PI Explorer Engine Swap Article - Page 3 - TCCoA Forums
post #61 of 132 (permalink) Old 09-25-2008, 02:42 AM
It's only easy to change if it hasn't been "welded" to the block with corrosion. It took a BFH to seperate the water pump from the block on my 4.6L, and the pump cracked in 3 different places during this removal "procedure".
post #62 of 132 (permalink) Old 09-25-2008, 11:51 AM
Moderator & Teksid Whore
guitar maestro's Avatar
i totally second that.....when i was trying to replace mine, i was like W..T...F!!!! this sucker wont budge...broke several of the mounting tabs off...and then i was like F-it....smashed a flat-head between the pump and the block....i knew i wasnt gonna do anything to the block, it being iron and all...and finally it broke loose......but it was worth the piece of mind to have a pretty much new pump in there
if you can find a '02 or newer pump AND pulley out of a parted-out 2V 4.6, then grab it....the longer-shaft pumps from mid-01 and older are, obviously, getting older and older and harder to find in like-new condition...but people are always parting out mustangs, crown vics, grand marquis, towncars, etc, etc
guitar maestro is offline
post #63 of 132 (permalink) Old 09-25-2008, 02:17 PM
Seasoned Geek
Yep the old pump has 120k on it so i am going to give it a go . Pics Below of Pump have know clue as to make or good or bad .
post #64 of 132 (permalink) Old 09-25-2008, 11:38 PM
Hey guys,
My buddy and I are looking into doing the headswap on my 96 bird. I'm looking at some heads from an 01 GT. Are there any differences in bolt patterns between the two or do I need to check part numbers?
Btw, how much are the 94/95 timing covers going for?
96AlpineBird is offline
post #65 of 132 (permalink) Old 10-01-2008, 08:12 PM
Seasoned Geek
Just a quick question guys ....is it imperative that the intake bolts be torqued to Ford specifications?
post #66 of 132 (permalink) Old 10-01-2008, 09:13 PM
sik97bird's Avatar
it is, i believe its 18ft lbs
97 Ford Thunderbird
Check out my Gallery
vist the Man RobertP at www.robstireandauto.com
sik97bird is offline
post #67 of 132 (permalink) Old 10-01-2008, 09:15 PM
Seasoned Geek
Thank you sir !
post #68 of 132 (permalink) Old 10-01-2008, 09:36 PM
It's so imperative that I didn't do it with a torque wrench. I used my calibrated torque wrench built into my body. Almost 10k miles, not even the slightest hiccup.
post #69 of 132 (permalink) Old 10-01-2008, 09:40 PM
Seasoned Geek
Chris How did you reroute the hose under the Pi intake ? Took me awhile but i think i have it right
post #70 of 132 (permalink) Old 10-02-2008, 12:47 AM
SuperNewbie
supergordo's Avatar
When I did my first 4.6 water pump my car had really rusty coolant. It had ruined the heater core and it had corroded half of all the pump impellers away from corrosion. I did have to use a hammer to get it loose. But I just kept tapping it all the way around the pump until it came loose. Its a little bit of a challenge, but I've definitely done worse jobs than that.
1995 Cougar XR7 4.6
1997 Thunderbird LX 4.6
1977 Country Squire 460
1985 Capri RS 5.0, 5spd
1997 Thunderbird 4.6
1984 Capri RS 5.0,5spd
supergordo is offline
post #71 of 132 (permalink) Old 10-02-2008, 12:59 AM
Traveler's Avatar
I used an in/lb torque wrench and did them at 20 ft/lbs (well the in/lb equivalent of 20 ft/lbs.) My ft/lb torque wrench barely even clicked set at 20 ft/lbs.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #72 of 132 (permalink) Old 10-02-2008, 01:14 AM
I used the actual PI coolant tube. It exits on the opposite side of the intake as the original setup but you can use couplers, or you can just run rubber hose underneath.
post #73 of 132 (permalink) Old 10-03-2008, 03:41 PM
Seasoned Geek
She is getting there "Little by Little
post #74 of 132 (permalink) Old 10-03-2008, 03:49 PM
You can be done in less than 30 minutes!
post #75 of 132 (permalink) Old 10-03-2008, 04:05 PM
Seasoned Geek
The way i am feeling lately I take my sweet time Fell down the stairs in my house last night and cracked my tailbone Owch !!
post #76 of 132 (permalink) Old 11-02-2008, 08:11 AM
Send a message via AIM to SilverSpy0
Well??? Does it live??? WTF do I do with the 3rd coolant sensor I just found on the coolant tube??
SilverSpy0 is offline
post #77 of 132 (permalink) Old 11-10-2008, 02:31 PM
Seasoned Geek
Yep she lives nice She will haul the mail one or 2 or 3 steps closer now Thank you much guys for all the info and help and kind words
post #78 of 132 (permalink) Old 04-21-2009, 09:26 PM
96tbirdboi's Avatar
getting pi swap done on my 96 thunderbird,i didnt get the 94/95 timing cover,i was told to get longer bolts didnt know bout the timing cover is it true i can use longer bolts or do i need to order that timing cover now
1996 ford Thunderbird LX 4.6L 2V 14.611@98.29
PI Swap(heads/intake)
Comp 262 cams
Sport springs
True dual exhaust(Magnaflow cats/Mufflers
Steeda UDPs
Trick flow tb/plenum
96tbirdboi is offline
post #79 of 132 (permalink) Old 04-22-2009, 03:49 PM
96tbirdboi's Avatar
or is the swap need for the explorer swap components only???
Comp 262 cams
Sport springs
Steeda UDPs
post #80 of 132 (permalink) Old 04-22-2009, 08:06 PM
Downbylaw's Avatar
Um. In english, please?
Downbylaw is offline
post #81 of 132 (permalink) Old 04-22-2009, 08:26 PM
Traveler's Avatar
As far as I know, you only need the different front cover for the explorer swap. I did a complete heads/intake PI swap on my car and used the original 97 front cover.
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #82 of 132 (permalink) Old 04-27-2009, 11:06 PM
Clueless Poster
v8_superbirdy's Avatar
Send a message via AIM to v8_superbirdy Send a message via Yahoo to v8_superbirdy
i've got some questions
so today i just bought a set of pi windsor heads with valve covers spark plugs in them and the pi manifold.
now i've searched and read the pi swap articles.
1.) i want to know if there are any holes different from the romeo heads ie oil holes or coolant holes. im not worried about the valve covers as i got them in the package.
2.) also i read this in the swap tech article but no one mentions it but i have a 97 sport 4.6 will i need the newer "style" dipstick tube? it sasy you do but no one is mentioning it.
3.) can i swap over the aluminum cross over from my old manifold to avoid having to drill and tap a 3/4 hole for the second coolant sensor? i read something about swapping over the coolant crossovers to avoid having to do that but i could have misunderstood it.
4.) will i have to have a tune? i know this increases compression quite a bit to something like 10.5/1. so i assume there will be some detonation but if i run premium can i avoid having to tune it for the heads?
5.) what is the recomended gap for the sparkplugs with the new pi heads?.
6.) is there any special things im missing?
my other ride is an ambulance!
1997 V8 sport - first car - sold 6/7/10
2006 silver mustang gt premiumcustom made grill, frpp shorty headers, pypes cat back exhaust, hurst billet pro shifter,
v8_superbirdy is offline
post #83 of 132 (permalink) Old 04-28-2009, 03:54 PM
1) No
2) Don't know about windsor heads but definitely not with Romeo
3) Yes
4) Yes. Running premium is a band-aid for the swap and will leave a lot of power on the table.
5) Same as stock
6) No comment
post #84 of 132 (permalink) Old 04-28-2009, 04:25 PM
Faster than Porkchop
cjchevez's Avatar
I used my old dipstick with Windsor heads its fine . I agree with everything master486 said .
1997 Ford Thunderbird 4.6 Sport .
60'...... 2.06
1/8th .. 9.194
mph .... 77.13
mods*
PI heads *PI intake*Mark VIII torque converter*Cobra T-loc w\4.10's * Jmod*tranny fluid cooler*P&P stock T/B & plenum*UD pulleys* Dynotech 4in ds*80mm Lightning maf*Xcal2*02 GT intake tube.
cjchevez is offline
post #85 of 132 (permalink) Old 04-28-2009, 07:27 PM
Clueless Poster
sweeeet
i went shopping for head gaskets but i don't know which ones to get summit seems to have really good prices anyone have some suggestions for me.
post #86 of 132 (permalink) Old 04-28-2009, 07:42 PM
Buy the ford head changing kit it includes new gaskets and bolts and dipstick tube all for an affordable price
post #87 of 132 (permalink) Old 04-28-2009, 08:43 PM
Clueless Poster
thanks just looked it up thats not a bad price at all. im going to redo all the gaskets.
post #88 of 132 (permalink) Old 05-31-2009, 03:08 PM
I'm about to undertake the intake swap myself in a couple months, everything I think I have straightened out except the issue regarding the coolant temp. lockout sensor for the SATC. I've been combing through articles I found through Google and here on the forums and all I seem to find is people saying it needs to be addressed - no details or (my favorite) pics. I don't quite understand how or why it needs to be relocated; I can't really see where it screws into on the car with everything in the way. What extra parts do I need to get it "relocated" properly? I suppose I could just find out when I get there, but I prefer to know what I'm getting into before I get into it.
post #89 of 132 (permalink) Old 05-31-2009, 03:18 PM
Slightly Disjointed
I'm not even using that sensor, but heres the issue if you want to keep it...
Its attached to the old valley heater tube via a fitting, the PI tubes dont have this fitting. So what you do is cut the stock tube 1-1/2" to 2" after the fitting (on the valley side, not the heater core side) flare the end, and run a rubber hose from the PI tube to the flared stock tube.
This will also allow the heater core hose to fit like its supposed to
post #90 of 132 (permalink) Old 05-31-2009, 03:21 PM
Hm, I see... basically like replacing the end of the PI tube (which doesn't have the fitting) with the end of the NPI tube - which has the fitting.
