Fuel rail line replacement? - TCCoA Forums
 3Likes
  • 1 Post By RalphP
  • 1 Post By XR7-4.6
  • 1 Post By S4gunn
post #1 of 8 (permalink) Old 04-20-2017, 09:19 PM Thread Starter
Woodman's Avatar
I noticed one of the lines on my fuel rail has a heat spot in it, how hard is it to replace those lines? Just cut them, pull them off and replace them with high pressure rated fuel line?
Woodman is offline
post #2 of 8 (permalink) Old 04-21-2017, 05:55 AM
You can actually buy fuel rail hose; I did that away back when I did the injectors on Ruby Jean.
Here's one possible supply for it: https://www.amazon.com/Dorman-800-07.../dp/B000E323IA
Woodman likes this.
Fuelly
RalphP is offline
post #3 of 8 (permalink) Old 04-21-2017, 07:07 AM Thread Starter
Woodman's Avatar
Thanks!
Does the hose just pull off like a radiator hose would, may need a little work with a pick or something?
Woodman is offline
post #4 of 8 (permalink) Old 04-21-2017, 11:12 AM
Slightly Disjointed
It's on a hose barb, so you need to carefully cut the old line off with a razor blade, there's no pulling it straight off. I found hose made by good year at the local auto parts store with my old grand Marquis rails. Main thing is you don't want a solid hose, the factory hose and the Goodyear hose I used have a harder inner tube inside that the actual fuel flows through - for this reason your stock rails with a heat spot is probably no biggie.
(Not my pic, stolen from google)
Woodman likes this.
post #5 of 8 (permalink) Old 04-21-2017, 11:22 AM Thread Starter
Woodman's Avatar
Gotcha, thank you!
Woodman is offline
post #6 of 8 (permalink) Old 04-21-2017, 03:57 PM
S4gunn's Avatar
Just to be safe, I'd recommend using two stainless steel (not cheapie HF) worm gears to hold EACH connection of hose on the barb. Also pressurize the fuel rail (key on ignition off) and inspect very closely for leaks before starting the car up the first time.
The last thing you want is for fuel to be sprayed at 40PSI on top of a hot engine.
There's also two ratings for fuel hose
J30R7 and the more expensive J30R9.
You want the R9 stuff even if it's more expensive because it's designed for the higher pressure of fuel injected systems (not the low pressure of carbed setups).
Woodman likes this.
S4gunn is offline
post #7 of 8 (permalink) Old 04-21-2017, 05:22 PM Thread Starter
Woodman's Avatar
Thank you! I bought fuel injection rated hose, and fuel injection rated stainless gears. I will pressurize the system and check for leaks, have to anyway since I put a new fuel filter in today.
Woodman is offline
post #8 of 8 (permalink) Old 04-21-2017, 05:59 PM
I used the Gates 180psi rated fuel line on my replacement stuff; I bought it on RA.
It's ~$3 a foot, in 10' lengths, lol.
That's the cheapest place I saw it.
