Cobra install pics (56K should think twice) - Page 2 - TCCoA Forums
 1Likes
post #31 of 142 (permalink) Old 11-10-2004, 05:41 PM
MaddMartigan's Avatar
Well, if you are doing a stock for stock swap it is a waste of time. You lose performance because the stock 5.0 didn't come with as much power as the 3.8SC.
It is a good base though. If you are going to change the heads and build up the top end along with a decent bottom end then you can have something special. Keep the compression reasonable and supercharge it and you can have something special.
MaddMartigan is offline
post #32 of 142 (permalink) Old 11-10-2004, 06:09 PM
Mike Donley's Avatar
Send a message via AIM to Mike Donley
I am sorry if I disappointed anyone, but I built the engine for car shows at first, not speed. i needed a new engine and wanted something with a little extra power, but until I met the guys in the Bama Mafia, I had no desire to race or go fast. I did not do anything to the heads or intake. Also that time was before I had the SCT chip, and also was the FIRST time I ever ran down a track. It was also mega-HOT that summer day here in Alabama and high humidity. I am planning on running the car again sometime this month or next. when it will be cooler. I also still have the factory exhaust piping around the gas tank, but I have the '92-up fuel tank to swap out so I can put true duals.
I found out a few months ago that my rear brakes were totally shot and had cocked in the drums. They were dragging really bad and this could have contributed to my slow times. I had to completely replace every component of the rear brakes.
Right now I don't have the money to buy go fast stuff like heads and gears, so I concentrate on looks. It goes fast enough for me right now.
Mike Donley
Taylor Spiro-Pro Wires, Jasper Performance 302 long block, polished 1994-1995 Cobra Intake,JBA Shorty Headers,Polished Aluminum Valve Covers, Chrome 75mm Granatelli Bullet MAF, 70mm BBK Throttle Body, MAC Chrome Cold Air Intake, Ford Motorsports Smog Pump Delete Pulley, Removed Air Intake Silencer, MSD Blaster coil, Edelbrock 304 Series SS mufflers, Griffin 3 row Aluminum Radiator, Lincoln Mk VIII Electric Fan, 130 Amp Alternator, Art Carr 1 piece Input Shaft, B&M 2400 Stall Non-lockup C-6 Convertor, Heavy Duty Forward Clutch, A-servo for Overdrive, Transgo Shift Kit, Transmission Oil Cooler, 2003 Cobra Aluminum Differential w/ 3.55 Gears, SCT custom chip.
My CarDomain Pages
Mike Donley is offline
post #33 of 142 (permalink) Old 11-10-2004, 08:03 PM
Drive XR7's Avatar
Send a message via AIM to Drive XR7
How does that fit under the stock hood?
Jason
2003 SVT Mustang Cobra #5364
2001 Pontiac Grand Prix GTP
1991 Mercury Cougar XR7 5.0L - SOLD!
Drive XR7 is offline
post #34 of 142 (permalink) Old 11-10-2004, 08:10 PM
Who is your question directed at?
It fits under the hood if the insulation is removed and a chunk of the bracing is cut out.
Mike Donley
My CarDomain Pages
post #35 of 142 (permalink) Old 11-10-2004, 08:23 PM
Well i think if Best thing about the 5.0L ARE:
No crank sensor to fail
No Crank pulley bolt to break
No Blown Headgaskets
No Nose cone bearings to fail
91 XR7 is offline
post #36 of 142 (permalink) Old 11-10-2004, 08:33 PM
jk69cat's Avatar
mike i need to do that on mine for hood clearance. which brace? the one on the left?
mn12 less!
jk69cat is offline
post #37 of 142 (permalink) Old 11-10-2004, 09:00 PM
The reinforcement is sort of 2 levels Cut out the rearward part and leave the front part.
Mike Donley
My CarDomain Pages
post #38 of 142 (permalink) Old 11-10-2004, 11:34 PM Thread Starter
PostSkank
StupidFly's Avatar
bingo
math > pasta
StupidFly is offline
post #39 of 142 (permalink) Old 11-11-2004, 11:15 AM
jk69cat's Avatar
thanks, thats what i needed . i hate to loose the hood blanket. but i could just cut it out around it. it looks like it was a pretty easy modification.
mn12 less!
jk69cat is offline
post #40 of 142 (permalink) Old 11-11-2004, 12:02 PM
I think you could re-install .
I gues you could reinstall it after cutting the
reinforcement without cutting the hood blanket
Mike
My CarDomain Pages
post #41 of 142 (permalink) Old 11-11-2004, 12:44 PM
Jedi Master
mn12xr7's Avatar
just remember that it is different for the t-birds and cougars, less clearance...or at least that is what i have been told before...
-Orlando
mn12xr7 is offline
post #42 of 142 (permalink) Old 11-13-2004, 09:51 AM
BluBird's Avatar
StupidFly your pic's are helpfull here is a picture of my installed Cobra intake,65mm TB. Also installed 3.73 WOW!
BluBird is offline
post #43 of 142 (permalink) Old 11-13-2004, 01:28 PM Thread Starter
PostSkank
StupidFly's Avatar
what'd you use for that intake tube?
math > pasta
post #44 of 142 (permalink) Old 11-14-2004, 09:15 AM
BluBird's Avatar
I'm using the Densecharger Cold Air Intake and the tube is 3" exhaust pipe. But I ordered a new cold air intake to replace this setup.
BluBird is offline
post #45 of 142 (permalink) Old 12-07-2004, 10:31 AM
jk69cat's Avatar
heres pics of mine .
mn12 less!
jk69cat is offline
post #46 of 142 (permalink) Old 04-30-2005, 09:32 AM
did you do anything with the "thermactor" system on the back of the heads?
thanks,
jeff
lowflying90 is offline
post #47 of 142 (permalink) Old 05-01-2005, 08:06 AM
jk69cat's Avatar
you dont have to do anything with the thermactor system at all . not in the way unless your doing headers
mn12 less!
jk69cat is offline
post #48 of 142 (permalink) Old 05-01-2005, 08:20 AM
well i have the mac headers for the 91 tbird. will it be in the way with these?
jeff
post #49 of 142 (permalink) Old 05-01-2005, 02:02 PM
jk69cat's Avatar
a little, but i just have mine floating
mn12 less!
jk69cat is offline
post #50 of 142 (permalink) Old 05-01-2005, 05:48 PM
what do you mean by floating?
post #51 of 142 (permalink) Old 05-02-2005, 07:58 AM
jk69cat's Avatar
since you cannot use the brackets thats hold anything to the head its just sitting there
mn12 less!
jk69cat is offline
post #52 of 142 (permalink) Old 01-05-2006, 03:03 AM
paulaptrick's Avatar
hi,
I did a search and did not find out what year range of Cobra U/L Intake will work on our 5.0 birds. Can somebody reply the answer?
Thanks to whoever!
paul
Always learning.
Thank You to anybody with straight answers!
paulaptrick is offline
post #53 of 142 (permalink) Old 01-05-2006, 05:07 AM
Originally Posted by paulaptrick
hi,
Thanks to whoever!
paul
94-95 would be the years you are looking for.
1993 Ford Thunderbird LX
Coast High Peformance 342 Stroker
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.73 gears
Custom aluminum driveshaft
Built Darrin/dirtyd0g AOD with wide ratio gearset
dirtyd0g 9.5" Custom Torque Converter
Quarterhorse ECM from Moates
Zeitronix ZT-2 WB O2
No times under new system.......yet.
OMGHI2U
post #54 of 142 (permalink) Old 01-05-2006, 06:49 PM
Thumbs up
glad to see you are still here bro!
and thanks again!
paul
Always learning.
post #55 of 142 (permalink) Old 01-05-2006, 07:29 PM
and thanks again!
paul
Thanks man and no problem.
FRPP 42# injectors
3.73 gears
OMGHI2U
post #56 of 142 (permalink) Old 02-09-2006, 01:41 PM
bad93bird's Avatar
Would the Cobra intake make much difference on an unstock motor? Mine is deffinitly not stock. Close, real close. I couldn't bore it out anymore. Where are yall getting these upper and lower intakes? When ever I find one, it's like $600. I really can't afford that. Rather stroke mine than do the intake. I geuss both would work. I have to put headers on. What do yall do with the thermactor stuff?
bad93bird is offline
post #57 of 142 (permalink) Old 02-09-2006, 02:06 PM
jk69cat's Avatar
see above post about the thermactor parts, theres enough to hold them there with just the hoses. i left mine floating , no brackets . no issues yet , well with that part at least , i paid just under 600 when i bought mine , and that was at employee cost. now that you can not get them from motorsport , your gonna pay what you pay . iyour best bet is to find a used one that has been on a car. they wil go for substainally less than a new nos one
mn12 less!
jk69cat is offline
post #58 of 142 (permalink) Old 02-09-2006, 04:28 PM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
bill look on corral.net, the intakes go for $300-$350. if you are going stroker in the future, then the cobras will not be enough, unless they are ported to hell.
cobra intake ad examples:
http://www.corral.net/forums/showthr...ighlight=cobra
2014 GT
1990 300ZX TT
big mike is offline
post #59 of 142 (permalink) Old 02-09-2006, 05:42 PM
bad93bird's Avatar
I'm not to certain about going stroker. Nothing else will fit under the hood. I surely do not want to put the stock intake on a stroker motor. A cowl hood is out of the question. I need front and rear bumper covers 1st. PCM also.
post #60 of 142 (permalink) Old 02-10-2006, 02:38 AM Thread Starter
PostSkank
StupidFly's Avatar
The trick flow street manifold has been known to work under a stock hood now and then... albeit, with a bunch of bracing chopped off, and even then I believe its pretty darn close. C
math > pasta
