Strange noise from diff? - TCCoA Forums
post #1 of 5 (permalink) Old 03-06-2017, 07:10 AM Thread Starter
97 lx sport i have a strange noise coming from my diff sounds like road noise when accelerating or coasting but if you let out on the throttle it rattles similar to when you have something stuck inside your cat.......anyone have any ideas? Pinion bearing maybe??
tleem1996 is offline
post #2 of 5 (permalink) Old 03-06-2017, 10:51 AM
Rayo's Avatar
I would start, by checking the fluid level..
It should be level with the fill plug, in other words you should be able to feel the fluid with your finger inside the fill hole..
Tell us more about your rear end..
Is it completely stock?
Has it ever been serviced?
Any fluid changes done recently?
Are there any obvious signs of seepage/leaks anywhere on the outside of the Differential Housing?
Your description of the noise your car is making back there, sounds a lot like a bad rear U-Joint..
Look at that as well, for any signs of wear..
1991 Ford Thunderbird Sport
Rayo is offline
post #3 of 5 (permalink) Old 03-08-2017, 03:36 PM
gordonm1's Avatar
I think Rayo has some good advise to start with.
Otherwise:
You can put some oil in it and don't look behind you or under your car. Keep driving until it stops going.
gordonm1 is offline
post #4 of 5 (permalink) Old 03-17-2017, 10:07 AM Thread Starter
Fluid level was good completely stock rearend ujoints were replaced 5thousand ago no leaks that i can see but i can move the drive shaft up and down a good 1/4 inch or so
post #5 of 5 (permalink) Old 03-17-2017, 01:25 PM
If it's moving at the flange, the pinion bearing is toast; if it's in the middle of a stock DS, the DS could be the problem.
