Is This a Problem With The ECM? (97) - Page 2 - TCCoA Forums
post #31 of 39 (permalink) Old 12-27-2016, 01:17 AM
ikutoisahobo's Avatar
What are the IATs that you have?
ikutoisahobo is offline
post #32 of 39 (permalink) Old 12-27-2016, 02:09 AM Thread Starter
The inlet air temps? I'll check the next time I get the engine up to temperature. For right now it was 89°, but the car was warming up with a 192° water temp.
I got 2 new codes today, P0171 and p0174. Lean on both banks. Maybe my fuel pump is weak? It does make a weird sound sometimes, but the car has good power at high rpms where the fuel demand is higher. I don't know. I can try to drive around with a mechanical fuel pressure gauge attached to the fuel rail. Maybe it will show the pressure is low.
JasonWW is offline
post #33 of 39 (permalink) Old 12-27-2016, 06:37 AM Thread Starter
With a fully warmed engine driving down the road the IAT is 75°F, which is just above ambiant.
JasonWW is offline
post #34 of 39 (permalink) Old 12-27-2016, 08:34 AM
gordonm1's Avatar
The bucking sounded like an ignition miss or lean condition. It seems it only recently is giving you lean codes from your exhaust sensors though. Fuel filter could be plugging up. I don't know if driving around with a fuel pressure gauge hooked up will tell if it's a pump or the filter. You had the idea first.
I don't see where you have adjusted the TPS. It works with the IAC and I assume its closely involved with timing advance under partial throttle where you are bucking. With a multi-meter its free to check and adjust to correct voltage. There's good threads around here explaining how to do it.
I'd also verify your throttle body is closing the butterfly completely and is clean and moves freely.
gordonm1 is offline
post #35 of 39 (permalink) Old 12-27-2016, 09:45 AM Thread Starter
I just tested the fuel pressure and it's only reading 22 psi. When I hear the pump make its little whir sound every now and then the pressure jumps to 25 psi.
That's way too low, I'm sure. Is there a best place to get a new fuel pump?
The fuel filter is new from a few months ago.
JasonWW is offline
post #36 of 39 (permalink) Old 12-27-2016, 03:10 PM
Rockauto sells pumps and full assemblies. You can take the chance to upgrade to a Walbro as well (high flow fuel sells them in a kit)
post #37 of 39 (permalink) Old 12-30-2016, 05:01 AM Thread Starter
I found a complete Delphi pump assembly in stock at a nearby Autozone for $97.
I just got it installed yesterday. That seems to have cured all my new issues that appeared in the last 3 or 4 months. Timing is smooth and steady, like it should be. It's even cranking much quicker.
I guess its been going out slowly and acting weird, varying the output pressure.
Now I'm back to my original, small issues that I started this thread about.
JasonWW is offline
post #38 of 39 (permalink) Old 12-30-2016, 05:05 AM Thread Starter
I haven't done these things. Does it help in any way?
JasonWW is offline
post #39 of 39 (permalink) Old 01-01-2017, 10:57 AM
gordonm1's Avatar
I don't completely understand what the TPS does so I won't confuse you with bs. There is a specified voltage to check for and you check it with a multimeter and needle type probes that go into the electrical connections. This is on my 5.0 but I think I've read the 4.6 guys have a tps too. Mine was right next to the IAC.
You rotate the tps a bit to get the correct voltage. My aftermarket throttle body allowed more adjustment and it was necessary to adjust it for the new throttle body.
gordonm1 is offline
