Radiator Fan Removal? - TCCoA Forums
post #1 of 4 (permalink) Old 04-23-2017, 01:59 PM Thread Starter
Natesriv's Avatar
Just curious, how do you remove the fan & clutch assembly. I see bolts in the water pump pulley, and bolts between the fan & clutch. And it appears the radiator fan shaft is one BIG nut...
I'm assuming the nut unscrews? I've nothing that large!
Natesriv is offline
post #2 of 4 (permalink) Old 04-23-2017, 02:12 PM
Nut unscrews; it's reverse threaded IIRC.
You can rent the tool from AutoZone et al.
This is covered in the FSM BTW.
Fuelly
RalphP is online now
post #3 of 4 (permalink) Old 04-23-2017, 02:35 PM
The big nut unscrews, but it is regular thread, not reverse thread. They sell a tool that holds the water pump pulley still by going across all 4 of the small bolts that hold the pulley on, but they usually just wind up stripping the heads. I always take these off with an air chisel.
post #4 of 4 (permalink) Old 04-23-2017, 08:20 PM Thread Starter
Natesriv's Avatar
Odd, how a Mustang GT's fan is different from ours. On LMG's site they unbolt 4 bolts and the fan and clutch come right out...
Natesriv is offline
