M112 5.0 Adapter - TCCoA Forums
post #1 of 3 (permalink) Old 01-10-2017, 09:37 AM Thread Starter
ROLLINTHUNDER's Avatar
M112 5.0 Adapter
Anyone have any experience with these and know where to buy one? I see them all over youtube and may be something I think would be fun to mess around with. It's no fun without taking a few risks right!?
Eibach pro kit springs w/rear cobra bilstiens, rear disc conversion, 2000 Cobra R wheels, 89 SC track-lock swap w/mark 8 cv shafts, 89 front and rear sway bars
ROLLINTHUNDER is offline
post #2 of 3 (permalink) Old 01-14-2017, 04:52 PM
S4gunn's Avatar
This piqued my curiosity.
Apparently, there is a now defunct website calla jdbmods.com that sold these adapter plates.
Apparently, the best way to do it is now DIY
Eaton M112 Install on 5.0 LTD (pics!) - Ford Mustang Forums : Corral.net Mustang Forum
Maybe i should have kept that m90 from one of the sc donors. It would have been a little undersized but the price would have been right.
S4gunn is offline
post #3 of 3 (permalink) Old 02-15-2017, 06:25 PM
MaddMartigan's Avatar
I wouldn't really think of that as a reasonable DIY. If you look closely at his system you'll see that he's running that setup in an 80's Fox Body LTD II and he makes no mention of tuning. Having read through a lot of the thread I saw that he had detonation on a piston that messed it up pretty bad and plenty of other challenges. When you consider all of the work he had to do to make it fit then you begin to wonder if the results were worth the reward. I'm putting out more power NA than he was with that setup. His car just weighs less.
If you wanted to do a supercharger on a 5.0 MN12 then look for something that fits the 94-95 Mustang GT and you're most of the way there.
1993 Ford Thunderbird LX
Coast High Peformance 342 Stroker
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.73 gears
Custom aluminum driveshaft
Built Darrin/dirtyd0g AOD with wide ratio gearset
dirtyd0g 9.5" Custom Torque Converter
Quarterhorse ECM from Moates
Zeitronix ZT-2 WB O2
No times under new system.......yet.
OMGHI2U
MaddMartigan is offline
