move along people, nothing to see here - Page 2 - TCCoA Forums
 5Likes
post #31 of 144 (permalink) Old 09-28-2012, 03:58 PM
Slightly Disjointed
Originally Posted by ThunderChecken View Post
Top of the pistons looks like sand-paper
They're phenolic, you know, like brake caliper pistons
post #32 of 144 (permalink) Old 10-03-2012, 09:28 PM Thread Starter
Moderator & Teksid Whore
guitar maestro's Avatar
word to the wise. The TFS valve spring tool is USELESS with these Stage III springs. They are just too massive compared to stock. The curved "claw" on the TFS spring tool has absolutely no chance to get situated on the underside of the camshaft. Can't slide it under there because you're already trying to push against massive valve spring pressure.
So I copied a design I saw and whipped this up real quick today.
It's not finished though. I need to drill out 3 more holes and get some washers so as to be able to do 4 springs at a time. The two springs that are done I did with my old valve spring tool, the one that looks like a mini coil-spring compressor with the turn-handle on top. PITMFA.
guitar maestro is offline
post #33 of 144 (permalink) Old 10-03-2012, 10:05 PM
Wow! Those are massive springs!
Outstanding work and attention to detail!
post #34 of 144 (permalink) Old 10-04-2012, 06:29 AM
Send a message via AIM to LoadedButane Send a message via Yahoo to LoadedButane
wow @ those springs
great build...I love following these
Geoff
1995 Mercury Cougar
~Mark VIII Trans with jmod + converter, 255lph fuel pump
~heads, cams, and intake in the distant future or when I break something
LoadedButane is offline
post #35 of 144 (permalink) Old 10-04-2012, 06:07 PM
nall_one's Avatar
yeah, those valves wont be floating any time soon your going to be able to rev the nuts off this motor. and their all pretty and shiny
95 Deep Jewel Green 40th Anniversary Bird / Stock SOHC 170k FRPP PI intake swap, filter relocated! 97 Mk8 4R70W, Jmod, 3L27 / energy susp rear spindle, and cobra arm bushings, Tru-Cool Max/radiator cooler bypassed, 93 Mk8 shaft, and LCAs, 225/60r16 Michelin Defenders on Windstar twin 5spokes, Vogtland 1.6drop springs, Tokico Blues, PBR, and rear-disk swap, 89 SC swaybars
nall_one is offline
post #36 of 144 (permalink) Old 10-04-2012, 09:05 PM
CableguyJJS3's Avatar
Send a message via AIM to CableguyJJS3 Send a message via Yahoo to CableguyJJS3
I'm missing something, are you trying to install those springs?? If so is there another part to that spring compressor you built? The angle looks like the bolt is pointing right at the tip of the valve, not seeing how you compress the springs like that... And not surprised about that goofy little compressor in my kit, didn't work very easily on the normal upgrade beehive springs I had in my heads. Luckily I only needed to mess with a couple for checking PTV cleanances. The springs your trying to use look like they belong on the suspension, good grief man.
Ban low performance driver's, not high performance cars.
"Any idiot can make a Mustang fast, but it takes a special kind of idiot to make a Thunderbird fast."
CableguyJJS3 is offline
post #37 of 144 (permalink) Old 10-04-2012, 10:03 PM
Slightly Disjointed
He's copying this
post #38 of 144 (permalink) Old 10-04-2012, 10:07 PM
jhiland32's Avatar
Glad to see there are people around that know how to properly assemble and engine . Being detailed and extremely clean in everything makes a big difference in HP/Torque and longevity of your build.
Great work GM !
Jason H.
Mods:
jhiland32 is offline
post #39 of 144 (permalink) Old 10-04-2012, 10:10 PM
Well now that makes total sense. The pic above doesnt show that round cup part of the equation, thats what I was missing. And for the record thats a million times better of a tool setup for swapping valve springs that that goofy TFS tool. And seeing the flat plate and drilling and tapping the holes, a way better alternative in my opinion, and by far cheaper. Good job man I'm impressed.
post #40 of 144 (permalink) Old 10-04-2012, 11:42 PM Thread Starter
yea it wasn't complete when I snapped that pic. Some of the angles are a bit off since I don't have a mill to cut a flat before drilling/tapping the angled bolt holes. I'm using washers under the plate to adjust the angle.
I had bought one of those TFS tools too, from MHS.
Anyone want a TFS valve spring tool for $20 shipped? works great on anything but these springs, lol.
post #41 of 144 (permalink) Old 10-05-2012, 11:14 PM
See I knew it, you was trying to intentionally confoose me, whats up with that man?? You checkin to see if I was payin attention, lol. You know you aint gonna trip me up on silliness like that.
post #42 of 144 (permalink) Old 10-16-2012, 11:58 PM
Black_Cat's Avatar
Any updates on the engine build?
I drive an endangered species...they are being crushed at an alarming rate. Please do your part to preserve the Cougar species, and ensure they live on into the future.
1995 Mercury Cougar XR-7 4.6L 2V 5 Speed
1998 Lincoln Mark VIII LSC Collector's Edition Car#94
Black_Cat is offline
post #43 of 144 (permalink) Old 10-17-2012, 12:09 AM
Works great on anything but these springs, lol.
LOL
post #44 of 144 (permalink) Old 10-17-2012, 02:19 AM Thread Starter
the update is that there is no update, lol. Still fighting the springs. The problem with my tool, I found, was since my angle was not dead on (I don't have access to a true mill), the constant turning of the bolt through the plate with a radial load on it caused metal shavings. It will compress the spring with the square tubing deal that I made alright, but I don't want to risk shavings working their way down into the bottom end.
post #45 of 144 (permalink) Old 10-18-2012, 04:33 PM
Black_Cat's Avatar
Sad Panda
post #46 of 144 (permalink) Old 11-01-2012, 08:02 PM Thread Starter
took a break from working on the engine. Needed to get outdoors now that the weather is semi-nice around here.
(This is/was a stock Mark VIII oil pan BTW)
who can tell what I'm doing?
post #47 of 144 (permalink) Old 11-01-2012, 08:22 PM
If I didn't know any better (which I don't) I'd say you were going to calculate the volume of that beastie.
97 Laser Red Thunderbird LX 155k, Stage 2 4.6L 2v N/A | 300 BHP (255 RWHP, 290 RWTQ) | 13.95 @ 97.58 | Build details | Pics at the Lorain Assembly plant
96 Ivory Mark VIII 230k, stock 4.6 32v on coils; New engine at 185k
post #48 of 144 (permalink) Old 11-01-2012, 08:43 PM Thread Starter
that part is done (the calculating). But I meant the overall "goal" of this part of the build.
post #49 of 144 (permalink) Old 11-01-2012, 09:05 PM
Slightly Disjointed
Dry sump conversion!
post #50 of 144 (permalink) Old 11-02-2012, 12:31 PM Thread Starter
post #51 of 144 (permalink) Old 11-02-2012, 01:33 PM
r429460's Avatar
Bung...................................hole.
Quickest N/A Modular MN12.
11.97@ 109.35
3880 lbs. w/driver.
Bradenton Spring Brake Shootout 03/04/2017.
r429460 is offline
post #52 of 144 (permalink) Old 11-02-2012, 02:19 PM
Did you ever coat that pick up tube?
Don't forget to cauclulate for the reduced volume of lubricant caused by the area of the tube plus or minus .001 to .002 based on whether or not you coated it.
post #53 of 144 (permalink) Old 11-02-2012, 03:54 PM Thread Starter
lol
where is everybody? or does no one get what I'm doing? and I'm not adding a bunghole. lol
.... reduced volume of lubricant.....
with this modification, that's the last thing I'll need to worry about
post #54 of 144 (permalink) Old 11-02-2012, 04:28 PM
Custom User Title
8 Quart oil capacity ?
dDUBb is offline
post #55 of 144 (permalink) Old 11-02-2012, 05:29 PM Thread Starter
ding! ding! ding!.......I'm going for 8+ qts.
post #56 of 144 (permalink) Old 11-02-2012, 06:24 PM
Going for 8+ qts AND keeping it all out of windage. Good stuff, GM.
Delete my account.
94 Thunderbird XX is offline
post #57 of 144 (permalink) Old 11-02-2012, 07:11 PM Thread Starter
Most importantly, its gonna be IN the oil pan where it is needed, not taking its sweet time on a merry-go-round cruise through hundreds of feet of remote oil filter hose, lol.
post #58 of 144 (permalink) Old 11-03-2012, 01:40 PM
r429460's Avatar
The best theory is a deep sump.
Unless you are going to put on two of the MK8 oil pan volume expander thingies.
11.97@ 109.35
3880 lbs. w/driver.
r429460 is offline
post #59 of 144 (permalink) Old 11-03-2012, 01:50 PM
Custom User Title
I'm a winner .. whats my prize ? Help with my math homework ?? LOL
Looks like a good design and your welding is better than most of what I have seen on this site.
dDUBb is offline
post #60 of 144 (permalink) Old 11-03-2012, 02:42 PM Thread Starter
yea sure; I ain't about to buy you a prize that's for sure
Thanks, and that was with a POS harbor freight welder. I had it setup outside to demo it to a prospective buyer on video. Ending up finally selling it, lol.
