Cobra IRS rear hubs - TCCoA Forums
post #1 of 2 (permalink) Old 03-21-2017, 11:10 AM Thread Starter
Cobra IRS rear hubs
Looking for a place to buy Cobra IRS rear hubs to complete a hub/bolt pattern swap. Where's the best place to buy them now?
jdhughes909 is offline
post #2 of 2 (permalink) Old 04-02-2017, 08:23 PM
MaddMartigan's Avatar
Tasca has them for $138 a piece. The part number is M-1109-A. That seems to be the cheapest I can find them. You will still need bearings though.
COBRA IRS HUB (1 EACH) : Genuine Factory OEM Parts & Accessories | TascaParts.com
1993 Ford Thunderbird LX
Coast High Peformance 342 Stroker
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.73 gears
Custom aluminum driveshaft
Built Darrin/dirtyd0g AOD with wide ratio gearset
dirtyd0g 9.5" Custom Torque Converter
Quarterhorse ECM from Moates
Zeitronix ZT-2 WB O2
No times under new system.......yet.
OMGHI2U
MaddMartigan is offline
