Radiator npt fitting/plug size for 5.0 radiator - TCCoA Forums
post #1 of 4 (permalink) Old 06-17-2017, 04:51 PM Thread Starter
1991 5.0's Avatar
Does anybody know the radiator plug size "npt"threading I need to plug my radiator trans line inlets .
Because I'm installing a trans cooler that did not come with plugs
Unfortunately I'm not sure and neither is the clueless auto parts.
Motor is 5.0 efi 91 Thunderbird
1991 5.0 is offline
post #2 of 4 (permalink) Old 06-17-2017, 05:29 PM
Rayo's Avatar
If you remove the (2) fittings that the transmission cooler lines thread into on the radiator..
Then you would need (2) 1/4-18 NPT size plugs to seal the transmission cooling section of the radiator, no longer in use..
If you leave the (2) fittings that the transmission cooler lines thread into on the radiator in place..
Then you would need (2) 5/16" plugs to seal the transmission cooling section of the radiator, no longer in use..
1991 Ford Thunderbird Sport
Rayo is offline
post #3 of 4 (permalink) Old 06-17-2017, 06:08 PM
There is no need to plug those holes, no coolant can leak out of them.
post #4 of 4 (permalink) Old 06-17-2017, 06:12 PM
Rayo's Avatar
Just to keep the critters out..lol
Rayo is offline
