4.6 intake manifold options?! - TCCoA Forums
 7Likes
post #1 of 32 (permalink) Old 09-08-2003, 03:28 AM Thread Starter
Rob
Rob's Avatar
Send a message via AIM to Rob
Unhappy 4.6 intake manifold options?!
I know a 4.6 truck intake wont clear our hoods, but does anyone have flow #s on any of them? Which year truck intake would be best for a SOHC 4.6? What about the SVO? What is the best production intake I could put on my car? Thanks
-Rob
-Rob
RIP '94 Amber Fire Pearl Metallic Thunderbird on Bullitts 14.56@90.54MPH
96 Sport '02 Explorer PI with ported heads, 90MM LMAF, DirtyDog Marauder TC, Inject tech chip, Jmod, Magnaflow mid-mount with Tru-X core, no cats. Urethane drivers motor mount. HIDs!
Rob is offline
post #2 of 32 (permalink) Old 09-08-2003, 09:59 PM
Evil Poster
Pooperscooper's Avatar
Send a message via AIM to Pooperscooper
Riechard Racing makes custom intakes that I hear make about 15 more hp than a Bullit. The also cost less. Since they are custom, they can be made for just about any application.
Pooperscooper is offline
post #3 of 32 (permalink) Old 09-09-2003, 12:56 AM Thread Starter
Rob
Rob's Avatar
Awesome, I'll go try to check out his website. Thanks
-Rob
-Rob
Rob is offline
post #4 of 32 (permalink) Old 09-09-2003, 06:30 AM
JustinH's Avatar
Its nothing I would ever consider buying.
JustinH is offline
post #5 of 32 (permalink) Old 09-09-2003, 06:58 AM
RIP Jake
Leland Jacobson's Avatar
Use caution with the Reichard manifold; its application is for boosted all out raceing, and makes hp at the expense of torque...... it will add considerably more tahn 15 hp with boost , but will never find favor as a street application in its present configuration, but the design is such that they might change things and come up with a good street application in the future.... the svo manifold is available for non PI apps, the Bullit is for the PI apps... both have the advantage of being aluminum, which is adaptable, in that its machinable, so porting, polishing, etc are possible... You may even be able to add spacers to the lower plenum, and change the characteristics a bit, but the manifold situation on mudulars is pretty much all ford , no spectacular hp advances good luck
Leland Jacobson is offline
post #6 of 32 (permalink) Old 09-09-2003, 08:20 AM Thread Starter
Rob
Rob's Avatar
Ok cool. Looks like I'll just wait aroud so I can afford an SVO for NPI heads. I thought the SVO intake added about 35HP according to Ford. What about torque on the SVO? Who has ran the truck intake on a basically stock 4.6? Thanks
-Rob
-Rob
Rob is offline
post #7 of 32 (permalink) Old 09-09-2003, 08:31 AM
banned
mad281's Avatar
I have a similar question.
From which car could I get a set of heads and instake for my Crown Vic? Hood clearance is not important. I like road racing, so I'm interested in better high end. Good idle is not important either. BTW: I'm only interested in something that I can get from a junk yard.
mad281 is offline
post #8 of 32 (permalink) Old 09-09-2003, 09:36 AM
RIP Jake
Rob, I wouldnt even go there ... some pre 99 truck manifolds were alum.... the prob is that with height you get the longer runners that make early torq, and unless you have a split plenum with valving like a 99 5.4, they do not make decent H.P. , especially at higher rpms....Truck manifolds are great for grunt early on, but up somewhere after 4000- 4500 rpm they start to fizzle out
post #9 of 32 (permalink) Old 09-09-2003, 11:15 AM Thread Starter
Rob
Rob's Avatar
Talking
So the SVO intake is probably a better choice that running a truck intake (with hood modifications?) Thanks
-Rob
-Rob
Rob is offline
post #10 of 32 (permalink) Old 09-09-2003, 11:23 AM
The Great Obucina's Avatar
go for the SVO manifold, there may be some clearance issues with the hood so some braces may need to come out. Also, its been a while but i remember KD mentioning to me that the EGR needs to be welded in on the manifold. Unfortunately, the manifold aint cheap, i would try the corral classifieds and ebay, i remember there was a guy selling a bullitt manifold he said awas port matched for NPI heads.
joseph
"Booyah". Stu Scott.
1996 Braincoated, all Aluminum PI powered and obscenely loud Pearl White Tbird 14.17@98.57mph AKA Dyrdek.
The Great Obucina is offline
post #11 of 32 (permalink) Old 09-09-2003, 11:41 AM Thread Starter
Rob
Rob's Avatar
I thought there was an install kit for the SVO intake that included EGR stuff. Welding the EGR in...damn thats just horrible. I'd try to tap some holes and bolt it up. Thanks
-Rob
-Rob
Rob is offline
post #12 of 32 (permalink) Old 09-09-2003, 11:47 AM
Astrophysicist / PostWhore
66dvlbrd68's Avatar
(SVO Intake, pic from FRPP website).
NRL has the SVO intake, so you'd probably wanna get a hold of him. I forget if he had any problems or not (I've not talked with him in a while).
I've seen the Reichard intake up close. It looks good. It made some goooooood power on an '03 GT. Too bad the car cracked a head (too much boost I guess).
Mike | RSW | THP | MF | SRTConnection |
1996 Ford Thunderbird LX V8 + 1992 Ford Mustang hatchback + 1989 Ford Mustang notchback = no where else to park at my house!
66dvlbrd68 is offline
post #13 of 32 (permalink) Old 09-09-2003, 08:37 PM
Like Titles Matter
kdanner's Avatar
The welding that needs to be done is to the EGR tube, not the manifold. The EGR valve is farther forward so you need a longer tube. No you cannot use the one from the install kit, a Mustang EGR tube goes to the driver's side.
You have to hack out a lot of hood bracing and it will still be right against the outer skin of the hood where the boot goes over the throttle body.
EFI Tuners Organization Administrator/Gatekeeper
1996 Thunderbird LX- 12.54@106.08 NA
1998 GT - 11.51@122
2001 Lightning - 12.15@110
1996 GT 248A - ?@?
2011 GT - 10.46@129.38 180 MPH at the Texas Mile
generated by sloganizer.net
kdanner is offline
post #14 of 32 (permalink) Old 09-09-2003, 09:49 PM Thread Starter
Rob
Rob's Avatar
Talking
Awesome. Making an EGR pipe ain't no thang :-). So I don't need the install kit? I guess SVO intake is on my wish list now. Thanks guys
-Rob
-Rob
Rob is offline
post #15 of 32 (permalink) Old 02-08-2016, 11:55 AM
deckstripe1@verizon.'s Avatar
I was wondering if you ever did the SVO install ???
deckstripe1@verizon. is offline
post #16 of 32 (permalink) Old 02-08-2016, 04:40 PM
That thread's over 13 years old; some of those guys are still here, tho.
CDsDontBurn likes this.
Grog6 is online now
post #17 of 32 (permalink) Old 02-08-2016, 07:49 PM
Woodman's Avatar
Trick Flow also has intake manifolds for the Modular now, and they should work very well with Trick Flow heads.
Since it's a very old thread, may as well update it with current info, right?
Woodman is offline
post #18 of 32 (permalink) Old 02-10-2016, 01:56 AM
ogbird95's Avatar
holy mother of god thread revival.
I was wondering about an intake manifold upgrade aswell. I was looking at Trickflow street burner or the typhoon intake. I've heard some negitive things about the typhoon intake, but it is half the price of the Trickflow. That may be for a good reason, also the typhoon intake does not have the second coolent temp sensor hole.
Links
Professional Products Satin Typhoon Mustang Intake Manifold 54061 (99-04 GT) - Free Shipping
Trick Flow® StreetBurner® EFI Intake Manifolds for Ford 4.6L 2V TFS-51811000 - Free Shipping on Orders Over $99 at Summit Racing
Woodman and CDsDontBurn like this.
ogbird95 is offline
post #19 of 32 (permalink) Old 02-10-2016, 06:30 AM
r429460's Avatar
The Typhoon is a copy of the stock PI plastic manifold.
The Typhoon can be taken apart and fully ported.
The Street Burner can be taken apart to be fully ported as well.
The runners a shorter than the stockers for a higher rpm range.
If your not going to run TFS heads or ported PI, NPI heads stick with a plastic stocker.
But nitrous or a centrifugal supercharger should have a aluminum intake manifold.
But, what do I know.
Woodman likes this.
Quickest N/A Modular MN12.
11.97@ 109.35
3880 lbs. w/driver.
Bradenton Spring Brake Shootout 03/04/2017.
r429460 is offline
post #20 of 32 (permalink) Old 02-10-2016, 11:46 AM
Woodman's Avatar
Links
Nice that the street burner has both coolant temp holes already too.
Woodman is offline
post #21 of 32 (permalink) Old 02-10-2016, 02:40 PM
T6Rocket's Avatar
Doesn't the Trick Flow require a cowl hood for clearance? Or is that just if you have a 94-95?
Al
97 T-Bird LX 4.6 - 68k miles
Previous cars:
T6Rocket is offline
post #22 of 32 (permalink) Old 02-10-2016, 03:07 PM
Slightly Disjointed
I think the TF is a bit lower than the bullitt, both fit under 96/7 hoods with cut bracing, no idea about 94/5
post #23 of 32 (permalink) Old 02-10-2016, 03:43 PM
r429460's Avatar
95 and 95 will dimple my , I mean the hood.
The alternator mounts backward, using a bracket supplied with the
intake manifold.
That's what hits the hood on a 94-95 cougar.
A T-Bird might have enough clearance.
Looking at the picture on the TCCOA header.
96 and 97 have enough clearance.
11.97@ 109.35
3880 lbs. w/driver.
r429460 is offline
post #24 of 32 (permalink) Old 02-10-2016, 05:27 PM
****, my question would be will a coyote "302" intake fit my C heads, and will it clear a stock 96 hood...
@deckstripe1@verizon.
All the old intakes are here if you search, I'm pretty sure most of JL and KDanner's early exploits are here.
JL did have the NA record, last I looked.
Grog6 is online now
post #25 of 32 (permalink) Old 02-10-2016, 09:49 PM
Woodman's Avatar
No, nothing Coyote regarding intake, heads, etc fits the modular 4.6.
Woodman is offline
post #26 of 32 (permalink) Old 02-11-2016, 11:10 AM
ogbird95's Avatar
In your guys opinion what would be the best option for my build? I have;
Stage 2 cams with upgraded springs
Ported pi heads
Forged rods
Forged notched Pistons @ 10.5/1 comp.
Cast crank
Midlength headers
I know I can't go wrong with the trickflow streetburner, but at its price of almost a grand should I just find a roush/svo supercharger?
ogbird95 is offline
post #27 of 32 (permalink) Old 02-11-2016, 04:00 PM
Woodman's Avatar
Ported pi heads
Forged rods
Cast crank
Midlength headers
Supercharger + high compression = E85 or Race Gas only.
One of the guys on the Facebook TCCoA page has a stock 2V bottom end with 38CC Trick Flow heads and ported PI intake with Comp Cams XE270AH and a 3800 DD stall who is putting out 316 RWHP on pump gas, that's approximately 400 on the crank. With your setup, I don't think the intake is holding you back as much as the cams.
Woodman is offline
post #28 of 32 (permalink) Old 02-11-2016, 09:58 PM
ogbird95's Avatar
Would i still have to run E85 or race gas if i kept the boost low. I may be mistaken, but i think the roush/svo blowers only put out 8 psi on the stock pulley.
ogbird95 is offline
post #29 of 32 (permalink) Old 02-12-2016, 07:27 AM
T6Rocket's Avatar
You would require less octane and make more power with lower compression and higher boost.
Al
Woodman likes this.
Previous cars:
T6Rocket is offline
post #30 of 32 (permalink) Old 02-12-2016, 09:57 PM
Woodman's Avatar
You've already got 10.3 or so compression. That alone requires 91 octane. Add another 8psi of pressure, that ups the tendency to pre-ignite dramatically.
If you put NPI heads on, then the blower, you could stick with 91 octane. PI heads on an NPI block and a blower, I wouldn't run anything less than E-85 (approx 100-105 octane), but it'll cost you MPG and require a more robust fuel system.
ogbird95 likes this.
Woodman is offline
