What fixes these codes? P1443 and P1131 - TCCoA Forums
post #1 of 30 (permalink) Old 10-25-2004, 03:09 PM Thread Starter
Jealous?'s Avatar
Send a message via MSN to Jealous?
As it says, I scanned the car and these came up along with a closed loop fuel control issue. Could they be the same problem? or do I have a big issue to deal with?
Now I'm in Florida....
Jealous? is offline
post #2 of 30 (permalink) Old 10-25-2004, 07:48 PM
Darrin's Avatar
Straight from the service cd (mostly, I added a descriptor after the code)
P1443=A problem with the EVAP purge flow system
Continuous Memory Diagnostic Trouble Code (DTC) P1443 indicates an incorrect evaporative system purge control valve flow.
Possible causes:
-- Obstructed, open or cracked hoses between EVAP canister purge valve and intake manifold.
-- Damaged EVAP canister purge valve.
-- Damaged PF sensor.
P1131=Bank 1 upstream (front) O2 not switching properly showing that it thinks Bank 1 is going lean. Bank 1 may be going lean from what you say about a closed loop fuel issue.
Diagnostic Trouble Codes (DTCs) P1131 bank (1) (Cylinder #1) and P1151 bank (2) indicate the fuel/air ratio is correcting rich for an overly lean condition. The HO2S voltage is less than 0.45 volt. DTCs P1132 bank (1) (Cylinder #1) and P1152 bank (2) indicate the fuel/air ratio is correcting lean for an overly rich condition. The HO2S voltage is greater than 0.45 volt.
DTCs P1130 and P1150 indicate the fuel control system has reached maximum compensation for a lean or rich condition and the HO2S is not switching.
DTC/HO2S Reference List
-- HO2S-11 = DTCs P1131, P1132 and P1130
-- HO2S-21 = DTCs P1151, P1152 and P1150
Possible causes:
Fuel system
-- Excessive fuel pressure.
-- Leaking fuel injector(s).
-- Leaking fuel pressure regulator.
-- Low fuel pressure.
-- Contaminated injector(s)
Induction system
-- Air leaks after the MAF.
-- Vacuum leaks.
-- Restricted air inlet.
-- PCV system.
-- Fuel purge system.
-- Improperly seated dip stick.
EGR
-- Leaking gasket.
-- Stuck open EGR valve.
-- Leaking diaphragm.
Base engine
-- Oil overfill.
-- Cam timing.
-- Cylinder compression.
-- Exhaust leaks before or near the HO2Ss.
l Check air intake for leaks, obstructions and damage.
l Check air filter, air filter housing for blockage.
l Verify integrity of the PCV system.
l Check for vacuum leaks.
Darrin is offline
post #3 of 30 (permalink) Old 10-25-2004, 10:21 PM Thread Starter
Jealous?'s Avatar
HOLY CRAP. Thanks! Sounds like I have a rich condition that the computer is trying to compensate for.
I'll do a little tweaking and scan again to tell ya the results....
Jealous? is offline
post #4 of 30 (permalink) Old 10-27-2004, 03:50 PM Thread Starter
Jealous?'s Avatar
now all i have is the p1443. I'm beginning to think its the egr system.
Jealous? is offline
post #5 of 30 (permalink) Old 10-27-2004, 04:46 PM
Darrin's Avatar
I don't think EGR problems would cause a code for the EVAP system.
I bet you either have a bad vacuum line or the purge flow sensor is DOA. I am betting on the vacuum line though.
Good luck
Darrin is offline
post #6 of 30 (permalink) Old 10-27-2004, 05:35 PM
i am havin the same problems only my check engine light is comin on Someone told me it sounded like the mass air flow sensor and to test it by unplugging it while the car is off and to see if it is running any better I unplugged it and still no light came on. I'm curious to see what fixes urs so I can try it on mine. Also where would the most common place to look for a vaccumm leak? thanks Pat
GumbyHendu is offline
post #7 of 30 (permalink) Old 10-27-2004, 09:51 PM Thread Starter
Jealous?'s Avatar
anyone have a clue how to get to the evap can and hoses?
Jealous? is offline
post #8 of 30 (permalink) Old 11-04-2004, 11:03 PM Thread Starter
Jealous?'s Avatar
Well, I pulled the MAF plug and there is no change in idle at all. It basically runs the same too. Something is up.
any ideas???
Jealous? is offline
post #9 of 30 (permalink) Old 11-05-2004, 03:59 PM
motor city poster
Red96Bird's Avatar
i replaced two parts (little cans just underneath the headlights.,.
easiest way to get to them, jack up car, remove front passenger tire, and unscrew/pull back the lining, and you will se it right infront of where the air silencer used to be..
these two part numbers fixed my cel with P1443
E6ZZ-9C915-A and
F57Z-14A606-BA
one of them is like a little valve with an electrical connection, and the other is a little canister looking thing, u will also want to purchase like a foot or two of vacuum hose because the one in there will be all dry rotted and old.
hopefully this helps
btw-these two parts cost $72.82
like i said, that is what fixed my P1443 Cel code
Patrick
Red96Bird is offline
post #10 of 30 (permalink) Old 11-07-2004, 12:04 PM
JoeyICU's Avatar
the lean code is proabably from the maf, if your willing to spend 100 bucks take it to ford tell them your CEL theyll do a baro test on all your sensors the the NGS and find out whats wrong
it could also be the canisters under the headlights, maybe one of the vacum lines to them is bad
when you unplug your maf if your car is in closed loop mode you will not notice a diff in idle as the computer already has everything set in stone, in open loop the car would be pooing a brick, so it could be when you have the maf unpluged your cars eec is still in closed loop, i wouldnt trust just unpluging it and thats how you tell if its bad
1995 Ford Thunderbird 4.6 LX
2011 BMX X5 Xdrive50i
1998 Jeep Grand Cherokee 5.2L AWD - Cooling work, a big sound system, an exhaust, 3.5" IRO lift on 31s
1984 Ford F250 6.9 IDIT
JoeyICU is offline
post #11 of 30 (permalink) Old 11-07-2004, 12:05 PM
JoeyICU's Avatar
id look for that 1st, then if the lines seem old but not to bad off, go with replacing the two canisters
JoeyICU is offline
post #12 of 30 (permalink) Old 11-07-2004, 11:16 PM Thread Starter
Jealous?'s Avatar
I'm going to do that tomorrow. Thanks guys.
ps. Any idea what size the hose is?
Jealous? is offline
post #13 of 30 (permalink) Old 11-08-2004, 03:19 PM
motor city poster
Red96Bird's Avatar
maybe pull it apart first, take a sample piece with you and match it up at the auto parts store?
i cant remember off the top of my head
post #14 of 30 (permalink) Old 11-08-2004, 04:27 PM
JoeyICU's Avatar
ditto,take a piece in to match the size, i believe its the size of fuel line, maybe 5/8ths?
JoeyICU is offline
post #15 of 30 (permalink) Old 11-08-2004, 05:11 PM Thread Starter
Jealous?'s Avatar
well, isn't that impossible to do with no second car? I can't drive my car with open vacuum lines.
Jealous? is offline
post #16 of 30 (permalink) Old 11-08-2004, 08:11 PM
motor city poster
Red96Bird's Avatar
oh sorry about that.
post #17 of 30 (permalink) Old 11-08-2004, 11:12 PM Thread Starter
Jealous?'s Avatar
no biggie. I didn't know there were 2 EVAP canisters. Do they both have lines running to the intake?
Jealous? is offline
post #18 of 30 (permalink) Old 11-09-2004, 08:32 AM
Replace all your vacumn hoses if you are getting a EGR code. If you have a 94-95, look for the green and red hard llines. they hook up the the EGR pump behind the intake, and the littlt saucer thingie. Replace all and I mean all you vacimn tubing and the EGR code will go away.
Fly Low, Fly Fast, Fly Ford Forever!!!
Stock 94 block, Richard M intake tube, C&L 73mm MAF, BBK 75mm TB, Port matched elbow, 9 in K&N in the fender well, Diablo chip, M8 flywheel and TQ, FOrd racing underdrive pullies, NGK plugs, FRPP 3:73, auburn limited slip diff, 2.5in exhaust from manifolds back into Dynamax SS mufflers.
MN12-Blackbird is offline
post #19 of 30 (permalink) Old 11-20-2004, 11:50 PM Thread Starter
Jealous?'s Avatar
well, it must be the purge flow solenoid...the flow sensor (aka thermistor) did not fix the problem.
For future searches...the Motorcraft part number for the Canister Purge Flow Solenoid is CX1324 for the black top/black fittings and CX1158 for the natural-colored top/fittings. Its supposed to be the replacement for Ford part E6ZZ-9C915-A I'll update when I replace mine soon. Thanks for everyone's help!
Jealous? is offline
post #20 of 30 (permalink) Old 11-21-2004, 12:41 AM Thread Starter
Jealous?'s Avatar
PS. Its not a dealer-only part. RockAuto.com carries them for $30.79 plus shipping.
ok, I'm done for the night.
Jealous? is offline
post #21 of 30 (permalink) Old 11-21-2004, 05:28 AM
chromecoupe's Avatar
while were on the topic...anyone have any info on code p0113 i know its listed as "high flow current from iat sensor"(from autozone atleast) and its because i put one of those magical "add 20+hp with a 5cent resistor" off ebay into the pigtail part of the iat...i replaced the pigtail (rewired it) and still get the same error, anyone have anything to offer on this? (sorry, didnt wanna start a new thread)
black 97 v8 bird . 18" panther chrome . tinted . r40 lowpro tires . lowered 2" . k&n cone . 180* Tstat . jba headers . gutted precats . 18"x3.5" straight duals . clear corners . pioneer 240w 4-way 5x7's all around . 04 xplod headunit . memphis amp + two 10" woofers.
chromecoupe is offline
post #22 of 30 (permalink) Old 11-23-2004, 01:34 AM
Tinfoil hat wearer
azreael344's Avatar
Send a message via AIM to azreael344 Send a message via Yahoo to azreael344
Even before I got my chip my car would throw the p1433 code when we switched to the winter oxygenated gasoline on 87 octane. When I would run 93 octane it wouldn't come on. I guess it just didn't like the winter gas mixture.
1996 Laser red 4.6 V8.
Flowmaster catback, PI Intake, PI cams K&N 9 inch cone filter 80mm LMAF, Trickflow plenum, 75mm BBk throttle body,SCT Chip, Red FRPP wires, 22c plugs & 180* t-stat, PBR calipers, ASP underdrives. Marauder torque converter, FRPP 3.73 gears, Custom Drive shaft, Eibach Springs, Tokico shocks, JMOD, B&M 24k Tranny Cooler, Clear corners, 145mph Speedo,17X9 Cobra R's, Complete SC interior including SC Handbrake conversion
Best time 14.90@ 93.18 MPH 4/16/2004
My other ride: 2001 F150 4x4
Aol screen name: Azreael344
azreael344 is offline
post #23 of 30 (permalink) Old 11-23-2004, 08:25 AM
JoeyICU's Avatar
you probably need a new sensor you may have killed it
JoeyICU is offline
post #24 of 30 (permalink) Old 11-23-2004, 08:27 AM
JoeyICU's Avatar
i dont think thats his problem in his case
ps ive never had that problem
JoeyICU is offline
post #25 of 30 (permalink) Old 11-23-2004, 12:04 PM
Red Sox Nation Rabid Fan
TCCoAAC Founding Member
jordansypek's Avatar
Send a message via AIM to jordansypek
Search..
throwing code 1443
TCCOAAC (R.I.P. JOEL)
96 4.6 XR7 (T45 Swap, etc.)
97 4.6 Mustang Cobra (12k Miles)
00 5.0 Explorer Limited
2008 KTM 690SMC
2004 Seadoo GTX-SC
(Looking for a 1962 Ford Falcon)
jordansypek is offline
post #26 of 30 (permalink) Old 11-23-2004, 02:01 PM Thread Starter
Jealous?'s Avatar
Why are you telling me to search? This problem has been resolved.
Jealous? is offline
post #27 of 30 (permalink) Old 11-24-2004, 06:15 AM
I know buddy, but you were asking earlier in the post, I had the same problem, it was a piece of cake... Glad to hear you ironed it out... Also the next time someone else searched for the same code, they will see the reference to my thread also.. since this will more than likely be the latest thread, mo info, mo info, mo info!
2008 KTM 690SMC
2004 Seadoo GTX-SC
post #28 of 30 (permalink) Old 02-08-2011, 01:13 AM
maybe im a glutten for punishment but i have to ask . i am wondering if there is any ohms or voltage specs to test if the purge valve or purge sensor to insure the right part is being replaced ? i always like to teast something before i condem it being ive seen sensors that seem bad via a troubble code yet if i pull the offending sensor put it on a diffrent motor wham its working perfectly so id rather test and replace the offending sensor or valve then just shoot in the dark and pray i hit the right one
1986 Mustang GT 5.0 RIP
1988 F-150 4x4 5.0
1997 Thunderbird LX
outboardtech is offline
post #29 of 30 (permalink) Old 02-08-2011, 05:38 AM
Wow, another thread revival!
When I fixed mine, I said to hell with it and just replace everything. It was easier for me to take everything out together.
post #30 of 30 (permalink) Old 02-08-2011, 01:22 PM
i had this suzuki DF 115 that i was working on that saied the map sensor was bad on my laptop, but when i went and took the map off a brand new 115 i had in the back of the shop just to test and make sure the sensor was the problem the new sensor still threw the code. so out of curiosity i took the "bad sensor" put it on the new motor took the new motor and stand to the front of the shop started it and it ran fine no codes, so after that day ive learned test things to be 100% sure sadly the motor with the map sensor problem was never repaired the owner was disgusted with the motor and had me install a new motor and sold the old one with the problem to a idiot who refused to even pay me to put my laptop on it to diagnose the problem so he made me alot of $ buying sensor after sensor trying to fix it lol
1988 F-150 4x4 5.0
1997 Thunderbird LX
