move along people, nothing to see here - Page 5 - TCCoA Forums
 5Likes
post #121 of 145 (permalink) Old 06-18-2014, 06:11 PM
Did you see the thread about the manual steering? (Steering was on your list...)
I've seriously been considering it; I'd hotwire the variable system if it wouldn't melt, lol.
Thoughts?
post #122 of 145 (permalink) Old 06-18-2014, 06:26 PM
Thanks for the update, GM.
I know that life happens!! lol
Dusty Rusty is offline
post #123 of 145 (permalink) Old 06-18-2014, 06:43 PM Thread Starter
Moderator & Teksid Whore
guitar maestro's Avatar
Thoughts?
I wasn't gonna modify the steering, I just wanted to get it nice and tight like when it wasn't so old, lol.
guitar maestro is offline
post #124 of 145 (permalink) Old 06-18-2014, 07:27 PM
Slightly Disjointed
Thoughts?
I've been considering it lately too but the cost of the Flaming River racks are ludicrous and you have to supply tie rods(inner and outer) and a matching Flaming River U joint. I'd really like to drive an MN12 with it before I'd shell out the $500 or so it would cost when everything's said and done, I don't mind the slower ratio(I'd prefer great road feel and and extra turns to numbness and less turns anyday)but the effort part has so much conflicting experiences that I don't trust a word of it anymore, especially since I run 255s up front, and don't plan on going any less than 245s in the future.
An adjustable EVO module would be sweet. Max assist under 5 mph and "off" anywhere past it
post #125 of 145 (permalink) Old 06-18-2014, 07:35 PM
I wonder if anyone's tried to reprogram the EVO on our cars...
post #126 of 145 (permalink) Old 06-18-2014, 07:38 PM
I'll be doing the manual steering conversion soon on my 90 SC. As with anything I do, I have to look for a cheaper way, so I'll let you know my parts sources and feedback once it is done.
post #127 of 145 (permalink) Old 06-18-2014, 09:01 PM
Originally Posted by theterminator3 View Post
I wonder if anyone's tried to reprogram evo on our cars...
Maybe replace the evo computer or rig up an adjustable switch or knob similar to what the lincoln town cars got from the factory.
post #128 of 145 (permalink) Old 06-18-2014, 11:20 PM
Slightly Disjointed
Town cars got adjustable EVO? hmmm... Might have to go yard hopping soon
post #129 of 145 (permalink) Old 06-19-2014, 12:08 AM
Yes, I personally have no experience with it, I just know its a sliding lever for adjustable steering effort.
post #130 of 145 (permalink) Old 06-21-2014, 07:52 PM
I don't have an evo box; I know the solenoid is pwm, and if the box goes bad it smokes the solenoid.
There would be a circuit that reads the VSS signal, and decides what to do.
We could re program it, with an effort to ID the circuitry.
There's also a sensor that reads steering input, and I'd bet braking comes into it as well.
If someone posted really good pix of both sides of a 96 EVO box, I have the wiring book, I could look at the circuitry.
post #131 of 145 (permalink) Old 06-21-2014, 08:51 PM
Slightly Disjointed
This is a 94 module(not sure if it's the same for 96)
post #132 of 145 (permalink) Old 06-21-2014, 09:30 PM
Rayo's Avatar
EVO Module
The 96-97 MN12's used a different EVO Module..
Rather than it being mounted in the trunk like before (89-95)...It was moved under the heater blower motor case..
No..I don't have any close-up pics..
1991 Ford Thunderbird Sport
Rayo is offline
post #133 of 145 (permalink) Old 06-21-2014, 10:31 PM
Slightly Disjointed
I knew that, but that's not to say the circuit changed
CDsDontBurn likes this.
post #134 of 145 (permalink) Old 06-22-2014, 12:58 AM
Rayo's Avatar
Steering Diagrams
Maybe this will help..
1994 MN12 Steering Diagram
1997 MN12 Steering Diagram
Rayo is offline
post #135 of 145 (permalink) Old 06-22-2014, 01:07 AM
Slightly Disjointed
This helps more
(96 EVTM left, 94 EVTM right)
Note the connector. I guarantee all that changed on the module in 96 was the outer case for the mounting.
post #136 of 145 (permalink) Old 06-22-2014, 01:30 AM
Rayo's Avatar
The 89-95 EVO Modules did use a different case with different mounting points compared to the 96-97 EVO Modules..
So you could be right..The guts could be very similar..
Only way we'll ever know is if someone cracks one of the 96-97 EVO Modules open, and gets some gut shots of it..
I just posted the diagrams in case you guys need them to make some sort of "hybrid" EVO Module..
Good Luck..
Rayo is offline
post #137 of 145 (permalink) Old 03-05-2017, 02:36 PM
Rayo's Avatar
This seemed appropriate here, since you don't have an "official" build thread..
Grog6 and CDsDontBurn like this.
Rayo is offline
post #138 of 145 (permalink) Old 03-21-2017, 02:24 PM
I know this is an older thread but what main and rod bearings did you use?
sceholmes97 is offline
post #139 of 145 (permalink) Old 03-21-2017, 04:08 PM
CDsDontBurn's Avatar
http://i790.photobucket.com/albums/y...pscl4n4rkv.jpg
How many of us does this apply to, though?
CDsDontBurn is offline
post #140 of 145 (permalink) Old 03-21-2017, 05:00 PM
I can't believe he hasn't edited all the random BS we put in his thread, lol.
I think all of his time and interest has shifted to frame and body work; I have no idea what Her name is.
Rayo, there is a Pantera sitting at the entrance to my "Subdivision" completely glassless, that I've watched rust away over the last few years; it kills me.
What movie is that from? I remember that scene...
post #141 of 145 (permalink) Old 03-21-2017, 05:38 PM
Slightly Disjointed
Kill Bill II. That's not a Pantera though, that's a Mangusta
post #142 of 145 (permalink) Old 03-21-2017, 06:21 PM
Oops.
post #143 of 145 (permalink) Old 03-21-2017, 07:47 PM
Originally Posted by grog6 View Post
i can't believe he hasn't edited all the random bs we put in his thread, lol.
I think all of his time and interest has shifted to frame and body work; i have no idea what her name is.
lol
Grog6 likes this.
post #144 of 145 (permalink) Old 03-23-2017, 02:07 PM
Mach1Motorsports's Avatar
This is an awesome post. Great pictures and notes and details. I barely have gotten thru the first page but will when I have more time.
Thanks again. This is such great information that is not even in some of the 4.6 articles I have read.
96 Saleen Cobra 55k
98 Mark VIII 91K
97 Mark VIII LSC 175k
94 Mark VIII 122k
84 Bronco 351 HO 115K
66 Mercury Monterey 390
49 Lincoln 2 dr
70 Mustang Mach 1 351C 4V Restored
Mach1Motorsports is offline
post #145 of 145 (permalink) Old 04-12-2017, 03:27 AM
Rayo's Avatar
Don't feel bad Grog, I always just assumed it was a Pantera too..
That's a shame, about the one near you rusting to pieces though..
I've always like the Pantera, and I guess the Mangusta too..lol
I used to frequently drive up to the Henry Ford Museum, and often seen a pair of Pantera's parked outside..
Rayo is offline
