Cobra install pics (56K should think twice) - Page 4 - TCCoA Forums
 1Likes
post #91 of 142 (permalink) Old 03-25-2006, 01:13 AM
The hp calculator says 19hp on a stock motor. Feels like more, probably because of the bigger tb. Throttle response is awesome! I went from a 15.1 @ 89 to a 14.7 @ 91.87
icantdrive55 is offline
post #92 of 142 (permalink) Old 03-27-2006, 12:13 PM
bad93bird's Avatar
I'm going to try to get some kind of new intake. I hope that I have the same or better results as you.
bad93bird is offline
post #93 of 142 (permalink) Old 06-01-2006, 10:30 PM
Gary Bitzer's Avatar
there are quite a few different intakes out there but im not sure if any are actually "cheap". i have the gt-40 on mine and believe me i paid enough for it, wasnt really a tough install but there were a few things that had to be changed/moved. i also did jba headers and bigger TB and MAF sensor at the same time, i noticed a HUGE DIFFERENCE in power at high rpm but low end is the same if not worse, but i also have 3.08 gears, im thinking about changing to 3.55's.
The Collection:
1988 Thunderbird Turbo Coupe; 1989 Thunderbird SC; 1993 Thunderbird SC; 1993 Thunderbird LX 5.0; 1994 Thunderbird SC 5spd; 1995 Cougar XR7 4.6; 1995 Thunderbird 4.6; 1996 Cougar XR7 3.8
The Search begins;
1990 35th Anniversary SC very low miles, auto, loaded
1998 Lincoln Mark VIII Collectors Edition
Gary Bitzer is offline
post #94 of 142 (permalink) Old 06-03-2006, 11:07 AM
Mark M. TCCoA VP's Avatar
Gary,
With the AOD trust me go with the 373s as the 1st gear in the AOD is a dog of a gear.
"Mark M. TCCoA VP. Emeritus"
To the Batmobile ! ! !
ADDCO MN12 big bar R&D guru
Mark M. TCCoA VP is offline
post #95 of 142 (permalink) Old 06-03-2006, 11:13 AM
well i have 3.73's in my 93 sc and i like them, but not on the interstate, it runs the car too hard, thats why i want 3.55's. im not really worried about how fast the car is "light to light" because its a dog anyway you want to gear it until i do some more engine work lol.
The Collection:
The Search begins;
post #96 of 142 (permalink) Old 06-05-2006, 08:49 AM
bad93bird's Avatar
Well with the price of gas going up and up. I don't want gears. If I happen to come across a Rustang sitting around, I will make it a 1320 car.
QUADSQUAD MEMBER
post #97 of 142 (permalink) Old 08-28-2006, 10:37 PM
bad93bird's Avatar
I know this is an old post, where exactly did you grind off the stuff to swap the linkage. I just bought a 65mm T.B. and want to use it. Do I have to use the mustang spring or the birds?
QUADSQUAD MEMBER
post #98 of 142 (permalink) Old 08-29-2006, 12:46 AM Thread Starter
PostSkank
StupidFly's Avatar
I ground off the weld on the very top of the shaft, the spring shouldnt matter, should be the same.... or at least I cant see it affecting anything too much. As long as it is strong enough to close the TB. To be on the safe side I'd go with the spring from the TB you're adapting for use. Before you weld the t-bird spring on, I'd mock it all up and make sure it all functions like it should. Just use common sense on this one, and triple check everything before you weld.
math > pasta
StupidFly is offline
post #99 of 142 (permalink) Old 08-29-2006, 08:32 AM
bad93bird's Avatar
I was looking at your home made C.A.I. Do you have measurements on how long and at what angles it is. I'm going to do that also when I get my T.B. on. I'm going to go to the exhaust shop and have them make me one.
QUADSQUAD MEMBER
post #100 of 142 (permalink) Old 08-29-2006, 10:29 AM Thread Starter
PostSkank
StupidFly's Avatar
I'm afraid I dont have any measurements.... I used to have a template for the plate somewhere. Dont hold your breath on that though. I think I just used a 45* bend, and cut the leg down to fit. I had to build the whole thing slowly and all at once to make sure the dimensions worked out.
math > pasta
post #101 of 142 (permalink) Old 08-29-2006, 10:36 AM Thread Starter
PostSkank
StupidFly's Avatar
Ok, here we go.
Grind off the bump here:
and weld the new plate like so:
make sure you have the linkage on in the proper direction, and that the spring is on as well before you weld. Pay attention to how the spring comes off so you will know how it needs to be loaded when you put it back on.
math > pasta
post #102 of 142 (permalink) Old 08-29-2006, 06:33 PM
bad93bird's Avatar
Pay attention to how the spring comes off so you will know how it needs to be loaded when you put it back on.[/QUOTE]
I don't remember how it was on there. I geuss I'll have to figure it out. Hmmmmm.......
QUADSQUAD MEMBER
post #103 of 142 (permalink) Old 08-29-2006, 09:58 PM Thread Starter
PostSkank
StupidFly's Avatar
I don't remember how it was on there. I geuss I'll have to figure it out. Hmmmmm.......[/QUOTE]
I have confidence in you, shouldnt be too tough. Just stick everything together and try it out with your hand before you actually weld it together.
math > pasta
post #104 of 142 (permalink) Old 08-31-2006, 10:27 AM
bad93bird's Avatar
I'm going to try it next week. I'm going out of town and need the turd. I'll let you know next week how it all goes.
QUADSQUAD MEMBER
post #105 of 142 (permalink) Old 01-23-2007, 09:27 AM
sloth92's Avatar
was it worth it
sloth92 is offline
post #106 of 142 (permalink) Old 01-23-2007, 09:41 AM Thread Starter
PostSkank
StupidFly's Avatar
Originally Posted by sloth92
was it worth it
well, knowing what I know now, I think I would have done a few other things before I did the manifold. I think I would have been happier doing gears and a tune first.
So, I guess if I could go back do everything in a different order, it would look something like this:
-shift kit
-exhaust
-gears
-MK8 E-fan
-THEN Cobra manifold/TB
But I think I would rather schedule a new set of cylinder heads and headers to go in at the same time I did the manifold, maybe a cam too. Its alot easier than taking the top end off the motor twice.
So, to answer your question, I would take care of alot of other stuff before I went to the trouble of replacing the intake manifold. And even then, these heads are still pretty restrictive.
math > pasta
post #107 of 142 (permalink) Old 01-23-2007, 09:44 AM
MaddMartigan's Avatar
To expand on those points, if you want to wake these engines up, you really need to build the top end (heads, cam, intake) and put on a good exhaust and then add gears. I realize that to get a good setup like that you are going to spend ~$3000 or more but that's the way it is with these cars.
1993 Ford Thunderbird LX
Coast High Peformance 342 Stroker
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.73 gears
Custom aluminum driveshaft
Built Darrin/dirtyd0g AOD with wide ratio gearset
dirtyd0g 9.5" Custom Torque Converter
Quarterhorse ECM from Moates
Zeitronix ZT-2 WB O2
No times under new system.......yet.
OMGHI2U
MaddMartigan is offline
post #108 of 142 (permalink) Old 01-23-2007, 12:30 PM
jk69cat's Avatar
when i did mine i did headers, intake, cai, 1.7 roller rockers , new trans with a shift kit . it work her up nicely
mn12 less!
jk69cat is offline
post #109 of 142 (permalink) Old 01-31-2007, 08:02 PM
bad93bird's Avatar
I've been done with mine for awhile. It's ok. I'm going to sell the bird and get something else for now. I'm tired of working on it and never getting anywhere. The sunroof leaks when it rains and the A.C. just blows on the floor. I'm tired of messing with it. I want something I can just drive and change the fluids when it needs it. I'm tired of fixing things. It's just gotten to be too much with this car.
QUADSQUAD MEMBER
post #110 of 142 (permalink) Old 01-31-2007, 08:47 PM
jk69cat's Avatar
well does your sun sheld work properly? if the trough is broken it will leak into the car, also the drains could be pluged, the ac thing is a control head or a vaccum motor problem, i have parts i could get you for those too
mn12 less!
jk69cat is offline
post #111 of 142 (permalink) Old 02-01-2007, 07:42 AM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
bill, i remember seeing a few mn12s at the pick-n-pulls with sunroofs.
2014 GT
1990 300ZX TT
big mike is offline
post #112 of 142 (permalink) Old 02-01-2007, 10:20 AM
or just strip the entire car, lose 800 lbs, and it should be close to a 13...
post #113 of 142 (permalink) Old 02-17-2007, 09:03 AM
bad93bird's Avatar
Well I got the modem fixed. So I'm back for now. I know very little about the sunroof. I was thinking it was the gasket around the glass. Not sure about it. The passenger front drain is plugged up due to the metal fitting to the hose rusted and I couldn't get it fixed. So I broke it off and plugged it.
Now the A.C. I couldn't figure out. I hear alot of stuff moving around in the dash but it still blows on the floor. So I don't know there. If I could get my service manual to load up on here I can fix it. What do yall think. Now I've got another problem which yall can go check out under the 5.0l section.
QUADSQUAD MEMBER
post #114 of 142 (permalink) Old 08-05-2007, 06:05 PM
Send a message via Yahoo to Jim Allen
So, A 70mm throttle body from a Thunderbird SC would bolt up to a 1995 cobra intake and the throttle cables and cruise control would work?
I have a 1990 35th anniversay that i am putting a 347 stroker and GT40 heads E303 cam 1995 cobra intake with a GT40 NOS plate between the lower and upper.
This thread and the Mac full length header thread has saved me alot of trial and error....Thanks
Jim Allen is offline
post #115 of 142 (permalink) Old 08-05-2007, 08:45 PM
jk69cat's Avatar
sc does not have a 70 mm t/b stock more like 60ish
mn12 less!
jk69cat is offline
post #116 of 142 (permalink) Old 08-05-2007, 09:54 PM
BBK makes a 70mm TB #1715
post #117 of 142 (permalink) Old 08-05-2007, 10:02 PM
jk69cat's Avatar
i was saying stock not aftermarket, thats what i thought was being suggested
mn12 less!
jk69cat is offline
post #118 of 142 (permalink) Old 08-05-2007, 10:14 PM
Bradone's Avatar
Measure the intake opening. I've measured 2 at 63mm. I don't know what year they were.
Brad
14.62@95.54 (engine/trans is stock)
Bradone is offline
post #119 of 142 (permalink) Old 08-05-2007, 10:46 PM
I run the BBK 65MM unit.
post #120 of 142 (permalink) Old 05-08-2008, 07:52 AM
1994 SC 5.0 Cobra
Here is a pic of my 5.0 in a 1994 SC. Mods are as follows; 94/95 Cobra intake, 65mm throttle body, GT 40 iron heads, E303 camshaft installed 2 degrees advanced with frpp multi index timing chain on a stock block 5.0 ho. 3000 rpm lock up T/Q bolted to sfi flexplate inside the bellhousing of a 2000 4r70w trans c/w J-mod.
Fresh rebuilt 3.73 traction lock pumpkin. U4PO pcm c/w sct 4 bank chip.
Pro SC is offline
