move along people, nothing to see here - Page 3 - TCCoA Forums
 5Likes
post #61 of 145 (permalink) Old 11-03-2012, 03:17 PM
Custom User Title
Originally Posted by guitar maestro View Post
yea sure; I ain't about to buy you a prize that's for sure
Its all good, Im satisfied with seeing good progress being made on the project with quality work.
dDUBb is offline
post #62 of 145 (permalink) Old 03-07-2013, 09:49 PM Thread Starter
Moderator & Teksid Whore
guitar maestro's Avatar
So the saga continues......amongst the multitude of things I'm working on simultaneously....
My shot at expanding the oil capacity.
Here is the first rendition that needed some work....
So, I modified it to clear the eccentric bolt for the LCA and the hole for the rear nut on the rack and pinion bolt...
After yet a little bit more modification (cut a corner off to not have it too close to the longtube headers), and getting a little more length on the narrow part on it in order to grind it down to match the contours of the oil pan down by the drainhole, I pretty much have it ready for final fit-up and final grinding
Obviously, it's just tack-welded right now. I'm waiting on a special long-nozzle TIG welding ceramic cup in order to get into the top-side weld that is near the mounting flange of the oil pan. Very little space there.
By the time the nozzle gets here, I should have the panel for the main opening that will contain the one-way trap doors to let oil in at the top, and only let oil out at the bottom.
More to come very soon.....
guitar maestro is online now
post #63 of 145 (permalink) Old 03-07-2013, 10:09 PM
Nice work! How much do you expect that to hold? An extra quart or two?
post #64 of 145 (permalink) Old 03-07-2013, 10:36 PM Thread Starter
Hoping to get close to 1.5. Crossing my fingers since I can't do much to the other tumah on the passenger side that is already there--too cramped near there.
post #65 of 145 (permalink) Old 03-07-2013, 10:51 PM
Looks good. Only thing I see is, is the top side slanted down towards the outside so it doesn't trap any air?
1995 SC------------------1994 SC----------------1993 LX
Black----------------------Red----------------------Grey
3.8-------------------------3.8w/bent rod---------5.0
4R70W--------------------M5R2--------------------AOD
2.4 AR in works---------2.0 Auto Rotor---------N/A
24psi----------------------15+----------------------none yet
450RWHP----------------300RWHP est.---------who knows/who cares
10.740@127------------13.842@103.08-------16.1@
BLOWN38 is offline
post #66 of 145 (permalink) Old 03-07-2013, 11:05 PM
r429460's Avatar
by the time this box is running I'll be on my ......................
12.06@110.38.
Quickest N/A Modular MN12.
11.97@ 109.35
3880 lbs. w/driver.
Bradenton Spring Brake Shootout 03/04/2017.
r429460 is offline
post #67 of 145 (permalink) Old 03-07-2013, 11:41 PM
By the time his box is running I'll have my money on a faster then 12 second time slip. Oh no he didn't!
post #68 of 145 (permalink) Old 03-08-2013, 12:14 AM Thread Starter
you can can sorta tell in the 4th pic where the top is slightly slanted down, about 5° from the horizontal.
12.06@110.38.
That's fine. I have the rest of my life to claim the fastest N/A 4.6 MN12. I dunno about you though...
that's about all you can hope for
post #69 of 145 (permalink) Old 03-08-2013, 12:14 AM
Great pictures and videos.
"The truth is,everyone is going to hurt you.You just got to find the ones worth suffering for." Bob Marley
FranklinMint is offline
post #70 of 145 (permalink) Old 03-08-2013, 08:23 AM
by the time he gets his done, mine will still not be finished
post #71 of 145 (permalink) Old 03-08-2013, 08:37 AM
Old_Fashioned_Cat's Avatar
Looks good! How much clearance did you get between the k member and the extension? It looks really close.
Ryan
1997 Cougar XR7 30th Anniversary Edition
Stock 4.6, Tokico Blues, lowered 1.25", 2.5" high flow catback exhaust
2013 Escape (daily driver)
2.5L
Old_Fashioned_Cat is offline
post #72 of 145 (permalink) Old 03-08-2013, 09:02 AM
LOL
Watching your and GM's projects proceed is like watching paint dry. ... only slower.
post #73 of 145 (permalink) Old 03-08-2013, 11:24 AM Thread Starter
It is really close, about 3/8". Wish there was more room or other oil pan options, but it is what it is.
post #74 of 145 (permalink) Old 03-08-2013, 11:31 AM
Are you dropping your engine and trans together or one piece at a time? I had a hard time squeezing both in because of the extra quart tank on the Mark VIII oil pan. It was hitting the motor mount on the passenger side. Not sure if yours is bigger or smaller for the driver side.
post #75 of 145 (permalink) Old 03-09-2013, 02:21 AM Thread Starter
What I did was install the transmission attached to a dummy block with no oil pan. With the trans installed i can drop the engine w/oil pan straight down pretty much. I do this several times a week while working on this stuff and while I was doing the longtube headers.
post #76 of 145 (permalink) Old 03-22-2013, 06:34 PM Thread Starter
Before I post the final pictures of the oil pan mod, who wants to play the guessing game? I will give an absurd amount of money to whoever guesses the capacity of this extra sump! (down to a tenth of a quart)
Here I filled it up with acetone to make sure there were no leaks (of course there weren't), and to see how much liquid it would take to pretty much fill it up to the level that corresponds to the weld point that will attach it to the oil pan.
post #77 of 145 (permalink) Old 03-22-2013, 07:11 PM
95LX4.6's Avatar
2.565
95 LX: "Midnight" Photo thread: http://forums.tccoa.com/30-videos-images/137962-midnight-has-arrived.html *SOLD*
95LX4.6 is offline
post #78 of 145 (permalink) Old 03-22-2013, 07:51 PM
The_coop_08's Avatar
Send a message via AIM to The_coop_08
2.758 Quarts
Silver 1996 T-bird
Major Mods: Stage II PI head swap w/Stage II cams, Kooks headers, 2.5" exhaust with borla xr1, 9.5" Converter 3800 stall, Aluminum rear 3:73 gears, lots of suspension and bolt ons. 13" Cobra brakes, ss lines, lowered 1.6" on staggered saleens
Tim Barth tuned at MPH 274rwhp/298rwtq on 93
--Coop--
Vortech build in progress
The_coop_08 is offline
post #79 of 145 (permalink) Old 03-22-2013, 09:08 PM
I'll go with 3 qts
BLOWN38 is offline
post #80 of 145 (permalink) Old 03-22-2013, 09:17 PM Thread Starter
lol
besides 3 people being disqualified for not listening to instructions about only specifying a tenth , you all might want to reconsider this picture where you can see it's size in relation to my hand (I have small hands)
post #81 of 145 (permalink) Old 03-22-2013, 10:13 PM
.9 quarts.
RalphP is offline
post #82 of 145 (permalink) Old 03-22-2013, 10:39 PM
1996Project-bird's Avatar
1.4
1996Project-bird is offline
post #83 of 145 (permalink) Old 03-22-2013, 10:59 PM
1.6
AlanE is offline
post #84 of 145 (permalink) Old 03-22-2013, 11:08 PM
Mgino96tbird46's Avatar
that's a game changer.
1.2 quarts
1996 Thunderbird LX. Gone, but not forgotten Oct 1995-March 24 2016
1998 Mustang GT premium. Auto, stock, and slow. Daily beater.
Mgino96tbird46 is offline
post #85 of 145 (permalink) Old 03-22-2013, 11:18 PM Thread Starter
Well, that picture was posted before when I uploaded the pics when I was constructing it. Just thought I'd remind you all I'll post the welded-to-oil pan pics tomorrow and tell ya what I found for the capacity.
post #86 of 145 (permalink) Old 03-23-2013, 12:13 AM
1.1
post #87 of 145 (permalink) Old 03-23-2013, 05:44 AM
2.0 quarts
post #88 of 145 (permalink) Old 03-23-2013, 09:22 PM Thread Starter
Ralph and ChrisMurder are the winners. I was able to get 1.0 quarts to that fill line, which I consider full because it is partially inserted into the oil pan. Those were the two closest ones. To claim your absurb amount of prize money, all I need is your checking acct and routing # so I can wire the funds from Zimbabwe & Uganda from a fortune I have inherited
7qts total. With a cool little trap door. I'll take it.
post #89 of 145 (permalink) Old 03-23-2013, 09:40 PM
Seasoned Geek
LOL good one there Zod
post #90 of 145 (permalink) Old 03-23-2013, 11:25 PM
rushtonracing's Avatar
Interesting. Humbly, with all due respect to the builder, a dry sump system would be superior.
rushtonracing is offline
