Just to verify... 19lb injectors? - TCCoA Forums
 1Likes
  • 1 Post By Natesriv
post #1 of 18 (permalink) Old 03-26-2017, 03:31 PM Thread Starter
Natesriv's Avatar
They're orang'ish yellow on my V8.. I'm wanting to swap them out with some refurbs to ensure I have a clean pattern. I'm getting very faint hints of pinging on moderate accleration.
I'm going to swap the injectors, put on new spark plugs and wires and a new fuel filter. She runs fine now, but I want that piece of mind.
So mine should be 19lb's
Thanks guys!
Natesriv is offline
post #2 of 18 (permalink) Old 03-26-2017, 03:35 PM Thread Starter
Natesriv's Avatar
Oh and the fuel pressure regulator too
Natesriv is offline
post #3 of 18 (permalink) Old 03-26-2017, 06:26 PM
Woodman's Avatar
Thanks guys!
Why not just clean them?
Woodman is online now
post #4 of 18 (permalink) Old 03-26-2017, 06:46 PM
Also... a dirty or fauly MAF sensor is usually the culprit with pinging under closed loop acceleration (skewed timing).
97 Laser Red Thunderbird LX 155k, Stage 2 4.6L 2v N/A | 300 BHP (255 RWHP, 290 RWTQ) | 13.95 @ 97.58 | Build details | Pics at the Lorain Assembly plant
96 Ivory Mark VIII 233k, stock 4.6 32v on coils; New engine at 185k
post #5 of 18 (permalink) Old 03-27-2017, 07:58 AM Thread Starter
Natesriv's Avatar
Question
On 3rd bottle of fuel system cleaner... How to clean them manually? Don't have any tools for that....
Natesriv is offline
post #6 of 18 (permalink) Old 03-27-2017, 08:00 AM Thread Starter
Natesriv's Avatar
MAF cleaned when I got it... Sprayed a good amount of MAF cleaner when I took it off. WAS giving me a lean error code left bank when I bought it, but using premium gas and fuel system cleaners has erased that code....
Natesriv is offline
post #7 of 18 (permalink) Old 03-27-2017, 08:00 AM Thread Starter
Natesriv's Avatar
So.... 19lb????
Natesriv is offline
post #8 of 18 (permalink) Old 03-27-2017, 09:26 AM
CDsDontBurn's Avatar
Stock, yes. Orangish Yellow.
https://www.dropbox.com/s/wfsruipowl...53648.jpg?dl=0
EDIT:
Sorry, DB won't let me link images anymore so you need to click the link.
CDsDontBurn is offline
post #9 of 18 (permalink) Old 03-27-2017, 01:44 PM
gordonm1's Avatar
I'll second the 19lb injectors. I swapped in some newer four hole rebuilds when I did my intake. You're supposed to get new O-rings for them or it's advised.
Didn't improve my fuel economy a bit. Since it was done with the Cobra intake I don't know if it helped any.
gordonm1 is offline
post #10 of 18 (permalink) Old 03-27-2017, 03:54 PM Thread Starter
Natesriv's Avatar
Yeah, I'll put new O-Rings too... looks relatively easy compared to the darned A/C pulley!
Natesriv is offline
post #11 of 18 (permalink) Old 03-27-2017, 04:22 PM
Woodman's Avatar
They're easy to replace. Just pull them out and push the new ones in. O rings are cheap too.
Something to consider, if you're planning on upgrades in the future, 24# aren't any more expensive...
post #12 of 18 (permalink) Old 03-27-2017, 04:56 PM
You might want to get the new Green/Blue orings they're putting on the new cars; something about fuel compatibility.
I got them from the same store I bought the new screens from.
You'll want to replace the screens.
injector-rehab.com Siemens-Top-Feed-Upper-O-Ring
injector-rehab.com Siemens-Top-Feed-Lower-O-Ring
www.mrinjectorparts.com's application guide
I rebuilt and cleaned a couple of sets last year; I made an injector driver out of a PWM board I bought from GuitarMaestro with some other parts.
I wouldn't hook one directly to the battery, that's not really good for them. I used a power supply, and about 8V.
An easy cleaning rig: A 20cc syringe fits over the top of the injector, and a small piece of model airplane fuel line tubing between it and another 200cc one full of cleaner lets you clean the injector as it runs.
I used Chemtool B-12; it's not quite so flammable as other things.
They have a great pattern now.
post #13 of 18 (permalink) Old 03-27-2017, 05:07 PM
^^ I got this set. IIRC, it was from this same seller. Price has gone up a couple dollars since I bought them, it seems.
FUEL INJECTOR REPAIR KIT O-RINGS, PINTLE CAPS FILTERS FORD 4.6L 5.0L V8 | eBay
post #14 of 18 (permalink) Old 03-27-2017, 05:55 PM Thread Starter
Natesriv's Avatar
Yup, that's coming up next free paycheck...
I'm running about 35 psi at idle. Turn car off, settles at 40 psi. All within spec.
Will 24#'s do anything tangible? Any mods needed ?
Natesriv is offline
post #15 of 18 (permalink) Old 03-27-2017, 05:58 PM
Slightly Disjointed
No, and you'll need to flash the PCM for them.
post #16 of 18 (permalink) Old 03-27-2017, 06:06 PM Thread Starter
Natesriv's Avatar
Just ordered an eBay set of refurbs for a decent price. New filters, ultrasonic cleaned, new O-Rings...
Will install this weekend if the weather doesn't turn to crap.
After that, tranny flush, POSSIBLE new power steering pump (lots of end slap) and a 4 wheel alignment/wheel double check balance....boom... she's up to my specs.
Thanks for the help guys!
CDsDontBurn likes this.
Natesriv is offline
post #17 of 18 (permalink) Old 03-27-2017, 07:08 PM
Woodman's Avatar
The only reason to go with 24# injectors is if you expect to make between 300 and 375 hp at the crank. The idea is, you want the duty cycle to be about 80% total capacity, and if you try to run the stock injectors for those power levels, you're running over 90% duty cycle, which wears them out faster, limits top end as they just cannot keep up.
That's why I said if you plan on other upgrades (heads, cams, headers, intake manifold, etc) it may be worthwhile. But if you're staying stock for the most part, absolutely no advantage and not worth the cost of a tune.
post #18 of 18 (permalink) Old 03-28-2017, 07:10 AM Thread Starter
Natesriv's Avatar
I'll stick with 19lbs.
Don't think I need a fuel pressure regulator, if I'm at the right pressure at idle and engine off... I'd suspect it's working just fine.
Natesriv is offline
