mark vIII vs thunderbird alternator - TCCoA Forums
 1Likes
  • 1 Post By XR7-4.6
post #1 of 7 (permalink) Old 02-07-2017, 05:40 AM Thread Starter
coggonobrien's Avatar
will an alternator from a 94 tbird 4.6 work on a 94 mark viii?
coggonobrien is offline
post #2 of 7 (permalink) Old 02-07-2017, 05:47 AM
They are different part numbers so I don't think it will fit.
Sent from my SM-N920V using Tapatalk
drew96dawg is offline
post #3 of 7 (permalink) Old 02-07-2017, 06:00 AM Thread Starter
ok, rockauto showed the same motorcraft listed under both
post #4 of 7 (permalink) Old 02-07-2017, 06:24 AM
I just checked it as well, I didn't see the same one listed under both. You could always try it if you've got one lying around. Mine is off of a crown vic I believe.
post #5 of 7 (permalink) Old 02-07-2017, 09:25 AM
Slightly Disjointed
No, it won't clear the intake manifold.
drew96dawg likes this.
post #6 of 7 (permalink) Old 02-07-2017, 10:27 AM
The cases on the two alternators are completely different. The dohc one is smaller to fit the intake.
Robe is offline
post #7 of 7 (permalink) Old 02-07-2017, 03:05 PM
Wile E. Coyote Jr.'s Avatar
The alternator for the mark is thinner to fit in between the intake manifold and the coolant crossover, while the one for the bird is thicker because it sits further back and is on top of the coolant crossover.
Lurking
Wile E. Coyote Jr. is offline
