. The company sells product in Venezuela, as well, where it has a manufacturing facility, with smaller operations in Brazil and Mexico. The company also recently built a new facility in China.
The Value of WIX
No matter what the industry, filter category or region of the world, McColley says customers benefit most from what he calls the “WIX value proposition.” This proposition consists of seven core elements that are critically important to its customers:
Order fill – McColley says WIX customers count on it to deliver a high rate of order fill with historic shipping performance at 95 percent or better. Despite the volume of orders, the company can get an order turned around within 48 hours without any forward-looking forecasts from customers, according to McColley.
“We’re extremely flexible here and we have a lot of diversity of products on our lines,” said Steve Renfrow, plant manager of the company’s Allen Plant. “Our production assembly lines run many different sizes and shapes of products, so we have to be able to make changeovers very quickly.”
Renfrow says the Gastonia plants review every production line each day to determine what’s on backorder and potential backorder, and creates daily schedules to determine what to run each week. This daily schedule allows the manufacturing operations to set up specific runs for much-needed product, with lines changing over as much as eight to 10 times a shift.
High-quality products – “Our customers and their customers and professional installers trust our brand,” McColley says. “OE quality or better is an expectation, and customers know they can count on WIX quality, backed up by our WIX warranty.”
Expert sales team – The sales force consists of more than 150 employees who assist customers in pulling product though a given supply chain. The salespeople are well-versed enough to visit any given installer’s bay, fleet or mine and advise customers on a variety of issues ranging from technical assistance, to stocking recommendations to inventory investment.
WIX Filters annually sends about a third of its sales force through its own WIX Institute, a three-day course taught by employees from the technical service and engineering departments to give salespeople and customers an exhaustive rundown on the products they sell. The course also includes a tour of all of WIX plants in Gastonia.
Technologically enabled – As its clients grow and become more sophisticated in the use of data and technology like electronic cataloging, WIX Filters has kept pace with them every step of the way. Since this is now considered the industry standard for suppliers in the automotive aftermarket segment, WIX gives its clients total access to its product data including product images, product attributes, installation instructions, and more so associates at all levels can speak intelligently about its products. Customers also can use an online order tool, Affinia On Line, to place orders, check order status, or inventory.
“These are tools that work 24/7, 365 days a year so customers can access data or place orders with us when it’s convenient for them,” McColley says.
Through its technological savvy, WIX Filters also can advance the performance of its products. This is how it developed its ecoLAST line of filters. This filter’s extended drain technology sequesters harmful acids that are a natural byproduct of combustion. McColley says WIX currently is the only company that offers this type of product.
Superior sales growth and margins – McColley says for most of the company’s retail clients, filtration offerings typically represent a sizeable percent of their overall business volume. “If they’re going to grow and be profitable, we want to be the locomotive that drives that business and also use filtration to open the doors to sales of other products,” he says.
According to Renfrow, WIX Filters manufacturing teams work with engineering and product development at the product planning stages to best determine what is needed for a new product. Sometimes, that involves creation of a new production line, and other times it calls for a slight tweaking of an existing product or process.
“If the volume justifies a style of filter we’ve never run before, we’ll introduce the new process and get involved early on to complete it within a six-month window,” Renfrow states. “That’s mostly for lead time to order the required tooling and equipment we need.”
Greg Dillman, vice president of engineering, says WIX Filters is involved with the OEMs for major platforms and those designs make take several years before they are seen in the aftermarket. “Those design advances in Original Equipment certainly impact the aftermarket and influence the how WIX meets those demands,” he says.
Product coverage – As manufacturer for several major distributors, WIX offers unparalleled product coverage. WIX Filters offers this breadth of items to ensure its customers can count on them to provide 100 percent of their filtration requirements. Time to market is another key consideration when it comes to coverage. Our customers service late model vehicles and demand timely new additions and WIX delivers.
Customer service – Although McColley joined WIX Filters in the late 1990s, he says it is evident that exceptional customer service was a pillar of stability for the company long before his arrival. This is evident in the relationships the company maintains with automotive manufacturers like GM and Ford, both of which have relied on WIX filters for more than 50 years. While NAPA, CARQUEST and O’Reilly have distributed WIX products each for more than 20 years.
“We have longstanding relationships because we embrace customers and have positive histories of working together,” Wilson added.
Hot Topic
With oil prices as volatile as ever, end-users want to extend the life of the oil in the fleets for as long as possible. However, engines also are operating at higher temperatures than the past – engines can sometimes exceed 250 degrees F in a given application. These issues have forced WIX Filters to revisit the materials it has used in the past.
“The life of the oil is being challenged in some of these really extended drain intervals,” McColley says. “This can be a taxing load on oil filters as the oil breaks down.”
In air filtration- WIX Filters has seen a transition toward panel-style filters, including those made of injection-molded plastic with nonwoven synthetic material as the media. “We have a whole team of people looking at different types of media,” McColley adds. “They’re trying to address many of the same issues with temperature and material capability.”
As for fuel filters -WIX has seen a trend with many auto manufacturers opting to place the fuel filter in the fuel tank, thus rendering the filter non-serviceable without dropping the whole fuel tank from the vehicle. This change has resulted in two challenges: The in-tank filters must last the life of the vehicle, and sales of traditional fuel filters have dropped as a result. Looking forward, WIX now sees manufacturers of vehicles using diesel and gas engines with common rail fuel systems operating at high pressures requiring finer filtration.
Along with growing in the industrial filtration sector, WIX Filters aims to expand to more international markets in the future. Wilson says the company is targeting the BRIC nations – Brazil, Russia, India and China – for new and continued expansion.
“We already have a small footprint in Brazil, but it is a great market where we would like to have a better foothold,” Wilson says. “We’re already in Russia, and India also is a great growth opportunity, so it’s another market I would like WIX to be in some day.”
According to Bob Ferguson, vice president of global sourcing, about 90 percent of WIX Filters’ products are sold to traditional aftermarket customers. These customers do not provide WIX a forecast of their needs but expect it to know their order patterns and have the product they need available in distribution centers to ship within 24 hours of placing an order. In order to accomplish this, WIX must forecast its customers’ needs and have products scheduled and produced in its plants on time. The remaining 10 percent of products are made to order for either a co-manufacturer, OEM or any type of client who may need private labeling.
WIX uses an ERP system to create the work orders and get lines scheduled throughout its plants to replace product that is about to run out. Ferguson says all lead times are built into the forecast and master schedule so raw materials can be purchased accordingly, as well.
About five years ago, WIX Filters updated its procurement process by installing software that can forecast the needs for every part – which involves thousands of SKUs – based on algorithms, history and product type. This independent forecasting by SKU optimizes inventory costs and availability, according to Dillman.
“It really optimizes the inventory along with cost of changeovers in the plant and balances those two based on our need at our distribution centers and demand of the plant,” Dillman says. “This process creates a work order for finished goods and the system then drives demand for raw materials so that they arrive just as we need them.”
Product Longevity
With approximately 12,000 different constructions of filters, a family of products can remain intact for decades. For instance, numerous filters required for open road vehicles haven’t changed in the last 50 years, although there are new applications calling for new products every year.
“I would say part of our strategy is speed to market as far as new applications coming along,” Ferguson says. “We measure ourselves on our ability to have new product available to our customers within a certain time criteria of when that product will be needed on that particular vehicle.”
Ferguson boasts that WIX Filters can have a replacement filter available approximately four months after a vehicle hits the market. Dillman adds that since a vast majority of the company’s business is in serving the aftermarket sector, unless WIX Filters introduced the filter to the OEM directly, the company has to rush to get a product to market as soon as possible.
“We have to scramble to get a part designed or manufactured because we don’t get a lot of advanced warning,” he adds. Ferguson says the company cuts down on lead times for such products by relying on WIX Filters’ existing product line and tweaking accordingly.
“Oftentimes, this calls for a new spin-on design that is constructed differently, using existing components in a different arrangement,” Ferguson says. “Whenever a new family of product comes through, that requires the building of a complete new manufacturing process to accommodate that.”
Every few years, these new families require an investment in new tooling and equipment. However, most often, the company relies on taking advantage of existing components and processes to create new products without having to retool its machinery.
“It’s fair to say when we’re looking at a new family and thinking about a new manufacturing process for that particular family, we would definitely try to make that process flexible enough to produce a large variety of filters in that family,” Ferguson says. “That’s one of our strategies. We make sure the assembly process does have that flexibility.”
Quality Control
To ensure its products are constructed with the utmost quality, WIX Filters requires that its suppliers are ISO certified, with some expected to have TS1649, as well.
“Engineering supplies specifications that we expect, and we have pretty high standards for process ability along those lines,” Ferguson says. “Along those lines, when working with suppliers, we’re going to select the one that gives us the best value not just on piece price, but the quality, workmanship, delivery and performance, as well. We could get a product at a cheaper price, but when we run it, it might generate more scrap, and take longer to process.”
WIX Filters also brings certain key suppliers into the R&D process to help with the functionality of the product itself. This helps WIX ensure it is introducing the most advanced filtration applications available.
“This helps us introduce new products that are better for the marketplace, whether they are more robust against adverse driving conditions, oil temperature and pressures,” Dillman says. “The WIX engineering team has technical meetings with our key suppliers on a regular basis to review our project list. This ensures that we continue to use the most technically advanced materials in our filtration products.”
Ready for Growth
With such rigid standards for quality and the demands for quick turnaround times to serve the aftermarket sector, Wilson says WIX is set to grow domestically, and around the world. “In the simplest of terms, our philosophy says: build the bulk of the product you sell, in the market where you sell it. That means we intend to manufacture in the markets where we sell around the world, including the U.S. and North America,” he said.
post #206 of 244 (permalink) Old 12-11-2014, 11:26 PM
BLKBRD88's Avatar
Thumbs up
Congrats!!!...........
Ron
BLKBRD88 is offline
post #207 of 244 (permalink) Old 12-12-2014, 10:02 AM Thread Starter
Seasoned Geek
Thank you Ron .
post #208 of 244 (permalink) Old 12-12-2014, 10:57 AM
Interesting read about Wix. Thanks for posting the insights about this company.
Sparks an interest to investigate this company more as I search for role-models to develop my own company.
2004 Tahoe 5.3 4x4
post #209 of 244 (permalink) Old 12-13-2014, 07:49 AM Thread Starter
Seasoned Geek
Most welcome Race , Glad to help ya out.
post #210 of 244 (permalink) Old 12-13-2014, 07:51 PM
I ussually always used Motor craft, the first time I used a Fram I had tiny clumps of paper or fiber (not sure) in the oil. The next change I had more of the tiny pieces in the Motor craft filter its self. Then I never had it again using the Motor craft filter.
2011 Kia Sorrento
1996 T-bird
*SOLD* 2007 Suzuki M50
Looking for a new ride!
funderbird is offline
