AC Compressor Pulley - TCCoA Forums
post #1 of 9 (permalink) Old 03-18-2017, 01:33 PM Thread Starter
Natesriv's Avatar
Is it possible to remove the pulley to the A/C compressor without pulling the compressor out? I'm getting a warbling squeak on acceleration and the only thing there is the compressor. I've already changed the idler and tensioner pulleys...
Don't like squeaks!
Thanks amigos!
N
Natesriv is offline
post #2 of 9 (permalink) Old 03-18-2017, 01:49 PM
Which motor? You may be able to bypass the A/C pulley with a different belt and arrangement.
This will avoid having to pull said pulley.
Fuelly
RalphP is offline
post #3 of 9 (permalink) Old 03-18-2017, 02:29 PM Thread Starter
Natesriv's Avatar
I want to keep the A/C.
Natesriv is offline
post #4 of 9 (permalink) Old 03-18-2017, 03:43 PM
Oh.
Yah, you can just replace the pulley; however, do remember, that compressor is ancient also.
I'd replace both, and convert to R134a (hey, that's what I DID do!)
But the pulley and clutch can be swapped separately. See, for instance, 1991 MERCURY COUGAR 5.0L V8 A/C Compressor Clutch | RockAuto
Fuelly
RalphP is offline
post #5 of 9 (permalink) Old 03-19-2017, 11:43 AM Thread Starter
Natesriv's Avatar
So I think I'll buy a compressor and clutch as they can only be the ones squeaking. Guess I'll have Goodyear install them as I don't have all the tools needed, nor a lift!
Natesriv is offline
post #6 of 9 (permalink) Old 03-19-2017, 12:09 PM
I didn't need the lift; DID need my vacuum pump, gauges, et al.
Goodyear will also want to swap the accumulator and the expansion valve; you should refresh all the seals / o-rings; and I'd consider having them flush what's left in the system.
Also, they'll want to convert to R134a; that does blow ice cold in our 1991 in 100F temps, so that's good.
Fuelly
RalphP is offline
post #7 of 9 (permalink) Old 03-21-2017, 08:02 AM Thread Starter
Natesriv's Avatar
They don't service R12 systems to even hold my refrigerant (other's might). I bought a refurbished clutch, pulley and clutch coil for a great price.
I'm wanting to change them as I believe since the idler and tensioner pulleys were worn out, the a/c clutch must also be.. Swap them out and see if my warble goes away.
Natesriv is offline
post #8 of 9 (permalink) Old Yesterday, 03:28 PM Thread Starter
Natesriv's Avatar
Swapped out a/c coil, pulley and clutch today. Old one spins freely, but you can hear the clicking of the bearing as it spins. Kept the OEM coil, it's working just fine. Was a little bit of a PITA, had to remove the battery and undo the tranny line to the radiator... also had to buy a good set of locking clip pliers...but it's done. The new pulley didn't want to go on without some help from Mr. Heat Gun...but she's on now.
I've been on a hunt to eliminate worn out parts noises from the engine bay... almost there
Done the tensioner pulley, idler pulley, a/c pulley. I do notice some "play" in the pulley for the power steering... end slap, is that what they call it... ?
Natesriv is offline
post #9 of 9 (permalink) Old Yesterday, 09:53 PM
It may be end slap; it may be time to replace that power steering pump.
Or convert to a Saginaw pump. (That appears to be for the not-faint-of-heart. I'll keep my Ford pump, thankewvellymuch)
Fuelly
RalphP is offline
