Cobra install pics (56K should think twice) - Page 5 - TCCoA Forums
 1Likes
post #121 of 142 (permalink) Old 05-08-2008, 11:25 AM
bad93bird's Avatar
Nice. I have the 65mm T.B. My car is now just sitting until I can make enough money to rebuild it. I'm not gonna sell anything. So don't ask. I did notice that with the 70mm MAF and 65mm T.B. It has better throttle response.
QUADSQUAD MEMBER
bad93bird is offline
post #122 of 142 (permalink) Old 07-20-2008, 06:51 PM
88TurboCoupeman01's Avatar
Send a message via AIM to 88TurboCoupeman01 Send a message via Yahoo to 88TurboCoupeman01
Mike thats the sexyiest motor I have every seen. MUst be a pain to clean.
1988 Thunderbird Turbo Coupe 5 speed manual
Mods. tinted windows, premium sound, red interior with red velor seats,Mild Cam, 30 degree valves, HP rolor rocker Arms, Light weight Aluminum radiator., Kenwood compotion CD player, with comption 6speakers.
1988 Ford Thunderbird Turbo Coupe Dailey Driver
1997 Saturn SC2 Custom Yellow w/ EVO 5 Body Kit.
1987 Ford MUstang LX 4cyl my first car RIP
www.myspace.com/racenut97
http://cardomain.com/ride/3114339
88TurboCoupeman01 is offline
post #123 of 142 (permalink) Old 07-20-2008, 10:42 PM
jk69cat's Avatar
then check this one out
in my 69 cougar
mn12 less!
jk69cat is offline
post #124 of 142 (permalink) Old 11-04-2008, 07:29 PM
Send a message via Yahoo to Jim Allen
I am building a 347 with GT40 heads and a 1994 cobra intake in a 1990 Supercoupe with a M5R2 5 speed...any advice would help
Happiest when I am digging through a salvage yard.
Jim Allen is offline
post #125 of 142 (permalink) Old 11-05-2008, 08:20 AM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
that's gonna be a slow 347. that top end belongs on a 302. a stroker needs much better heads and intake.
2014 GT
1990 300ZX TT
big mike is offline
post #126 of 142 (permalink) Old 11-05-2008, 09:05 AM
jk69cat's Avatar
your so wrong mike that intake is capable up to around 500 horse, the heads are a little small , but will make very decent power
mn12 less!
jk69cat is offline
post #127 of 142 (permalink) Old 11-05-2008, 09:09 AM
maybe with forced induction..
post #128 of 142 (permalink) Old 03-09-2009, 09:49 AM
decipha's Avatar
wow thats 3 of us that run that same msd street fire ignition coil
i really haven't forgotten how that 302 look so at home in there, i don't miss it for a second though.
supercoupin'
www.EFIDynoTuning.com
decipha is offline
post #129 of 142 (permalink) Old 05-12-2009, 11:40 PM
Send a message via AIM to 1992tbirdsport
so did the power to work ratio make it worth it?
1992tbirdsport is offline
post #130 of 142 (permalink) Old 05-13-2009, 07:09 AM
jk69cat's Avatar
yes
mn12 less!
jk69cat is offline
post #131 of 142 (permalink) Old 09-13-2009, 07:38 AM
svtfiend@yahoo.com's Avatar
so, guys the two hose ports on the back of the cobra intake, should they just be capped? when i bought my bird, one was capped, the other has a hose with a breather that just sucks in engine compartement air... and it whistles on idle. i know the old fox body stangs used one of these for the map sensor, but we don't have em. do they do anything or should they be capped?
1991 Super Coupe -
Performance=5.0 H.O. w/M5R2 5speed, 3.27 gears w/CF TracLoc,95 Cobra intake, 75mm Power throttle body, fenderwell CAI, C&L 73mm mass air w/24# injectors, FRPP E-Cam,Trickflow spring kit & Crane 1.7 roller rockers on stock E7s, MAC shorty headers, Flowmaster cat back w/hiflow cats, MSD plugs, coil, wires, electric cooling fan, 190lph Walbro fuel pump, BBK pulleys, and a B&M shifter. Drilled/slotted rotors, power brake conversion, Tokico Blues, Eibach springs, tons of poly, T4MO ecm
svtfiend@yahoo.com is offline
post #132 of 142 (permalink) Old 09-13-2009, 02:04 PM
ABA
ABA's Avatar
Darn, I was hoping to see a supercharged 4.6 COBRA swap...not just an intake.
Has that been done btw or did I miss it?
'93 T-Bird bone stock 3.8, 17" Cobra R rims and Bridgestone Potenza Tires.
Clear corners with Stealth bulbs, Audi style LEDs, Blacked Out Tails.
ABA is offline
post #133 of 142 (permalink) Old 09-13-2009, 07:59 PM
Slightly Disjointed
You missed it.
post #134 of 142 (permalink) Old 09-14-2009, 03:18 PM
ABA
ABA's Avatar
You missed it.
Found it, all by myself too.
ABA is offline
post #135 of 142 (permalink) Old 05-03-2010, 12:33 AM
I got a 93 5.0 T-bird, which year Cobra would I need for the manifold to fit on my car?
nigib is offline
post #136 of 142 (permalink) Old 05-03-2010, 07:13 AM
Mark M. TCCoA VP's Avatar
SN 94-95 5.0 Cobra manifold
"Mark M. TCCoA VP. Emeritus"
To the Batmobile ! ! !
ADDCO MN12 big bar R&D guru
Mark M. TCCoA VP is offline
post #137 of 142 (permalink) Old 05-05-2010, 09:40 PM
Thanks, am I gonna need to get a new throttle body? or anything else?
nigib is offline
post #138 of 142 (permalink) Old 01-24-2011, 02:55 PM
i will be putting a cobra intake on mine here really some,thanks for the info.
91 thunderbird sport,5.0,black lots of stuff to come......
4x4troy is offline
post #139 of 142 (permalink) Old 10-12-2011, 11:08 PM
allenc1007's Avatar
Send a message via Yahoo to allenc1007
Act
I got my cobra intake installed but check engine light is on-where can I put my ACT? I do not have an air box, so that option is out! Thank you
91 5.0 Cold Air Kit(air box delete),76mm C&L MAF, 70mm TB, 24lb Inj, Jet Performance Chip, Headers+Custom Ex, 3:55 Limited slip
allenc1007 is offline
post #140 of 142 (permalink) Old 10-13-2011, 08:17 AM
Post a pic of your intake system so we can see it. I installed the senser in the lower intake as it was designed but I had to drill out and tap the boss. You can't do that with the intake installed. With no air box I am not sure where to put it so that is why I am asking for a pic of under the hood
Mark
post #141 of 142 (permalink) Old 10-13-2011, 05:38 PM
allenc1007's Avatar
OK> thanks-gotta find a camera!
post #142 of 142 (permalink) Old 10-29-2011, 06:18 PM
allenc1007's Avatar
I put an airbox on and put the ACT in as described in StupidFly's posting from 2004. The check engine light is no longer on. Never did find a camera to post picture!
