97 Thunderbird 4.6L - Problem with A/C manifold lines - TCCoA Forums
 1Likes
  • 1 Post By XR7-4.6
post #1 of 5 (permalink) Old 04-07-2017, 11:03 AM Thread Starter
whitebird97's Avatar
I recently took my 97 Thunderbird to the shop because the A/C compressor was going bad. They installed a new compressor, but told me that the A/C manifold lines are bad and were leaking bad enough so that I won't be able to have any A/C. I was told that the part numbers are obsolete and there isn't anything they can do. Being this car is a daily driver and still in very good shape, I need to find a way to fix the A/C. Is there anywhere I can purchase these manifold lines, or is there a workaround? Thanks in advance!
97 Thunderbird 4.6
2.25 custom exhaust w/flowmasters, deleted cat, 3.73s, 1.25 drop w/Tockico blues.
whitebird97 is offline
post #2 of 5 (permalink) Old 04-07-2017, 11:26 AM
Slightly Disjointed
Are the lines leaking? Or are the connections to the lines, or the valves themselves? It could be as simple as replacing all the O-rings
post #3 of 5 (permalink) Old 04-07-2017, 12:22 PM
Woodman's Avatar
I think the 1996 lines are still available, and you can retrofit them to the 97 I believe.
Woodman is offline
post #4 of 5 (permalink) Old 04-07-2017, 01:00 PM
Slightly Disjointed
Nope. high pressure lines use different connections at the condenser, 96(and prior) use push lock fittings, 97s are screw in.
97-98 Mark VIII should interchange, the routing over the shock tower is slightly different but not in a way that would interfere.
Woodman likes this.
post #5 of 5 (permalink) Old 04-07-2017, 01:11 PM Thread Starter
Thanks for the reply, not sure about this, I'll have to ask the mechanic. He only told me that they were leaking and in bad shape.
97 Thunderbird 4.6
