DC power dropped out - TCCoA Forums
post #1 of 15 (permalink) Old 05-18-2017, 07:30 AM Thread Starter
This morning driving into work the cruise control just shut off. This happened twice and I noticed the second time the radio turned off and back on. The accelerator pedal poped up & the snap it made caught my attention.
The car never sputtered or shut down. It's like the power just dropped out real quick. I did a quick check before walking into work, battery is 12.4v; the connectors were tight with no corrosion. Looking for any ideas or experience. It's an aftermarket radio installed by the PO, so that's where I'm going to start checking.
Kidd-7 is offline
post #2 of 15 (permalink) Old 05-18-2017, 04:26 PM
S4gunn's Avatar
My guess is the alternator and/or voltage regulator on the back of the alternator is going out (so it's running only on battery power) or there's a loose connector/corrosion at the battery (so it was running on only alternator power).
I had something similar happen with an old commuter car. When the car is no longer providing as much power as needed for all the electrical accessories, stuff starts acting weird even if the car continues to run.
-g
S4gunn is offline
post #3 of 15 (permalink) Old 05-19-2017, 10:14 AM Thread Starter
-g: Thanks for the insight. Battery terminals are clean and tight. I'll check out the alternator and do some voltage readings and check fuses. I pulled the radio last night and drove in w/o it. The wiring is all crimp connectors and not pretty. The cruise control would not work at all. I also noticed that the clock is dark, it did light up some for a few minutes, but went dark again.
Side note: Since I bought the car the volt gauge bounces when the blinker is on. I never really though much of it b/c the blinker indicators are on either side of the volt gauge, but maybe in fact that current draw is causing the voltage to dip.
Kidd-7 is offline
post #4 of 15 (permalink) Old 05-19-2017, 11:14 AM
S4gunn's Avatar
1) This all sounds like an alternator/voltage regulator issue to me.
2) most auto shops have a testbench in which they can test your alternator but keep in mind that the load on a testbench is "simulated" so a marginal alternator could pass the testbench but still fail in real world. These items do wear out.
Depending on how frugal you are, you can rebuild an alternator fairly cheap yourself (kits are on eBay). I've done it before and would do it again if you find the issue are voltage spikes (uneven voltage when measured at the alternator output.
Regards,
-g
S4gunn is offline
post #5 of 15 (permalink) Old 05-19-2017, 03:25 PM
Check the connections at the megafuse, below the outside fusebox; that's a common spot for problems.
Checking the voltage at the fusebox and tracing back while the blinker is making the voltage vary makes it easy to troubleshoot; when the voltage stops varying, the problem is between the last two points.
If it varies more than a volt at the battery itself, even with the engine off, your battery is wasted, or barely charged.
Charge the battery and check again; that's a sure sign of a cell that's slowly dying.
If charging the battery fixes the variation, the alternator isn't charging enough, and needs rebuilt; I've used "Victory Lap" kits from amazon with no issues. ~$20.
You may end up replacing the battery too, if the Alt has been undercharging for a long time.
post #6 of 15 (permalink) Old 05-19-2017, 03:38 PM Thread Starter
Good advice thanks Grog6; didn't think of the mega fuse, but that thing is open to the elements. I'll run some voltage tests when I get home and see.
Kidd-7 is offline
post #7 of 15 (permalink) Old 05-19-2017, 07:50 PM Thread Starter
Checked the mega fuse, very slight green corrosion, but northing major.
Checked the voltage after work today. with the engine running I've only got 13.4v; Even reving the engine the voltage doesn’t climb. The battery voltage does drop about 2v when starting, so that battery is dying.
The battery is a 2 year old wally world batt. I may try swapping the battery with one of my other cars and see what happens.
Kidd-7 is offline
post #8 of 15 (permalink) Old 05-20-2017, 12:20 PM
The limit of voltage drop on a battery during starting is to about about 8V, depending on what your engine is built to.
A 2V drop while turning the headlights on is a battery problem, not a 2V drop while starting.
I'd buy a rebuild kit for the alternator, and check the rest of the wiring; there's a problem somewhere.
Check the ground side out; I'd bet the heavy wire to the starter is going bad.
Look at the Sticky for the "Big Three" mod.
post #9 of 15 (permalink) Old 05-20-2017, 10:33 PM
Rob
Rob's Avatar
Send a message via AIM to Rob
You don't think maybe it's a cruise system problem rather than voltage supply? Perhaps it's a intermittent switch or failing cruise actuator? The reason I mention this is your only symptom is the cruise turning off, right?
Rob is offline
post #10 of 15 (permalink) Old 05-21-2017, 06:50 PM
S4gunn's Avatar
He also mentioned the radio cutting out.
-g
S4gunn is offline
post #11 of 15 (permalink) Old 05-22-2017, 07:16 AM
Rob
Rob's Avatar
Well damn, I missed that. Yeah I would also be suspicious of a big voltage drop/loss somewhere.
Rob is offline
post #12 of 15 (permalink) Old 05-27-2017, 10:51 AM Thread Starter
Had to travel, but I'm back.
It is possible it's the cruise control drawing too much current, but not enough to blow the fuse. I think it's more likely corrosion on the wires.
I replaced the alternator, had one on the shelf, it seemed to improve some. I also pulled the radio and replaced the crimp connectors with solder & heat shrink, some were really loose. I data logged it going to work, the cruise held longer than before, but did fail again. Unfortunately, looking at the data I didn't see any Vdrop.
There was mild corrosion on the ground near the battery, I need to pick up a new batt term to clean that up.
I'm still a little leary of the battery though; normally when I test one I like to see no more than a 1.5v drop when starting. I'm going to do some more testing this weekend and possible swap the battery with my other car.
Kidd-7 is offline
post #13 of 15 (permalink) Old 05-27-2017, 12:20 PM Thread Starter
Big 3 question: What are the big 3? I read through posts that I found, all referring to using larger gauge wire, but I didn't see specifically what the big 3 are. I read about running a ground from the alternator mounting to the chassis, but what other wires are we talking about here?
Thanks.
Kidd-7 is offline
post #14 of 15 (permalink) Old 05-27-2017, 12:33 PM
Thanks.
Alternator to battery; battery to block; block to body.
(The "Big 3" may actually be 4 or 5, since for instance, my old 2000 Malibu went alternator --> starter post; starter post --> battery for the positive; then block --> body; body --> body; body --> battery for the negative.)
Fuelly
RalphP is online now
post #15 of 15 (permalink) Old 05-27-2017, 01:37 PM Thread Starter
Makes so much more sense now, thanks, RalphP
Kidd-7 is offline
