5.0 MN12 Longtube Headers Installed (DUW) - TCCoA Forums
post #1 of 1 (permalink) Old 11-19-2005, 06:29 PM Thread Starter
MaddMartigan's Avatar
Figured I would post a link in here just in case you missed it in exhaust.
1993 Ford Thunderbird LX
Coast High Peformance 342 Stroker
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.73 gears
Custom aluminum driveshaft
Built Darrin/dirtyd0g AOD with wide ratio gearset
dirtyd0g 9.5" Custom Torque Converter
Quarterhorse ECM from Moates
Zeitronix ZT-2 WB O2
No times under new system.......yet.
OMGHI2U
MaddMartigan is offline
