Decision time - Page 6 - TCCoA Forums
 142Likes
post #151 of 289 (permalink) Old 07-20-2016, 08:01 PM
Originally Posted by Woodman View Post
So what makes the Motorcraft timing set worth $400?
That's not even the good sliders, or anything.
On my 2V PI motor, I used these:
OEM Ford 4.6L 2V Curved Timing Chain Guides
And these:
OEM Ford 4.6L Plastic Backed Straight Timing Chain Guides
OEM Ford 4.6L Primary Timing Chain Set
TFS-51800505
TFS, baby!
I still do as much business as I can with these guys.
RIP, Nick!
EDIT: Crap, MMR has a similar kit for $219.99; but they still aren't the good sliders:
http://www.modularmotorsportsracing....roducts_id=165
Summit is way overpriced there!
CDsDontBurn likes this.
post #152 of 289 (permalink) Old 07-20-2016, 08:04 PM Thread Starter
Woodman's Avatar
And these:
TFS-51800505
TFS, baby!
RIP, Nick!
I am getting the MHS cams, the adjustable crank gears, and the degreeing service from them. Didn't realize they would piece a set together. Should I get new tensioners?
Woodman is offline
post #153 of 289 (permalink) Old 07-20-2016, 08:51 PM
Slightly Disjointed
Didn't see your earlier reply.
So I may not even need to replace the chains?
I don't find it necessary, the chains and steel tensioners are proven million mile components. These aren't Hondas
Woodman likes this.
post #154 of 289 (permalink) Old 07-20-2016, 09:07 PM Thread Starter
Woodman's Avatar
Well, that saves me $400
Woodman is offline
post #155 of 289 (permalink) Old 07-23-2016, 05:50 PM Thread Starter
Woodman's Avatar
There is a 2003 Explorer motor, complete with wiring harness, ac compressor, power steering, hell it even has the cruise servo, currently sitting in my garage.
$300 and half a tank of gas. The yard I got it from fired it up, read the codes and told me the only one it had was for the TPS, which I'm not worried about as I put a brand new motorcraft one on my motor last year.
Got it hooked out of the back of my work van and rolled it into the garage. Headers will ship next week, I am a happy camper!
Woodman is offline
post #156 of 289 (permalink) Old 07-24-2016, 10:22 PM Thread Starter
Woodman's Avatar
And I just scored a set of 24lb/hr injectors for $100. Look brand new!
Woodman is offline
post #157 of 289 (permalink) Old 07-25-2016, 09:50 PM Thread Starter
Woodman's Avatar
And the big tube Kooks are on their way too!
Woodman is offline
post #158 of 289 (permalink) Old 07-26-2016, 09:54 AM
CDsDontBurn's Avatar
I'm sure all of us feel that way when the most wanted of parts we want are on their way
Woodman likes this.
CDsDontBurn is offline
post #159 of 289 (permalink) Old 07-26-2016, 12:04 PM Thread Starter
Woodman's Avatar
To say I'm excited is beyond understatement.
The hard part is waiting for the ability to pay for the cams so I can start putting it all together!
Woodman is offline
post #160 of 289 (permalink) Old 07-26-2016, 01:16 PM
Can't you start cleaning engine first before you start putting it together? It's something I'd do so that my engine looks as purdy and shiny as possible before it goes into the engine bay. If you do, brake cleaner....and lots of it....will be your best friend
Woodman likes this.
post #161 of 289 (permalink) Old 07-26-2016, 01:33 PM Thread Starter
Woodman's Avatar
Oh yeah, there's all kinds of stuff to do before I get the cams, I just meant the whole "getting it together" as in dropping it in the car, flashing the tune, and firing it up.
I need to autopsy the old motor, see what died and what is still usable. Put in a new oil pump, water pump, swap oil pans, get new sensors, bolt up the AC, get the stuff to charge the AC, learn how to do the timing, etc.
I'll buy a good supply of brake cleaner and go to town too. Should I tape off any ports, or doesn't that matter at this stage? Might paint the motor, but I do know that'll require taping things off.
Woodman is offline
post #162 of 289 (permalink) Old 07-26-2016, 01:50 PM
Slightly Disjointed
Takes 1 minute and 3 feet of tape to tape them shut, cheap insurance. I spent half a day cleaning out dust and leaves that accumulated in my 4Vs intake ports during the brief period I left it at the wrecker's warehouse(should have just left the intake on in hindsight).
If you paint it mask around the machined areas, all of them, and prep prep prep prep. With the huge heat cycles of engines if there's a spot that the paint hasn't bonded to it's going to flake off immediately. So get out the brushes, soap, degreasers and mag wheel cleaners(those etch the block). Personally though, aluminum block, aluminum heads = leave bare. You can't see them anyway in this chassis.
Woodman likes this.
post #163 of 289 (permalink) Old 07-26-2016, 05:10 PM
For me though, even if it won't ever be seen, you'll know if the work was done right and not half assed.
Woodman likes this.
post #164 of 289 (permalink) Old 07-26-2016, 06:14 PM
Slightly Disjointed
Oh I'm just saying leave bare period, not to half ass the prep.
Woodman likes this.
post #165 of 289 (permalink) Old 07-26-2016, 06:24 PM
Gotcha. That works too. Painting gives it another type of nice look, but painting is also another layer of work that is completely optional and will add cost to the overall build, even if it's minuscule in comparison to the cost of the overall build.
Woodman likes this.
post #166 of 289 (permalink) Old 07-26-2016, 09:49 PM Thread Starter
Woodman's Avatar
So guys, give me a realistic estimate based on what I'm installing for crank horsepower.
Explorer block, PI heads.
MHS Stage 2 PI NA cams, degreed with TFS adjustable gears.
Kooks 1.75" primary, 3" collector headers necking down to 2.5" mandrel bent dual exhaust with midmount dual in/out magnaflow and chambered mufflers at the pipe exits. No catalysts.
24# injectors
Underdrive pulleys
.5" plenum spacer (it's already on the car, don't hate!)
75mm Throttle body and elbow
Don Lasota canned tune until I get a dyno tune
I'm hoping for around 320hp at the crank. Seem realistic?
Woodman is offline
post #167 of 289 (permalink) Old 07-31-2016, 10:35 PM Thread Starter
Woodman's Avatar
And she's OUT!
On the good news front, I was able to spin the crank via long breaker bar to get the TC unbolted, but she wasn't cranking via starter due to loss of oil, so the oil pan should HOPEFULLY come off tomorrow, and we'll see what we see.
More pics will follow
Woodman is offline
post #168 of 289 (permalink) Old 08-01-2016, 09:09 AM
Does this mean you'll probably be able to restore the engine after the donor engine is put in? Or will you take off the goodies first and then scrap the rest?
post #169 of 289 (permalink) Old 08-01-2016, 12:39 PM
Slightly Disjointed
Make a table out of it, that's what I'm going to do
post #170 of 289 (permalink) Old 08-01-2016, 07:13 PM Thread Starter
Woodman's Avatar
It is looking salvageable so far. I started the autopsy today.
Here's a few pics...
Water Pump, looks pretty good, much better condition than the one on the Explorer block. May just swap this one over.
Passenger side head, cams look good, but what's that about the forward girdle?
THAT doesn't look good. What would cause this?
Reference picture of the studs placement.
Ever hear of doctors leaving surgical equipment in the patient? I have a feeling that happened here. WTF is this, and what's it doing in my valvetrain? I know I haven't dropped anything down there!
Metalpalooza in the oil pan...
Bearing surfaces?
All conrods present and accounted for. That's good!
Pick up screen isn't doing so hot.
I'm not going to make a coffee table, nowhere to put it.
For removing the heads, do I need it at TDC? Does the front cover need to be off to get the heads off? Any special trick to removing the cam gear?
Woodman is offline
post #171 of 289 (permalink) Old 08-01-2016, 07:59 PM
Slightly Disjointed
That water pump doesn't look so hot to me, plus it's open vane.
The carnage to me looks like it may be either failed cam bores and/or piston, the metal in the oil pan looks aluminum. Are all 16 valves accounted for?
Yes take the timing cover off, you don't need to remove the cam sprockets, just compress the tensioners and lock em with a paper clip, the guides can then be removed giving full slack to the chain.
Before pulling the chains though I'd check where the timing's at, I'm thinking PTV on cylinder 1, or bad detonation. Hey, have you pulled the spark plugs yet? Those will tell a story.
Woodman likes this.
post #172 of 289 (permalink) Old 08-01-2016, 08:02 PM Thread Starter
Woodman's Avatar
I haven't looked closely at the valves yet. Will pull them Wedneday or Thursday. I'm off all week, but we have plans tomorrow, and my wife is off Wednesday too.
Woodman is offline
post #173 of 289 (permalink) Old 08-01-2016, 08:05 PM
The front cover needs to at least be loose to pull the heads, so you might as well pull it off completely. The motor does not need to be at any particular position to pull the heads. That cam girdle is part of the cam caps, so to replace it you will need to have the cam bore on that head align bored, which given the price of good used PI heads, unless these ones were ported, it probably isn't worth fixing them. Same goes for the bottom end, with all stock stuff it wouldn't be cost effective to rebuild it, and if you are going to build up a bottom end, might as well start with an aluminum block.
Woodman likes this.
post #174 of 289 (permalink) Old 08-01-2016, 08:15 PM Thread Starter
Woodman's Avatar
I have a complete 2003 Explorer motor sitting right next to it, so if it's effed up, it's getting scrapped or sold as a core. Not really planning on rebuilding it, just doing the autopsy while I wait for my new headers, new cams, etc.
How do I tell if the motor mounts are good? They wiggle a little, but they're rubber, so I figure they may be useable. Had no issues with them so far.
Woodman is offline
post #175 of 289 (permalink) Old 08-01-2016, 08:35 PM Thread Starter
Woodman's Avatar
Got a part number for a closed vane water pump?
Woodman is offline
post #176 of 289 (permalink) Old 08-02-2016, 06:40 PM
MMR Performance Water Pump for all 4.6 Mustang GT & COBRA [403430] - $99.99 : Modular Motorsports, Home of the Worlds Fastest Modular Engines
They have the short and the long version, so you can order for whichever pulley you have.
Woodman likes this.
post #177 of 289 (permalink) Old 08-02-2016, 09:18 PM Thread Starter
Woodman's Avatar
Thank you. I'm fairly certain it's short.
That's what is normal for a 97, right?
Woodman is offline
post #178 of 289 (permalink) Old 08-02-2016, 09:43 PM
Slightly Disjointed
Factory is long. Short is a 2000s thing
Woodman likes this.
post #179 of 289 (permalink) Old 08-02-2016, 09:52 PM Thread Starter
Woodman's Avatar
Thanks. I was going to measure it tomorrow.
Woodman is offline
post #180 of 289 (permalink) Old 08-03-2016, 04:28 PM
The long pulley looks like a Devo hat; the short one looks like a Heisenberg hat.
Stock is Devo-esque.
Heisenberg:
Devo:
Woodman likes this.
