steering maintenance. - TCCoA Forums
 9Likes
  • 1 Post By XR7-4.6
  • 1 Post By XR7-4.6
  • 1 Post By Natesriv
  • 1 Post By XR7-4.6
  • 1 Post By XR7-4.6
  • 2 Post By Kenz
  • 1 Post By Grog6
  • 1 Post By XR7-4.6
post #1 of 21 (permalink) Old 04-04-2017, 12:31 PM Thread Starter
kids93bird's Avatar
1993 TBird 5.0 auto.
going to replace rack & pinion, tie rod ends and rag joint.
posting this cause this job is better done once by purchasing a quality unit and parts.
any sugestions wil be appreciated.
1993 thunderbird 5.0 H.O A4
2003 Crown Victoria LX
1995 Camaro Z28 M6
1992 mustang LX 5.0 H.O A4
kids93bird is offline
post #2 of 21 (permalink) Old 04-04-2017, 12:53 PM
Rack Doctor ( Mercury Cougar Rack And Pinion ).
The rag joint is NLA; there's been forum posts on "the steering shaft mod" which will have info on what you'll need to do to replace the rag joint. They're mostly done to fit headers; but the same setup will work without headers.
If you don't get the outer ends from TRD, then I'd recommend ACDelco Professional Grade or Advanced Technology or Raybestos PG or AT; the Moog bellows failed inside of a year for me, and the tie rod end boots likewise don't seem to last like Moog did when I was a kid forty years ago.
BTW - BTDT for now TWO racks; the A1 Cardone was not worth the money, alas. The Rack Doctor unit seems to be holding up a LOT better. (Overall, on line, the concensus is "We don't know how good customer service is at Rack Doctor, our rack hasn't failed and we've not needed them." )
Fuelly
RalphP is offline
post #3 of 21 (permalink) Old 04-04-2017, 02:09 PM
Slightly Disjointed
Steering shaft mod shouldn't even be in your vocabulary, just get a 3/4" 36 spline to 3/4" DD universal joint and a short section of DD shaft to join it to the stock coupler. The steering shaft mod changes geometry, this just changes rack couplers with the same geometry.
Is your rack leaking or do you just perceive it being "worn out"? If it's the latter just replace the inner tie rods and be done with it, a lot of people tend to not realize those are serviceable. And remanufactured racks often being dicey, maximizing the life of the existing one is the better solution if at all possible. If the seals are shot, well, cross your fingers. The big issue with remans is that they sometimes neglect resleeving the spool valve cylinder, which gets grooves worn into it by the seals from years of service, and fluid will ultimately seep past and into the driver's side bellow if they're deep enough.
Woodman likes this.
post #4 of 21 (permalink) Old 04-04-2017, 02:44 PM
Natesriv's Avatar
I'm interested in this too. My 93 seems to feel every jolt in the road through the wheel and it seems to wander more than other cars I've had....
And how easy is it to swap out the rack & pinion?
Natesriv is offline
post #5 of 21 (permalink) Old 04-04-2017, 03:13 PM
Slightly Disjointed
Again, it's not the rack, it's the inner or outer tie rods(or something else, or just alignment). You're throwing your money away and opening up the possibility of infinite frustration with crappy remans for no good reason.
It's the probably hardest single part to replace on this chassis.
Woodman likes this.
post #6 of 21 (permalink) Old 04-04-2017, 04:30 PM
I bought an upgrade from DLF that included the pieces to make the flaming river joint work, and the joint.
It's a straight-up bolt in.
IDK if Jay picked up those parts with the suspension parts, but it might be worth asking.
I think only the D piece is custom, but it's stainless, and the joint isn't cheap.
post #7 of 21 (permalink) Old 04-04-2017, 04:52 PM
Slightly Disjointed
The flaming river joint isn't cheap, but there are much more reasonable alternatives
post #8 of 21 (permalink) Old 04-04-2017, 05:17 PM
But it feels SO good.
If Jay isn't making them, I won't feel bad for posting pix and drawings, lol.
DLF was a good dude; not many peeps qualify for his 'farm'...
post #9 of 21 (permalink) Old 04-04-2017, 05:44 PM
Jay's making them; but there are other ways, yes *grins*
Fuelly
RalphP is offline
post #10 of 21 (permalink) Old 04-04-2017, 05:54 PM
Natesriv's Avatar
Oh, I'm not going to change it.. I don't think it's outer tie rods as I just had an alignment and no mention of worn or out of spec. Inner ones... Not sure.
As I continue to learn about this amazing car I'll keep asking questions..
So here' another, inner tie rods easy DIY?
Woodman likes this.
Natesriv is offline
post #11 of 21 (permalink) Old 04-04-2017, 06:13 PM
Natesriv's Avatar
OH, and forgive me, I'm not trying to hijack this thread...just reading along to get more knowledge!
Natesriv is offline
post #12 of 21 (permalink) Old 04-04-2017, 06:33 PM
Slightly Disjointed
Yes, inners are easy, just turn the wheel to the side your working on, remove the bellows and unscrew. There are aluminum lock rivets to prevent them from backing out but they'll simply shear off after your first turn, new quality ones will have a new rivet and you pound that on once they're on and you're done.
Woodman likes this.
post #13 of 21 (permalink) Old 04-04-2017, 06:35 PM
Natesriv's Avatar
Can be done after an alignment and won't affect it?
Natesriv is offline
post #14 of 21 (permalink) Old 04-04-2017, 07:46 PM
Slightly Disjointed
You'll definitely need an alignment
Woodman likes this.
post #15 of 21 (permalink) Old 04-04-2017, 09:11 PM
Kenz's Avatar
From my experience MN12s have a very "responsive" steering feel. You feel more through the steering wheel then you do with most cars. If everything isn't dialed in correctly, any kind of play is present, or anything is out of balance; you will know.
RalphP and Woodman like this.
96 Cougar Sport
96 Tbird LX
Kenz is offline
post #16 of 21 (permalink) Old 04-05-2017, 07:43 AM
Natesriv's Avatar
Yeah, I notice no play (where I turn the wheel, car does nothing)...it's just on some level undulations, it's a little like a jalopy feel..lots of minor corrections...
Now I'm running wider tires than what came with it... and the alignment may be needing adjustment (I'm not sure they did anything with the rear toe-in)... so the quest continues.
Natesriv is offline
post #17 of 21 (permalink) Old 04-05-2017, 05:53 PM
I can actually feel .1mm play in an inner ball joint; my alignment guy said I was nuts, I paid him to replace it, and it totally fixed a little wiggle I had that was driving me nuts.
Replacing both inners made a huge difference, but I'd already replaced everything else.
The Rack is a terrible job on this car, unless the engine is out; and then it's merely difficult, lol.
You have to have all 4 wheels adjusted at once; it's worth the cost.
Use the settings from the article:
alignment
My allignment guy said these were within the specs, but nothing he would ever set it to, normally.
He recommended it to his other customers, and it was well liked; but not for the 'Cruizer' crowd.
This makes my car handle like a dream; YMMV.
Woodman likes this.
post #18 of 21 (permalink) Old 04-05-2017, 06:46 PM
Natesriv's Avatar
Watched a couple of videos on how to change them. Simple enough... but measure the length or count the turns so you're close to before when you do it.
I'm going to pull the tire size tie rod out of it's slot and see if by moving the assembly I can feel if the inner tie rod is worn.. If so I'll replace them.. and if the tie rods themselves are sloppy, them too!
There was some online article on Jalopnik about cars from the 90's being the best to wrench on. That's true!
Here's the link
Cars From the 1990s Are The Best To Wrench On
Natesriv is offline
post #19 of 21 (permalink) Old 04-05-2017, 07:02 PM
Slightly Disjointed
Jalop has obviously never encountered an MN12
Woodman likes this.
post #20 of 21 (permalink) Old 04-06-2017, 12:05 PM
Woodman's Avatar
Very. Motorcraft ones are $13 each on Rock Auto, all you need is a BIG crescent wrench, undo the outer tie rod end (count the revolutions), get the car up as high as you can on good, solid stands, and get both hands on that Crescent and break em loose. They will be TIGHT. The "hard" part is lining the new ones up because they'll be so stiff.
If it were my car, with outer tie rods being inexpensive for the good Motorcraft parts, I'd do them all at the same time and be done with it. Get your alignment done when you're done.
Woodman is offline
post #21 of 21 (permalink) Old 04-06-2017, 12:39 PM
Here's a really good write up on replacing inner tie rods; it's for an explorer, the process is very similar.
Inner Tie Rod Removal and Replacement (Pictures) | Ford Explorer and Ford Ranger Forums - Serious Explorations
Kidd-7 is offline
