PI Explorer Engine Swap Article - Page 5 - TCCoA Forums
post #121 of 132 (permalink) Old 03-22-2013, 04:26 PM
Slightly Disjointed
Yes but look for a newer trans anyway.
post #122 of 132 (permalink) Old 03-22-2013, 04:31 PM
Paulyrats's Avatar
Okay and by newer what youd you suggest?
Because i actually just had mide rebuilt about a month ago?
Paulyrats is offline
post #123 of 132 (permalink) Old 03-22-2013, 04:44 PM
If the 95 is a 4.6 mod motor and your swapping in an Explorer 4.6 PI aluminum block engine, then yes, they are a match. All mod motors have the same transmission bolt pattern EXCEPT the 92 bastard block in the Crown Vic/Grand Marquis/Town Car (and 91 Town Car).
Bangster is offline
post #124 of 132 (permalink) Old 03-22-2013, 04:53 PM
Slightly Disjointed
98 Mark VIII or 99+ Mustang or civilan CVs. The intermediate 1 way clutch and converter in the 94/5 transmissions are on borrowed time in performance applications.
post #125 of 132 (permalink) Old 03-22-2013, 05:01 PM
Paulyrats's Avatar
Okay Great, Thanks for all the info guys.
post #126 of 132 (permalink) Old 07-06-2013, 10:21 AM
very good write up.especially a newb like me.
rviera5 is offline
post #127 of 132 (permalink) Old 07-06-2013, 01:10 PM
Obviously, the FWD versions of these blocks will not fit.
The Lincoln Continental is a good source of heads, however.
post #128 of 132 (permalink) Old 07-06-2013, 09:39 PM
is it really difficult to swap a pi motor into a 94 tbird,i can get a 02-05 explorer motor for 300 bucks from one of my friends that own a junkyard. I left chevy and gone ford.
rviera5 is offline
post #129 of 132 (permalink) Old 07-06-2013, 10:29 PM
Slightly Disjointed
I'm surprised they aren't more popular for this. 99-02s are common yard sights yet you never see the engines leave them until the yard finally crushes the body. With my local yard prices you can get their C heads $130-140 a pair when all is said and done.
Those Continentals are surprisingly easy to tear down as well. Despite the assumption that a 90* DOHC being transversely mounted in a Taurus engine bay would be a nightmare to work on, it's surprisingly easy. Way easier than any RWD modular(seriously!). Granted I've only gone as far as pulling the valve covers off of them, but that was a breeze, on both sides. Can anyone say that about pulling 4V covers from a FN10 or SN95? Thusly, I can't imagine the heads would be bad at all. Definitely not bank 2 at least.
post #130 of 132 (permalink) Old 07-06-2013, 10:44 PM
cool i appreciate it
im going to do a rebuild and I don't know if im going to push on doing a full pi swap or just do heads and intake. im not worried about money,im more worried on time. im also trying to see what is going to pull more power.
rviera5 is offline
post #131 of 132 (permalink) Old 07-06-2013, 11:53 PM
Slightly Disjointed
Full engine swap is way more time effective. Pull the old one out and drop the new one in. For $300 it's WAY cheaper than a headswap too. Gaskets and TTY bolts aren't cheap.
post #132 of 132 (permalink) Old 07-07-2013, 01:38 AM
ok
I got to read the pi swap article again I think I only got to swap over a couple of things.
rviera5 is offline
