Cobra install pics (56K should think twice) - TCCoA Forums
 1Likes
post #1 of 142 (permalink) Old 10-06-2004, 11:06 PM Thread Starter
PostSkank
StupidFly's Avatar
I swapped a Cobra intake into my '92 T-bird somewhere around June or July. Anyway, I'm finally getting around to posting some of the pics, maybe I'll get off my butt later and actually put together a write up like I said I would. Anyway, here we go.
First things first (other than removing the old manifold), I had to take care of the throttle/tranny/cruise linkage issue. As the mustang linkage isnt compatible with the MN12 setup. So, it was time to do some grinding
Under that pretty pink-checked cloth is a 65mm BBK throttle body. There are 70mm units made to fit the SC t-birds, and those will also fit the 5.0L. However I opted for adapting the 65mm unit because it has been billed as the optimal size for a mostly stock 5.0L (at least one thats in a heavy car.... like mine).
After some grinding heres what I had:
Thats the 65mm unit, the linkage from my old TB, and the return spring.
The shape is the same, but things dont fit perfectly.
With some patience and a few minutes with a hand file, everything fit just dandy. Now, before you rush off and weld that sucker on, make sure you remeber to put the return spring on first.... otherwise you end up having to grind it back off and put it on anyway.
Since my lower manifold isnt equipped with an ACT bung, I had to relocate it to my airbox. Since my car is NA, it wont make any difference. So I cut the harness and extended the wires.
Then I found a suitable location on the airbox where the sensor wouldnt be in the way, and drilled a hole. I'm afraid I dont know the size hole I drilled, but I recomend drilling it small and then reaming out the hole until you can force the sensor through, the threads will hold it in place.
Then it was just a matter of routing wires.
I wont go into any detail on the actuall install as it is fairly straightforward. However I do suggest you keep a helper around. Especially when puting either manifold piece in place. That way on person can position the manifold, while the other makes sure that gaskets stay where they should, and any connections are made.
Heres a few side-by-sides of the Cobra manifold and the stocker:
Viva la difference
I was able to close the hood without cutting any reinforcement... barely. No visible bulge, but there was definetly resistance. I didnt get around to trimming the hood bracing until a week or so later, and there was a visible rub mark on the manifold. So I recomend taking the time to remove the bracing before you go out on any test runs
math > pasta
StupidFly is offline
post #2 of 142 (permalink) Old 10-06-2004, 11:09 PM Thread Starter
PostSkank
StupidFly's Avatar
BTW, if you catch me on any inconsistencies or blatant mistruths, let me know so I can fix them.
math > pasta
post #3 of 142 (permalink) Old 10-07-2004, 06:45 AM
High Output Poster
91HellCat's Avatar
Send a message via AIM to 91HellCat
Did the car get a little kick in the rear after putting that in?
1991 Ford Mustang GT
1998 Lincoln Continental
1999 Mercury Mountaineer 5.0
91HellCat is offline
post #4 of 142 (permalink) Old 10-07-2004, 07:59 AM
Jedi Master
mn12xr7's Avatar
NICE!!! post some more helpful hints and this could be a sticky for two things, intake manifold swap and how to modify a mustang tb.
-Orlando
mn12xr7 is offline
post #5 of 142 (permalink) Old 10-07-2004, 11:34 AM Thread Starter
PostSkank
StupidFly's Avatar
aye, a bit I put headers in a week or so later, and once the computer got used to them I was haulin' butt. I could really benefit from some lower gears (my off the line is still kinda weak) but since I do alot of highway driving I'm not so sure that'll happen.
math > pasta
post #6 of 142 (permalink) Old 10-07-2004, 03:28 PM
56k was okay.
Looks good, bout how long did it take.
post #7 of 142 (permalink) Old 10-07-2004, 03:36 PM
Mark M. TCCoA VP's Avatar
Welcome to the Cobra club. Good job!
Mark
MrHorsepower likes this.
"Mark M. TCCoA VP. Emeritus"
To the Batmobile ! ! !
ADDCO MN12 big bar R&D guru
Mark M. TCCoA VP is offline
post #8 of 142 (permalink) Old 10-07-2004, 05:38 PM Thread Starter
PostSkank
StupidFly's Avatar
Originally posted by badbird95
56k was okay.
glad it was fairly easy on the 56kers.... btw the original photos are gigantic if anyone wants a blown up copy of any of them.
If I were to do it again, and I had all my parts and tools there, I could get it done in a day (assuming I'm not stopping to take any pics ). As it worked out I arrived at the shop in the evening and got busy modding the TB and removing the old manifold. The next day I did some parts hunting and got everything back together.
I think with 2 guys (who know what they're doing) working the whole time you could move through it pretty swiftly.
math > pasta
post #9 of 142 (permalink) Old 10-07-2004, 05:40 PM Thread Starter
PostSkank
StupidFly's Avatar
Mark
math > pasta
post #10 of 142 (permalink) Old 10-07-2004, 09:41 PM
Mike Donley's Avatar
Send a message via AIM to Mike Donley
Mark
Yes. Welcome!
Mike Donley
Taylor Spiro-Pro Wires, Jasper Performance 302 long block, polished 1994-1995 Cobra Intake,JBA Shorty Headers,Polished Aluminum Valve Covers, Chrome 75mm Granatelli Bullet MAF, 70mm BBK Throttle Body, MAC Chrome Cold Air Intake, Ford Motorsports Smog Pump Delete Pulley, Removed Air Intake Silencer, MSD Blaster coil, Edelbrock 304 Series SS mufflers, Griffin 3 row Aluminum Radiator, Lincoln Mk VIII Electric Fan, 130 Amp Alternator, Art Carr 1 piece Input Shaft, B&M 2400 Stall Non-lockup C-6 Convertor, Heavy Duty Forward Clutch, A-servo for Overdrive, Transgo Shift Kit, Transmission Oil Cooler, 2003 Cobra Aluminum Differential w/ 3.55 Gears, SCT custom chip.
My CarDomain Pages
Mike Donley is offline
post #11 of 142 (permalink) Old 10-07-2004, 10:32 PM
makes me want to take pictures of mine installed in my Cougar...
except its at the body shop.......
vlipke is offline
post #12 of 142 (permalink) Old 10-07-2004, 10:53 PM Thread Starter
PostSkank
StupidFly's Avatar
Hey Mike, I've been meaning to ask you, is that a custom STB? Or is it a KB piece?
math > pasta
post #13 of 142 (permalink) Old 10-07-2004, 10:54 PM Thread Starter
PostSkank
StupidFly's Avatar
on one condition... yours had better look worse than mine, so far everyone else's engine bay looks way better than mine
jk, get some pics up man
math > pasta
post #14 of 142 (permalink) Old 10-07-2004, 11:04 PM
looks just like the original engine bay for now, except the KNN filter, wich I am going to get rid of, and the intake, oh yea the headrs also...
Winter time the engine will be out of the car, gaskets being replaced (main seal leakes bad) and I will be ordering and putting in Thumper heads, Trickflow stage 1 cam, and 65mm TB.
Now only if I could find somone to do tht darn 373's.....
Oh yea, your install pictures are good, mine is about the same install, except the hood had to be trimmed a little on mine...and supposubly my 95 Cobra intake has been ported by the previous owner. He had it in a Mustang that was supposably turning mid 12's...I'll see if I can find the link with his pictures...
vlipke is offline
post #15 of 142 (permalink) Old 10-07-2004, 11:31 PM Thread Starter
PostSkank
StupidFly's Avatar
I've been eyeing the thumper heads, make sure you let us know how they install goes, and how they work out.
My upper has been extrude honed, but with stock heads and stock(cobra) lower intake, it probably does more harm than good right now
math > pasta
post #16 of 142 (permalink) Old 10-08-2004, 05:45 AM
MaddMartigan's Avatar
Yes, welcome to the club......errrr...something:
MaddMartigan is offline
post #17 of 142 (permalink) Old 10-08-2004, 11:58 AM
Ahh you haven't seen my engine carpartment have yah??
Hmm I can't even REMEMBER when the last time i cleaned under there, along witht he heater hose that sprung a leak and sprayed nice sticky steam everywhere.... and leaves, road grim, ect, ect
Also the last time my car was washed in the last 1 1/2 months was when it rained the oher day
91 XR7 is offline
post #18 of 142 (permalink) Old 10-08-2004, 02:07 PM
jk69cat's Avatar
stupid fly , i want pics of where the interferance with the hood is.
mn12 less!
jk69cat is offline
post #19 of 142 (permalink) Old 10-08-2004, 03:51 PM
zacharyzmn's Avatar
by golly that is one beeautiful intake. mike i would have to say takes the cake. how much did all the modding cost ya? and yes a sticky or tech article would be freakin awesome. what kind of results are you seeing over the stock intake and throttle body?. sure would love to try that.
zacharyzmn is offline
post #20 of 142 (permalink) Old 10-08-2004, 04:26 PM Thread Starter
PostSkank
StupidFly's Avatar
10-4, as soon as I find my digital camera again, I'll go take some. Unless someone else has some handy they want to post.
math > pasta
post #21 of 142 (permalink) Old 10-08-2004, 05:22 PM
It is a Kenny Brown.
This is just an estimate but:
Engine: 2900.00
Cobra Intake: 490.00
Mustang Valve Covers: 20.00 on ebay
Polishing: Did it myself.
24 lb injectors: 220.00
JBA headers: 571.00
Pro-M MAF: 218.65
BBK TB: 258.00
SCT chip: 350.00
HP with stock motor and intake: 150
HP now: 196
Mike Donley
My CarDomain Pages
post #22 of 142 (permalink) Old 11-08-2004, 11:01 AM
jk69cat's Avatar
ok mines on finally. ill have pics in a day or so, i am having hood clearance issues, but i cant see where its hitting
mn12 less!
jk69cat is offline
post #23 of 142 (permalink) Old 11-08-2004, 04:38 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
Just so you know, you can unbolt the throttle plate and slide the shaft and linkage out of it to put the return spring on.
-Thomas
Thomas is offline
post #24 of 142 (permalink) Old 11-09-2004, 01:17 AM Thread Starter
PostSkank
StupidFly's Avatar
-Thomas
nearly went that route, but all I was doing was rounding out the screwdriver slots. Wasnt budging.
math > pasta
post #25 of 142 (permalink) Old 11-09-2004, 02:27 AM
Uber Luber
Thomas's Avatar
Ah yes, very common problem. Since I do that as a side job (halfshafting and porting tb's) I invested in a hand impact tool made by craftsman. You hammer it and it twists. Pretty nifty, and well worth the 30 bucks.
-Thomas
Thomas is offline
post #26 of 142 (permalink) Old 11-09-2004, 11:13 AM Thread Starter
PostSkank
StupidFly's Avatar
-Thomas
ah, good to know. BTW, I've always wondered... what the heck is halfshafting anyway?
math > pasta
post #27 of 142 (permalink) Old 11-09-2004, 12:19 PM
Uber Luber
Thomas's Avatar
And now I also incorporate counter-sunk screws on the throttle plate to open up the pinch point even more. But thats the main idea. It's literally halving the shaft.
-Thomas
Thomas is offline
post #28 of 142 (permalink) Old 11-10-2004, 02:36 PM
_________________
Taylor Spiro-Pro Wires, Jasper Performance 302 long block, polished 1994-1995 Cobra Intake,JBA Shorty Headers,Polished Aluminum Valve Covers, Chrome 75mm Granatelli Bullet MAF, 70mm BBK Throttle Body, MAC Chrome Cold Air Intake, Ford Motorsports Smog Pump Delete Pulley, Removed Air Intake Silencer, MSD Blaster coil, Edelbrock 304 Series SS mufflers, Griffin 3 row Aluminum Radiator, Lincoln Mk VIII Electric Fan, 130 Amp Alternator, Art Carr 1 piece Input Shaft, B&M 2400 Stall Non-lockup C-6 Convertor, Heavy Duty Forward Clutch, A-servo for Overdrive, Transgo Shift Kit, Transmission Oil Cooler, 2003 Cobra Aluminum Differential w/ 3.55 Gears, SCT custom chip. Best time: 15.88 @ 88.12 Best Dyno Pull: 194.45 RWHP/234.9 Max Torque
My CarDomain Pages
all this mods and you run a 15.........not trying to offend you but i was thinking of swapping my SC engine for a 5.0, but i dont think its such a good idea anymore.
1990 5-speed BHJ balancer , ASP underdrives with march WP pulley, 5%OD, optima red top, Magnaflow resonator no cats, solid motor/tranny mounts .
turbospeed is offline
post #29 of 142 (permalink) Old 11-10-2004, 03:43 PM
If you are going from a 3.8SC to a fairly simple 5.0 then it is definitely a waste of time. If you are going to go to a 5.0 base then go with a 331 or 347 stroker and build it to leave room for a supercharger and you can see unreal power. If you want to go carbed then consider a 392 or 427 (351W base) and customize it all you want.
post #30 of 142 (permalink) Old 11-10-2004, 05:10 PM
Uber Luber
Thomas's Avatar
I dont know that it's a waste of time, I believe it was xr7 dave who bought a project sc and converted it to 5.0 just for a new project.
I don't know why MIke is only running 15.88, maybe it's an old time, but a local guy ehre with 2" true dual straight pipe (done by previous owner) and cobra intakes ran a 15.8, so I'd say something is not right, or it could be the location/altitude/weather affecting it, who knows.
-Thomas
Thomas is offline
