what's needed for 300 rwhp - TCCoA Forums
 2Likes
post #1 of 90 (permalink) Old 01-13-2009, 12:26 AM Thread Starter
Like it states I was wondering what would be required to get 300 rwhp on a NA build? It would be going in a 95 T-Bird
This is not something that is gonna happen in the next lil bit but eventually I would like to try to reach this goal...
I know that otherthings would have to be looked at first but i would kinda like to start planning this out,
Also not looking to do a 32v swap maybe explorer swap
transam396 is offline
post #2 of 90 (permalink) Old 01-13-2009, 12:36 AM
T-BIRD 90's Avatar
i cant really tell u personaly but there is a book i have that is called "how to build max-performance ..4.6 liter ford engines"...it covers 4.6L & 5.4L 2,3 and 4 valve head and intake
-camshafts & headers
-big-bore & stroker short blocks
-blowers, turbos, and nitrous
they have even successful packages in the book. witch is form a packages that has 345 hp and 355 tq(2v 96-04 n/a) to 1500 hp 1000 tq 32v (blown or turboed) custom built engines
T-BIRD 90 is offline
post #3 of 90 (permalink) Old 01-13-2009, 12:47 AM
Moderator & Teksid Whore
guitar maestro's Avatar
ported heads, cams, exhaust, tune, compression, air, fuel, spark, RPMs, etc, etc, etc
there are a million threads on this that have never materialized that you can read up on
hit that search button buddy!
guitar maestro is online now
post #4 of 90 (permalink) Old 01-13-2009, 12:56 AM
T-BIRD 90's Avatar
or that ^
post #5 of 90 (permalink) Old 01-13-2009, 05:51 AM
cougar_ricer's Avatar
how deep is your pockets? lotsa info in search on this subject. others will prob chime in though.
cougar_ricer is offline
post #6 of 90 (permalink) Old 01-13-2009, 07:13 AM
firescout211's Avatar
Send a message via AIM to firescout211
this is MY build:
DSS racing short block with 10cc pistons and .20 over $3,000
fox lake stage 2 heads, comp stage 2 cams $2,500
pi intake with c&l plenum and 75mm t/b $700
2800 stall converter $800
kooks headers, catless, 2.5 duals $1700
3.27 posi rear, built trans by darrin $1200
and tuned on blown head gaskets (consumed 1 gallon of antifreeze per 200 miles) made 272 rwhp and 292 rwtq, and ran 13.7 at 99.9 mph 1/4 time
new setup with unk numbers: NEW HEAD GASKETS!!!! $200 port matched bullitt intake $1500 , 3600 tripple disk circle d converter $1000, 3.55 posi rear $400, ARP everything $400, and vortec with 15 psi $1500
5.4 32 valve monster being built
firescout211 is offline
post #7 of 90 (permalink) Old 01-13-2009, 07:16 AM
if i could do it all over again, i would do a 3 or 4 valve build, don't blow the money like i did on a 2 valve......
post #8 of 90 (permalink) Old 01-13-2009, 09:51 AM
BIG PETE's Avatar
Agreed. The 2V will make good power, but if I had my identical setup with a 32V head instead of my 2Vs, I'd probably be making 370-380 at the wheels with the Ford Racing cam set for the DOHC engine.
If I had headers on my car now, it would make 300 RWHP, but they are awaiting install. I'm currently making around 270, but the stock manifolds are killing me.
Maybe the new Trick Flow heads will make a 2V more of a viable option, but still. Just get a DOHC longblock, slap a Vortech on it with 6 PSI worth of boost, and you're done.
Pete
-97 XR-7
-5.0 Big Bore ...
Density Altitude = 4132'
1/8 mile: 8.75 @ 82
BIG PETE is offline
post #9 of 90 (permalink) Old 01-13-2009, 10:18 AM
this is MY build:
New setup with unk numbers: NEW HEAD GASKETS!!!! $200 port matched bullitt intake $1500 , 3600 tripple disk circle d converter $1000, 3.55 posi rear $400, ARP everything $400, and vortec with 15 psi $150
If i could do it all over again, i would do a 3 or 4 valve build, don't blow the money like i did on a 2 valve......
You needd 3.73's or 4.10's.
Wait until you can get your hands on the new TrickFlow 2V heads. They'll be worth the wait.
post #10 of 90 (permalink) Old 01-13-2009, 02:15 PM
wait till the trick flows come out? no way! i've spent wwaaayyyy too much money on the ehads i have now and my intake is custom matched to my current set up, thanks though. i would go with a larger rear if i did not have a blower. thunderbirds are unique in that they are luxury performance. i am keeping the car streetable. if i wanted a 1/4 car, i would have built a mustang.
post #11 of 90 (permalink) Old 01-13-2009, 03:51 PM
lol. 3.73's are streetable even with a blower.
I should have clarified. The reference to the TrickFlow heads was for the original poster, Mr. transam396, who has his F150 listed in his profile instead of his Tbird and who's screen name reflects a GM product, go figure?
post #12 of 90 (permalink) Old 01-13-2009, 03:55 PM
why?
everyone else and their brother has a stang.
sometimes its good being different.
when it comes to actually building a real race car, it really doesn't matter what car you go with, it all costs lots of money.
post #13 of 90 (permalink) Old 01-13-2009, 07:10 PM
BIG PETE's Avatar
Well, NA you would need 4.10's or 4.30's for the gears, but I went with the 3.73's to leave the door open for a Vortech. If you get a stout 2V built then throw some boost at it, the 3.73's would be perfect for the MPH you'd cut across the line in 3rd.
Pete
-97 XR-7
-5.0 Big Bore ...
1/8 mile: 8.75 @ 82
BIG PETE is offline
post #14 of 90 (permalink) Old 01-13-2009, 09:30 PM
rbrown's Avatar
why?
Actually it's everyone and your brother.
rbrown is offline
post #15 of 90 (permalink) Old 01-13-2009, 11:14 PM Thread Starter
Sorry I didn't realize that I hadn't corrected my profile since i got my bird...When i signed up I didn't have my bird yet so i listed the truck.
As for the screen name I've been using that same screen name since 1997 , I had a 1980 transam that I was going to put a 396 in. But marraige intervened.
I'm really intrested to see what kind of numbers the trickflow heads can put down.
I kinda laugh when i hear guys talking about needing 400-500 rwhp I think 300 would be a real nice number and as far as gears go would prob stay with somethin like a 3.55 or maybe as high as 3.73 to maintain some type of highway mileage as this is my DD.
LOL since I got this Thunderbird my 04 supercrew with the larait trim has been on the road Twice since October i just LOVE driving this car
post #16 of 90 (permalink) Old 01-14-2009, 05:58 AM
BIG PETE's Avatar
Well, as for gears, lemme put it to you this way. My car makes within 15 RWHP of Johnny Langton's. They were on the dyno the same day at the same place; however, his car runs over 1 sec faster in the 1/4 mile. The only significant differences are that he has 4.30's to my 3.73's, a higher stall converter than my 3500, and he ran on slicks. That's it. My 3.73's get about 24 mpg on the highway at 70 MPH while JL gets about 21-22 with the 4.30's.
Pete
-97 XR-7
-5.0 Big Bore ...
1/8 mile: 8.75 @ 82
BIG PETE is offline
post #17 of 90 (permalink) Old 01-14-2009, 06:09 AM
As for the screen name I've been using that same screen name since 1997 , I had a 1980 transam that I was going to put a 396 in. But marriage intervened.
I'm really interested to see what kind of numbers the trickflow heads can put down.
I kinda laugh when i hear guys talking about needing 400-500 rwhp I think 300 would be a real nice number and as far as gears go would prob stay with something like a 3.55 or maybe as high as 3.73 to maintain some type of highway mileage as this is my DD.
LOL since I got this Thunderbird my 04 super-crew with the lariat trim has been on the road Twice since October i just LOVE driving this car
That's cool. Thanks for the clarification on your screen name.
Yea, I'd have to agree, 300 would be a real nice number to achieve. That's been my goal as well. I hope to get there this year or next. I'm running 3.73's in mine as well and am very pleased with them.
Here's a snapshot of the flyer for the new Trick Flow heads with some numbers on it, from this thread where we've been discussing them. There are also some other pictures of the new heads in the linked thread.
It's my understanding that the new Trick Flow heads are on several blocks and are currently being Dyno tested for stories to be run in automotive magazines in the coming months. As far as I know they're still not yet available. They will definitely be on backorder as soon as they are released for sale.
post #18 of 90 (permalink) Old 01-21-2009, 08:46 PM
Boost Happy
Jurgen's Avatar
Send a message via AIM to Jurgen
Pete
4.10's and Vortech are not as bad as everyone thinks .
1994 Ford Thunderbird
2002 Corvette Z06
Yeah I got a few mods.And Some More
http://www.cardomain.com/ride/239875
Jurgen is offline
post #19 of 90 (permalink) Old 01-21-2009, 11:39 PM
R8D-XXX's Avatar
And me, my brother, my dad, and most of my friends LOL but still love the bird
pics of my car
Updated 10/14/11
13.0 @ 106.5 1.79 60ft
R8D-XXX is offline
post #20 of 90 (permalink) Old 01-22-2009, 06:08 PM
"transam396" Why bother with a Tbird, you can get a TransAm to 300 RWHP much cheaper. My 98 has 320 crank HP stock.
1995 PI Tbird
1995 Lincoln Town Car
1998 TA Vert
2004 Buick Regal GS
2000 Honda ST1100
1990 Mazda RX-7 2+2
Dusty is offline
post #21 of 90 (permalink) Old 01-22-2009, 07:36 PM
nickmckinney's Avatar
3C = Cams, Compression, Converter
Plus a few other tweeks but all 3 of the above are needed in that chassis.
The Trickflow heads will be nice but I wonder how they will perform with the stock plastic intake. The TFS intake has proven to slow down N/A cars that don't shift at least 7000RPM. I will be playing with them myself as soon as they start shipping. If they don't have much gain with the stock plastic intake then its going to be 7000RPM motors only if N/A.
nickmckinney is offline
post #22 of 90 (permalink) Old 01-22-2009, 11:52 PM Thread Starter
The only Transam's I really like are the 3rd gen preferably 89-92 or the 4th gen 98-02 with the WS6 package ...that is one mean looking car.
Problem is I have my T-Bird,I love my T-bird and I'm not intrested in swapping to GM's and couldn't afford to do it right now ....Now I would Love to have a 95 5spd SC but finding one in decent shape is tough . And my bird is in good shape and I ain't getting rid of her.
So I'm going to start planning a build and watcing what other guys are doing and see what I can come up with
post #23 of 90 (permalink) Old 01-23-2009, 12:16 AM
Like Titles Matter
kdanner's Avatar
EFI Tuners Organization Administrator/Gatekeeper
1996 Thunderbird LX- 12.54@106.08 NA
1998 GT - 11.51@122
2001 Lightning - 12.15@110
1996 GT 248A - ?@?
2011 GT - 10.46@129.38 180 MPH at the Texas Mile
generated by sloganizer.net
kdanner is offline
post #24 of 90 (permalink) Old 01-23-2009, 01:39 AM
kraken2026's Avatar
Send a message via AIM to kraken2026 Send a message via Yahoo to kraken2026
ok guys I got a 92 firebird and a 94 T-bird.... I love them both but I got two words for you...ride quality. For a daily driver the T-bird wins hands down and the interior layout is much better. The f-bird is like riding on a slab of cement on long trips, the t-bird feels like I am floating on a nice matress.
-94 T-bird 4.6L SOHC "Driver"
Full Pioneer sound system, 3rd muffler delete, PBR front Calipers, Rear disc conversion, Strut Tower Brace, Marauder Torque converter, True CAI & Silencer removal w K&N.
Planned upgrades: SC trac-loc pumpkin, Magnaflow SS mufflers & SS resonator tips, SC ground effects.
-93 Eddie Bauer Bronco
5.0L, E4OD, FatBob 2" Suspension lift, K&N CA, 2-1/2" flowmaster exhaust, sixliter ignition, 96 EB interior, Alcoa rims with 33's.
-92 Firebird 5.0 TBI, 4L60 "Project"
Accel / Holly Annihilator ignition, Dynomax cat back, adj. panhard Bar & T/A Sways, Formula 17x8 Rims, LT1 4L60 conversion, rear disc w posi conversion.
What can I say, birds of a feather flock together
kraken2026 is offline
post #25 of 90 (permalink) Old 02-26-2009, 03:33 AM
Thunderstruck95's Avatar
Get a used PI 5.4, add 270 cams, choose an intake, and get a tune. THIS WILL GIVE YOU 300+ HP.
Thunderstruck95 is online now
post #26 of 90 (permalink) Old 02-26-2009, 03:38 AM
Slightly Disjointed
Uh, no it wont.
post #27 of 90 (permalink) Old 02-26-2009, 07:18 AM
I choose an early aluminum NPI intake off an 94 bird....will that get me there?
think before you speak, and some research next time.
post #28 of 90 (permalink) Old 02-26-2009, 08:09 AM
funnyfingers's Avatar
Send a message via AIM to funnyfingers
http://www.seanhylandmotorsport.com/..._engines.shtml
http://karkraft.com/engines.htm
15.3s@89.97 mph
Current Modifications:
Air intake/9inch cone filter
Modified MAF (post cut out, sampling tube drilled to 29/64")
99 GT PBR Brakes with cross-drilled slotted rotors
Modifications soon to be put in:
3.73 ring and pinion (used)
Trac-Loc Differential (used)
SSA headers
funnyfingers is offline
post #29 of 90 (permalink) Old 02-26-2009, 09:05 AM
that was too funny..LOL
guys read this post:
95 Swap to 5.4L
and read the last sentence of one of my replies a couple posts down:
95 Swap to 5.4L
so where is this 300+ HP 5.4 that was sitting in your barn?....it's been 15 months since then....i wanna see a stock headed pi 5.4 with cams and ANY intake break 270 at the wheels (300 ish at the crank)
hell read that whole thread...its funny
post #30 of 90 (permalink) Old 02-26-2009, 09:41 AM
and here is that thread....
http://forums.tccoa.com/showthread.p...42#post1049842
