Is This a Problem With The ECM? (97) - TCCoA Forums
post #1 of 39 (permalink) Old 06-16-2016, 07:28 AM Thread Starter
This is a 97 model Thunderbird with a 4.6 engine. Up until a few years ago I didn't have any of the following problems.
When in gear and stopped whenever I turn the steering wheel the idle speed drops way down and the whole car shakes.
On rare occasions the idle air control valve will make a wailing or moaning sound and the idle will get super choppy and usually die.
When cruising at a steady speed in 4th gear if I give it just a tiny bit of throttle I can just barely hear a little bit of knocking or detonating from the engine. A little more or less throttle will make it go away. Higher octane fuels don't seem to have any effect and I also pulled out the little computer chip on the right fender which affects the timing and that does seem to help reduce that knocking.
New plugs and wires seem to have no effect. I also tested the ignition coils and connectors and everything seems to be working properly in the ignition system.
I've also had the fuel injectors tested and ultrasonically cleaned then tested again and they all show to be working perfectly.
Recently I seem to be having some misfires on at least one cylinder which makes the car jerk under acceleration but it only does it when fully warmed up and between about 1500 and 2500 rpm.
In the past I suspected there was a vacuum leak so I tested all of the vacuum lines everywhere with a hand-held vacuum pump making sure there weren't any leaks anywhere and it all seems fine.
Does this sound like there's a problem with the ECM?
JasonWW is offline
post #2 of 39 (permalink) Old 06-16-2016, 07:58 AM
steamer471's Avatar
Look for a vacuum leak toward the purge canister on the right side of the fender well. There is a metal line that comes from the throttle body, follow it down to where there's a rubber hose that connects the evap system. That hose usually rots after 10 years. Also check the ones going to all the components down there. I would also consider replacing that IAC and clean the mas sensor(i believe that's the little "computer chip" you referred to.)
1997 Mark 8 LSC
Former owner:
1996 Thunderbird lx 4.6
1994 Thunderbird lx 4.6
steamer471 is offline
post #3 of 39 (permalink) Old 06-16-2016, 08:56 AM
T6Rocket's Avatar
X2 on cleaning the MAF, which should eliminated the pinging. That is different from the timing spout that was removed. You should be able to put it back in after cleaning the MAF.
You will need a tamper proof torx bit to remove the MAF sensor (Autozone sells it), and electrical cleaner and a Q-tip to clean it. A magnifying glass is helpful also.
Al
97 T-Bird LX 4.6 - 68k miles
Previous cars:
T6Rocket is offline
post #4 of 39 (permalink) Old 06-16-2016, 09:19 AM
My car did not have quite the same symptoms but in my case the MAF & connector, IAC and connector, purge valve solenoid, purge valve sensor, and purge valve associated hoses were all replaced to resolve idle/stall issues.
You'd probably be well served replacing all vacuum lines anyway, it's a cheap and easy thing to do.
Black '96 TBird - Dynotech 3.5" MMX DS, SCP mounts and brackets, Art Carr 4R70W transmission, DirtyDog 2800 stall TC, true dual exhaust w/FlowMonster mufflers
lurch is offline
post #5 of 39 (permalink) Old 06-16-2016, 05:58 PM
Put a vacuum gauge on it, and see what it reads.
See if pressing the brakes changes it, and how it changes.
If the MAF hasn't been cleaned lately, you need to clean it.
If it's never been "Seafomed", search that and do it.
You'll be amazed how much that matters.
Change the oil and filter after a seafoaming; it washes a bunch of crap into it.
post #6 of 39 (permalink) Old 08-07-2016, 05:29 AM Thread Starter
I'm sorry for not responding earlier, but I didn't receive any notifications.
I did have a leak in the long vacuum line going to the charcoal canister a few years ago. The leak was in the metal line and i couldn't fix it, so I bypassed it and ran a new rubber line from the intake directly to the fender well. Plus I replaced all the short lines around the canister as well.
I've cleaned the MAF sensor on a regular basis.
The computer chip I'm referring to controls the spark advance. If the engine starts pinging, you pull the chip out and it's supposed to limit spark advance. I believe this was designed for situations where you get some bad gas.
I've considered replacing the IAC, but they are so expensive that I didn't want to do it unless I knew it was bad. I've removed it and cleaned it well a few times.
JasonWW is offline
post #7 of 39 (permalink) Old 08-07-2016, 05:35 AM Thread Starter
Al
I'm a pro on cleaning the MAF. I can pop it off in less than 60 seconds. I also tend to pull the ecm fuse for an hour or so to reset the computer so it can relearn. This never seems to help my other issues.
JasonWW is offline
post #8 of 39 (permalink) Old 08-07-2016, 05:40 AM Thread Starter
I've never gotten any codes for the MAF or IAC. Did you get any codes which led you to replacing them and their connectors?
Every couple of months I'll get a code for the purge valve, but I just turn the code off. I once temporarily plugged off the vacuum going to the purge solenoid to see if that fixed the idle or any other problems, but it had no effect at all.
All my vacuum lines have been checked, no leaks.
JasonWW is offline
post #9 of 39 (permalink) Old 08-07-2016, 06:08 AM Thread Starter
I have very high and steady vacuum, around 18", at idle. I checked the vacuum lines and check valve going to the booster and they are solid, no leaks.
Maybe there is a leak under the intake manifold? Maybe a crack? I'd like to get a smoke machine, but they are hard to locate.
I did a Seafoam cleaning a couple years ago and it had no effect. Since then I've used an actual fuel Injector cleaning device. You hook up a air compressor, set the air pressure to 20psi or so, fill the bottle with a cleaning solution, like lacquer thinner, pull the fuel pump fuse and basically let the engine run solely on the cleaner. I did two 15 minute sessions and it had no effect on the the engines problems.
JasonWW is offline
post #10 of 39 (permalink) Old 08-07-2016, 07:46 AM
steamer471's Avatar
If you want to check the manifold for leaks you can take some carb cleaner and spray around it with the engine running and listen for the idle to increase if there's a leak. Some people say an unlit propane torch is safer and cleaner. Me, considering the time and effort already put into it, an IAC valve would not be an expensive alternative. You may want to pull it and check the gasket around it and try cleaning the valve. Also, the throttle body itself, my 96 got pretty gunked up at 100k.
1997 Mark 8 LSC
Former owner:
post #11 of 39 (permalink) Old 08-07-2016, 08:10 AM Thread Starter
I've tried checking the intake manifold gaskets for leaks with carb cleaner, and didn't find anything. I unplugged the IAC so I had a steady engine speed. When I talked about using a smoke machine it was to look for a crack underneath the manifold.
The last time I checked IAC prices they were $60+, but I see there are some cheaper units on the market from $30 to $40. That's not bad. Even though mine "works" it seems to react slowly, about a second too late. Like when the AC kicks on the idle drops too low for a second then it picks back up. It's annoying. I think I will get one and see what happens.
I'd like to confirm the ignition timing using a timing light and a rolling road to simulate it driving. It just seems like the computer is screwing things up on at least one cylinder.
Recently it's started bucking again under acceleration. I put all new plugs in just in case one of the old ones had a crack or something and no change. It's driving me crazy.
Maybe I could install a new crank position sensor. They are cheap at $10, but hard to swap out.
JasonWW is offline
post #12 of 39 (permalink) Old 08-07-2016, 08:18 AM
steamer471's Avatar
Bucking under a load also could be a spark plug wire. If you decide to buy a IAC I would stick with Motorcraft. Check the online sites for a descent price. I've only had luck with Motorcraft or Autolite wires and plugs. These cars are not fond of cheap after market parts. I once put Champion double platinum plugs in my 96 and it started a lot of that crap after 5k miles.
1997 Mark 8 LSC
Former owner:
post #13 of 39 (permalink) Old 08-07-2016, 08:30 AM Thread Starter
I recently installed new Motorcraft plug wires and Auto lite copper plugs and it had zero effect.
Let me see what the motorcraft version IAC costs.
JasonWW is offline
post #14 of 39 (permalink) Old 08-07-2016, 08:35 AM
Darrin's Avatar
How did you test the coils?
D
Darrin is offline
post #15 of 39 (permalink) Old 08-07-2016, 08:49 AM Thread Starter
D
You can take a digital multimeter and measure the coil resistances. The specs are in the manual. In addition you can pull each plug wire off while the engine is running. I got nice blue/white arcs over 1" long. That's very healthy.
JasonWW is offline
post #16 of 39 (permalink) Old 08-07-2016, 08:51 AM
Darrin's Avatar
Ok, textbook.
So how did you test for spark integrity under load or cross spark due to an internal crack?
D
Darrin is offline
post #17 of 39 (permalink) Old 08-07-2016, 09:04 AM Thread Starter
Ok, textbook.
D
I don't think such tests exist.
JasonWW is offline
post #18 of 39 (permalink) Old 08-07-2016, 09:10 AM
Darrin's Avatar
Just making you think.
I've run into that with those old coil packs on both my own and customers cars. Also, fuel injectors cause some wonky stuff to happen even though they may have been cleaned.
But I'd replace that IAC first. if it's making a noise it's having an issue. Cleaning sometimes works, but usually not and often only short term if it does.
And be careful cleaning your MAF too often. You can damage it and not know it.
D
Darrin is offline
post #19 of 39 (permalink) Old 08-07-2016, 10:11 AM Thread Starter
I just installed a new IAC. Motorcraft was $57 online and $85 local. I didn't want to wait a week for a online one so I used my Oreilly's account and got the BWD brand for $45 plus tax.
Yes! It fixed one of my issues. It seems to respond very quickly to changes in engine load. When in gear and I turn the steering wheel the rpms don't drop way down making the car shake anymore. Even the AC cycling on and off seems smoother. I assume it won't make that weird moaning sound anymore either.
I don't know if it will fix any of my other problems, but I'll have to test it later and see. I know the idle is still a bit shaky. But overall, a well spent $50 indeed.
JasonWW is offline
post #20 of 39 (permalink) Old 08-07-2016, 06:03 PM
Woodman's Avatar
Go ahead and order the Motorcraft IAC and keep it. That aftermarket one won't last very long.
Woodman is offline
post #21 of 39 (permalink) Old 08-08-2016, 08:11 AM
T6Rocket's Avatar
Being a pro at it sounds excessive. Cleaning it every 30-40k is sufficient, unless you are using an oily K&N.
Unless you see visible dirt, no need to clean it. Even though they say the cleaner does not harm it, I would not trust cleaning on a very short interval like every oil change.
Those things go bad if you look at them wrong, I would not want to spray one like 20 times over the life of it.
Al
Previous cars:
T6Rocket is offline
post #22 of 39 (permalink) Old 08-08-2016, 08:20 AM Thread Starter
I finally got to drive around with the new IAC last night. It's quicker to respond to engine load changes, but it created a new problem. When stopped at a red light the idle will sometimes drop real low for a few seconds and shake the car. I'm talking about 300-400 rpms on the stock tach. One time it even stalled out and I had to restart the car. My old IAC valve at least kept the car running.
This morning I decided to reset the ECM and then do some driving around hoping that would get the new valve operating properly. No luck, same near stalling performance as before.
IDK, is it the brand of valve I got? I could probably get a motorcraft sent to my local store and say the BWD brand I just bought is defective.
JasonWW is offline
post #23 of 39 (permalink) Old 08-08-2016, 11:20 AM
Woodman's Avatar
I would just order the Motorcraft unit, and a throttle position sensor at the same time. Replacing both parts on my car solved my idle issues.
Woodman is offline
post #24 of 39 (permalink) Old 08-11-2016, 01:45 PM Thread Starter
I used my OBD2 reader and the Torque app to look at some readings while idling in Park with the AC on. Even though the rpms vary a small amount based on whether the compressor is on or off the timing does jump around a lot. From a low of 12° up to 30°.
The last picture is the car idling in drive. It shows 30° of advance which seems weird.
Do any of the other readings look off to you guys? (Ignore the boost and mpg)
JasonWW is offline
post #25 of 39 (permalink) Old 08-11-2016, 02:04 PM Thread Starter
A couple of months back the car started jerking and bucking under acceleration pretty badly and it set a trouble code saying cylinder 5 was misfiring. I pulled the plug boot and there was some water down there. I dried it out, pulled the plug and wire brushed the contacts, applied more dielectric grease to the boot and put it back together and it ran smoothly.
When it started bucking again about 2 weeks ago, I checked cylinder 5 and it looked fine. 1 week ago I changed all the plugs. 7 of them were gray and ashy, but number 5 was dark gray. Darker than all the others. Maybe that is from the cleaning I gave it earlier?
Anyway, the new plugs had no effect.
I'm gonna try to plot a graph of the ignition advance while accelerating. Maybe the computer is just acting weird.
If one of the coils were bad, it seems likely it would buck and jerk above 2500 rpm, but it's smooth there. Can anyone think of a reason it's smooth above 2500 rpm? That seems about were full timing advance would kick in.
JasonWW is offline
post #26 of 39 (permalink) Old 08-14-2016, 07:41 AM Thread Starter
I've been working on the bucking issue since it's driving me crazy. Last night I did something that changed the rpm range that the bucking takes place. Now it's from idle to 1,600. Much better! It's drivable (Yes, my standards are that low ).
Anyway, I decided to check the coils again since it's been over a year since I measured them. I pulled the "3 wire" connectors on each coil pack to measure the battery voltage and coil resistance. I couldn't get the test probe into the connector, so I used a paperclip to reach down in there. I checked all 6 female connectors, voltage on the middle wires were all good. I cranked up the car and pulled each plug wire from it's coil pack to measure the spark length. All good and over 1.5". Although it was kinda orange colored though, not blue like last time. Then I went for a drive and the bucking rpms changed.
I know the 6 male electrical tabs on the coils are clean (I cleaned them last year with an emory board and used dialectric grease and they still look good) so I'm guessing the female plugs themselves are either dirty or not tight and leading to a misfire.
The freakin plugs are over $30 each! Has anyone ever taken this plug apart? I'd like to clean it and bend the metal to make a stronger contact.
JasonWW is offline
post #27 of 39 (permalink) Old 08-14-2016, 10:29 AM Thread Starter
I just cleaned all 6 coil pack connectors, male and female, and added grease. The female plug connectors are nice and tight so the plugs seem to be fine. No change in performance. It still bucks from idle to 1600 rpm.
What else did I do last night?
I unplugged and replugged the small single wire to the alternator. Voltage running is 13.7 idle and 13.8 above idle. Shouldn't it be closer to 14.4 or so?
Maybe the ground wire going to the front bottom of the engine is loose or dirty. It's the only battery wire I haven't looked at closely.
Maybe the voltage regulator is a bit weak or something. Stock regulators seem to be set at 14.6-14.7v, although I can't say for sure if they always run that high or if they fluctuate depending on what the battery needs.
JasonWW is offline
post #28 of 39 (permalink) Old 08-15-2016, 12:42 AM
gordonm1's Avatar
I stopped a mystery miss under load by changing the distributor cap back to factory original. My aftermarket cap had something that didn't work right with a stock rotor.
gordonm1 is offline
post #29 of 39 (permalink) Old 08-15-2016, 12:56 AM Thread Starter
No distributors here, more like crank sensors and coil packs.
JasonWW is offline
post #30 of 39 (permalink) Old 12-25-2016, 09:41 PM Thread Starter
Now I have an issue where if the engine is warm and it idles for 5 or 10 minutes thd idle gets real rough and starts spitting and sputtering. The engine light will flash (that's a new one) and I'll get a code p300 which is multiple random misfires. Then the engine will die and not crank. I pull the ecm fuse and let it set at least an hour. When I put the fuse back in it won't crank for maybe 10 seconds, then it fires up normally.
I don't know if it's the cooling down period or the ecm reset that fixes it.
When the engine is cold it can be really hard to cramk, might take 2 or 3 tries. When it's warm it cranks easily on the first try.
Here is the ignition advance while idling. It's all over the place.
Here is the ignition advance while driving down the road.
Obviously something is not right. I'm still leaning towards the ecm being bad since the spark is so strong, yet the timing is wacky. Maybe a new MAF is needed?
JasonWW is offline
