Today I put in new spark plugs/wires and new fuel injectors (refurbed, 19lb)..oh and a new fuel filter.
Everything went fine... runs good.
However, I'm still hearing pinging/rattling under two conditions
1: Modertly low throttle I'll hear faint pinging, lets up the second I lift off the throttle
2: Punching it... once I'm flooring it, getting to about 80 it pings/rattles quite loudly. Sounds like it's coming from the left side which would include that fuel rail AND the power steering pump.
I've replaced the tensioner, idler and the a/c coil/pulley and clutch. I do notice a lot of end slap in the power steering pulley.
So my only ideas about what's the pinging:
1: bad power steering pump
2: actual lean condition so it's real pinging (fuel pressure checks out at idle & key off)
3: timing chain rattle
The car only has 83k miles, so I don't see where a timing chain could be part of it.
That pedal to the metal was only twice to about 80 then off. NO more of that until timing set. I hardly ever punch it beyond the downshift to pass someone. Not Road Warrior escape velocity
I don't have a timing light to set anything.... What is factory? 10° BTDC?
MAF cleaned awhile ago.. I'll clean again tomorrow.
Factory should be on the emissions label under the hood; also, it's in the factory service manual.
For my 1991 5.0, it's 10* BTDC, with the timing plug pulled (to disable ECU advance).
You CAN run it 12* to 14*, but by 14* you're hard into "What? You only have 91 octane? I'll blow my motor!!!" level if anything else isn't quite right.
I'm going to borrow a buddies timing light. I looked at the flywheel and saw the markings for 10. There are two. The flywheel moves clockwise when the car is running, so I should set my timing to the 1st 10° I see? 0° must be TDC.
Also, the spout connector is located on the firewall, passenger side. I can see it, but just want to be sure.
Well, you can cheat if the timing light has the timing advance knob; set the knob for 10* and clock to 0* on the display; then set back to 0* on the knob and that one is the 10* one. I think you're right, but I cheated a bit; my harmonic balancer has a Mr. Gasket timing tape on it.
The 10° BTDC mark is just a little bit ahead of the "TIMING" text stamped into the indicator. Maybe 1/8". I need to make a finer line RIGHT on the 10° mark.
Will I be able to fine tune that 1/8" to be closer to the actual indicator position?
You could rewire and convert to the later Explorer 5.0 setup; but you'll still need to do the initial setup on the cam sensor.
Also, 2* isn't that critical.
Plus - I'll bet MORe than 7 to 8 BTDC.
Which begs another question - what kind of shape is your harmonic balancer in? It may be failing, slipping, and as a result your ignition timing may be off (because it's been reset).
I'm 99% sure I'm the 3rd owner. The previous owner (husband and wife) were born in 1929 and 1930...and that's not a typo! They lost some paperwork from 1999 behind the glovebox. So the guy was 70 when it was registered with 25,000 miles. Gives me a warm fuzzy that he didn't tear it up.. Older people are more likely to take cars in for service properly.
Knowing that, I'm not surprised it's still good. But the other factor to consider is TIME... I've no clue how long the car was idle the last 17 years. With that mileage, that's like 3-4k a year... to get to my current 83K
So I agree, it's not time to tear into that just yet.
About the balancer...at idle it hovers around 12-13°....it's not rock steady. Looking at the spin of the balancer, I don't see wobble, but it's not a smooth spin but I suppose it's because it's not the same width around the circumference. So as far as I know, it's totally fine.
Well, looking at more videos... Should I set it to 10° with the spout connector out. Then tighten dist back down, put plug back in, check again and if it's PAST 10° that's what it should be?? With the spout in, it's right at about 12-15° at idle..........
Runs fine, but just DOUBLE checking.
I'm using a regular inductive timing light btw..not knobs or adjustments
Start the engine and bring it to operating temperature.
Using the timing light, set initial to the setting you would like to test, rotating the distributor CW will advance timing, and CCW will retard timing. 10° BTDC is the stock setting, but you may want to check if 12° BTDC or 14° BTDC will work for more power.
Tighten distributor base bolt and confirm setting did not change.
Reconnect the SPOUT jumper plug into the connector.
Check timing change with the timing light, the reading should be between 20° - 24° BTDC = sign the computer is controlling spark advance.
Still getting a little bit of pinging... light moderate acceleration, nothing on WOT.
Today I replaced the ACT sensor. Boy was the old one gunked up!
Still a little, but since I've reset the timing (again to 10° BTDC), cleaned the MAF and put in a new ACT, I'll unplug the battery - tonight to clear any fuel trim levels and start fresh. I suspect it'll take a couple of days of driving for the system to settle down and work.
What pinging there is now is very light...and from what I read, it's a fine balance to keep these engines at peak.... fun to work on though!
Well, I'm stumped!
It doesn't ping when the engine's cold. It'll ping when it's fully warmed up. It's not over the top, but you can hear it in the background at about 3/4th throttle, like going up a hill & such.
I've set the timing to 10° spot on..it advances.
My balancer looks fine
New EGR and ACT
New plugs, wires & fuel injectors
New PCV and cleaned PCV mesh
Separated plug wires 2 & 4 and 7 & 8 on wire looms
Not sure what it could be I hear possibilites
1: valve clatter
2: manifold cracks
3: vacuum leaks
I've no evidence to support any of those... 98% of time the car runs just fine...it's just those press the throttle moments...
When I did the timing, I misunderstood some directions and set it to 0° BTDC and it ran fine. But I don't think the engine got up to full temp.. So I should set it back to 5°? I googled the effects of 0° (I know the ECU advances it with the spout connector back on)... I've thought of putting it back to 0° if it doesn't damage the engine.
OP:
Since I see that the root cause issue you are trying to solve is related to timing under load:
1) How long have you had the car? Are you certain it's not bad gas?
2) Have you done a vacuum test? If you are reading low vacuum at idle, it's time to find the leak. The gaskets, a manifold crack, or even the valves being leaky could cause this issue
If you have the intake off, take the valve covers off and:
- See if you have any play in the rocker arms
- Loosen the rocker arms so the valves are shut (tap the springs with the mallet) and redo the vacuum test to see if the leak is at the valves.
See my experience: http://forums.tccoa.com/8-engine-5-...ing-surging-partial-throttle.html#post1924786
3) have you done a compression test?
4) Do you have a real oil pressure gauge? Low oil pressure could be a sign of really worn bearings which could lead to knocking. The condition of your bottom end is not something you can confirm without pulling the oil pan off but confirming your oil pressure is a good indicator to see how worn out your engine may actually be.
Keep in mind that even though you think it's a "fresh" engine b/c it only has 85K mi on it, this was an engine architecture that was designed in the 60s and back then, they did not expect an engine to last this long. This is no honda and it's been my experience that my 5.0 engines were due for a rebuild (low compression, felt down on power) by 95K mi even though one of them was owned by an old man. Sure, he might have paid for maintenance whenever someone told him he should have something done but he probably also forgot to do some maintenance.
Your already most of the way to 100K and a harmonic balancer that has slipped slightly is a very real possibility. IMO, Rayo's suggstion makes sense.
Had since Jan, 2017. Owned by older couples... I see some service history in the "carfax" I used. All the recalls seem up to date. No compression tester. The oil pressure seems fine (the dash gauge shows it towards the high end)
No vacuum gauge either... I've looked the top end over to find any hint of a cracked hose... I did put a fuel pressure gauge on the rail. It reads within spec and holds pressure for hours after I turn the car off. Eventually falling to 0.
Another idea: You mentioned new EGR - did you mean the valve?
- Was the pipe gunked up as well?
- I only know this academically b/c I don't have this on my car anymore but I seem to recall that a closed EGR could cause knocking. A real professional mechanic like madmikey could confirm this theory.
Whole thing (not the pipe though, it appeared fine). The valve and the solenoid. That was the post I did a while back about the wiring to the plug...did I have the right wires to the right spot.. I think I do.
Related Threads
TCCoA Forums
1.5M posts
26.8K members
Since 2002
