System too lean - TCCoA Forums
 2Likes
  • 1 Post By Kidd-7
  • 1 Post By Kidd-7
post #1 of 10 (permalink) Old 02-08-2017, 10:08 AM Thread Starter
System too lean
Have done reading and searching, I'm looking for insight on troubleshooting to see what exactly is wrong. I have the torque app & OBDII reader, I have electronic test equipment, scope, multimeter, etc.
I don't want to throw parts at it.
Details: fault code shows
current: P0171 Powertrain system too lean (Bank 1)
current: P0174 Powertrain system too lean (Bank 2)
I replaced all vac lines with the exception of: the EVAP next to the gas tank, looked to be in really good shape and the vac lines to the brake booster and into the cabin.
PO replaced: plugs, wires, coil packs, fuel filter, PCV & seafoamed engine. I can visually verify these were replaced, plus I have a box of the old parts that PO included.
The car doesn't really hesitate, but I think it should have a little more off the block. On occasion under aggressive acceleration it shifts incorrectly into 2nd. seems to shift, but no power for a couple seconds then goes, feathering throttle seems to help it react at that point. Sometimes in normal city driving the tranny seems to pop into 2nd then buck a little.
I've found these 2 write ups that seem pretty good general troubleshooting:
https://axleaddict.com/auto-repair/H...-Oxygen-Sensor
https://axleaddict.com/auto-repair/H...Airflow-Sensor
Car: 96 Cougar 4.6L Stock ~50K miles.
Any specific troubleshooting would be appreciated.
Kidd-7 is offline
post #2 of 10 (permalink) Old 02-08-2017, 10:19 AM
Natesriv's Avatar
MAF sensor involved in any way?
Natesriv is offline
post #3 of 10 (permalink) Old 02-08-2017, 10:38 AM Thread Starter
Could be, just read through the write up on how to test that. I have cleaned it.
Another question: I've read that the intake manifolds cracking are common in certain years. I never had that issue with my 97. In searching I could not find details. Is my intake susceptible? How to test? I've read comments about propane, but how? Is it basically spray propane around the intake and if there is a leak the engine will suck it in and change revs?
Thanks.
Kidd-7 is offline
post #4 of 10 (permalink) Old 02-08-2017, 10:44 AM
Woodman's Avatar
Thanks.
The intake manifold cracks because it's basically a 20 year old plastic part, and due to heat cycling the plastic loses strength over time. They can last, they can go, it's kind of a crap shoot.
Generally speaking, the stock intake manifold will crack near the thermostat housing if it doesn't have the aluminum crossover, or near one of the spark plug wells where coolant is directed through it.
You'll see coolant in the spark plug well near where the crack is.
The propane test is that, if you spray an unlit propane torch around the intake, it'll suck it in.
I'm not well versed on the causes of the lean condition.
PI Swapped NPI motor with some port work on the heads, PI cams, 80mm MAF, CAI that feeds from fenderwell. Jmod, 3.73:1 TL in Mark VIII carrier, Mark VIII aluminum LCAs, 93 Mark VIII driveshaft, PBR brakes (soon to be Cobras), 18x9 wheels, 255/40/ZR18 Tires, Front and Rear strut/shock bracing, GR-2 shocks, Eibach 1.5" springs, 1989 SC front and rear sway bars.
Woodman is offline
post #5 of 10 (permalink) Old 02-08-2017, 07:25 PM
If you've never had the intake off, look at the #7 and #8 plugs, and see if there's any sign of coolant. that's a sign of an intake leak.
Grab the manifold and see if that side moves. No, really.
I had the alternator torque the intake to where the drivers side loosened up.
A propane torch, unlit, waved around the intake will show up bigtime on a live datalog of an idling engine.
Have a friend slowly go over everything spraying propane gas, and look for it moving back toward rich.
There's 5 short pieces of tubing in the evap circuit; the one everyone misses is in the passenger fenderwell, to the rear, between two hardlines.
post #6 of 10 (permalink) Old 02-08-2017, 07:58 PM Thread Starter
Can EVAP cause this? I would think an EVAP leak would throw an EVAP code, it depends on how the ECU firmware performs the self checks and i guess a vac leak is a vac leak. I did get that hose. I'll look at that stuff, Grog6.
Kidd-7 is offline
post #7 of 10 (permalink) Old 02-10-2017, 03:39 PM Thread Starter
I played around with Torque today attached is a screen shot. It appears from Torque that the MAF and O2s are working correctly. I'm going to set up the dataloging feature in Torque. I do remember now that the air temp was about 20 degrees higher than ambient, I saw a thermister near the MAF, that seems like a large temp increase. Can anyone confirm this is the air temp the ECU reports? I'll report back when I have a chance to get out and log.
Woodman likes this.
Kidd-7 is offline
post #8 of 10 (permalink) Old 02-10-2017, 07:35 PM
Woodman's Avatar
If the car is sitting still, depending on location of the air temp sensor, the air temp can be warmer under the hood than outside due to the hood holding the heat in.
Woodman is offline
post #9 of 10 (permalink) Old 02-11-2017, 08:42 AM Thread Starter
I agree with that statement. In our cars though the thermister is in the airbox before MAF and after filter. The air is being pulled in from the outside, I found it odd to be a 20 degree delta. Admittedly, I don't remember details when I saw the temp. So yes, if the engine was warm already and had just looked at the temp when I first started then the thermister would have been warm from sitting in the hot engine bay and not enough cold air flow yet.
Kind of rambling, sorry, thinking this through.
I'm going to inspect the intake, propane test and datalog today.
Woodman likes this.
Kidd-7 is offline
post #10 of 10 (permalink) Old 02-12-2017, 03:43 PM Thread Starter
I smoke tested the vacuum lines today. Found some mild leaking around the TPS, I tried to remove it and add some RTV to seal it up. I can't break the screws loose and started to strip the heads out. Any advice on breaking the screws loose? Also, found some smoke seeping out around the EGR, looks to be coming out of the small holes under the disk. Is this normal? Or should that be sealed? I'm assuming its a diaphragm in there to restrict the flow, could that diaphragm be warn and leaking?
Kidd-7 is offline
