Another question about the shuddddder - TCCoA Forums
 2Likes
  • 1 Post By MadMikeyL
  • 1 Post By Trunk Monkey
post #1 of 15 (permalink) Old 07-20-2016, 04:40 AM Thread Starter
Andy625UK's Avatar
I've had my car for 11yrs. I've experienced bad shudder, had it fixed a long time ago, then in latter years very light shudder at low throttle, which was fixed (for a few months) by a flush and refill with Mercon. The light shudder came back, but I've put up with it for years now.
The car is now only used in the summer and spends quite a while sat around. My question is, when you start driving a car again after its been sat for a few weeks/months, is that likely to make it shudder, or make any shudder that it used to be prone to, worse? I was visualising the friction surfaces in there getting dried out while its sat, and then taking a while to get back to "normal" when its driven again.
Any of you guys that only use their car now and again ever experienced that?
I'm currently getting the light shudder at light throttle/low speeds, but also a bit of shudder when it goes into overdrive, and some random occurrences when cruising at about 70. It could really do with a flush and refill, but Mercon is very expensive and difficult to get hold of over here.
"...put me on a highway, show me a sign, and take it to the limit one more time"
The Eagles
1975
http://www.cardomain.com/ride/2149821
RIP Dutch T-Bird (Robert Hendriks) 1970-2012 No doubt looking down on us from his low-riding T-Bird in the sky.
Andy625UK is online now
post #2 of 15 (permalink) Old 07-20-2016, 07:12 AM
I guess when you say Mercon you mean Mercon V not III. I dont' think Mercon 3 has been made for years but just checking.
You may not be getting a full flush when it's changed a lot depends on how it's done. It may just be time to look at replacing the torque converter.
I don't think you should be getting the shudder after the car has sat for a while. Sitting should have no bearing on the shudder suddenly appearing. How long has it been since the last time the trans fluid was changed? A year or more? How many miles on the fluid?
I'm just throwing some thoughts out there. I'd be interested to hear what others have to say.
post #3 of 15 (permalink) Old 07-20-2016, 07:31 AM
T6Rocket's Avatar
How was it "fixed" a long time ago?
I would do a full fluid replacement as defined in the tech articles. If you don't replace a full 12 qts, it's not a full flush.
That is not something you want to just "put up with for years." At that rate you will need to replace the converter.
Al
97 T-Bird LX 4.6 - 68k miles
Previous cars:
T6Rocket is offline
post #4 of 15 (permalink) Old 07-20-2016, 08:10 AM Thread Starter
Andy625UK's Avatar
The initial shudder problem (in 2005 just after I bought the car) was fixed by the used car place I bought it from. He told me he'd taken if to a transmission specialist who'd changed a solenoid in the gearbox somewhere. Anyway, it fixed the problem.
Last time the fluid was changed was 2010 - about 20k miles ago (which I know is too long). I bought some Mercon V and insisted that that was used (they wanted for use Dextron with additive, "because that's what we always do"). I also made sure they knew about the nut on the TC, and drained that out too.
Mercon isn't used in any other European cars, so it's difficult to get hold of and very expensive, which is one of the reasons I haven't had it changed since. That, and the fact that the car is hardly used most of the time.
The Eagles
1975
post #5 of 15 (permalink) Old 07-20-2016, 09:54 AM
The flush and refill to fix a shudder problem is really just a Band-Aid. The problem is there isn't enough friction material on the older style torque converter clutches, and it wears out, causing the shudder. The permanent fix would be to replace the torque converter with a newer one, and while you are at it, might as well get a higher stall.
CDsDontBurn likes this.
post #6 of 15 (permalink) Old 07-20-2016, 12:47 PM
T6Rocket's Avatar
The guy I bought my latest MN12 from said he had shudder at only 40k miles. Clutches wore that quick? It now has 65k, and it seems fine (knocks on wood).
Is a MKVIII converter immune from this issue? The reason I am asking is a lot of people seem to throw used ones in their MN12's.
Al
Previous cars:
T6Rocket is offline
post #7 of 15 (permalink) Old 07-20-2016, 01:40 PM Thread Starter
Andy625UK's Avatar
When I got mine, it was 11 yrs old, 46k miles, and was shuddering nicely. Now at 135k.
The transmission specialists over here were trying to get me to let them rebuild the whole transmission last time I had the fluid changed in 2010, as initally when they filled it back up with fluid, it shuddered even worse than when I dropped it off. Within about 50 miles though, it had completely stopped.
Rather than a complete rebuild, it sounds like all I need (in an ideal world) is a replacement TC.
The Eagles
1975
post #8 of 15 (permalink) Old 07-20-2016, 04:13 PM
Yes, replace the TC, fill with Mercon V and you could look at upgrading the valve body and doing the J-mod if that hasn't already been done. It will be better than new.
post #9 of 15 (permalink) Old 07-21-2016, 04:53 PM
I know that the Mercury Marauder TC was the one to swap, but it takes a dual pattern or Mark VIII flexplate.
I'm not sure, but we should be able to use the newer mustang converters; anyone know which years?
post #10 of 15 (permalink) Old 07-22-2016, 07:18 AM
T6Rocket's Avatar
I would start with a proper fluid change with the proper fluid. It does wonders.
My old 95 had 220k miles on the original converter. I only had shudder once, at around 200k, and a full fluid change fixed it.
Al
Previous cars:
T6Rocket is offline
post #11 of 15 (permalink) Old 07-25-2016, 12:27 AM
Urambo Tauro's Avatar
I once had a shudder that was caused by an engine misfire. Tightening the loose spark plugs fixed it. I don't know if that's what's causing yours, but it might be worth checking...
1996 Thunderbird LX (4.6), daily driver
1995 Mustang GT (5.0), alternate daily driver
Urambo Tauro is offline
post #12 of 15 (permalink) Old 07-25-2016, 07:06 AM Thread Starter
Andy625UK's Avatar
I did think it was a misfire when it first happened (especially at the low engine speeds), but since then everything's been replaced at least once (plugs/leads/coil packs), so I know it's not that.
The Eagles
1975
post #13 of 15 (permalink) Old 07-25-2016, 07:25 AM
T6Rocket's Avatar
They only "shudder" when the converter locks up. The converter only locks up in third and OD, though I personally have only noticed the shudder when it shifts into OD, around 40 MPH.
So if you're getting a shudder at low speeds, I doubt it is the converter.
Al
Previous cars:
T6Rocket is offline
post #14 of 15 (permalink) Old 07-25-2016, 07:35 AM Thread Starter
Andy625UK's Avatar
By "low" speeds I mean about 30-35 in 3rd (on a very light throttle) when following a slow car, or in a queue, and then when it goes into lockup. If it accelerate a slightly harder, it immediately stops.
Last time I had the fluid changed and refilled with Mercon it all stopped, then after about 6mths the low speed shudder started again.
The Eagles
1975
post #15 of 15 (permalink) Old 07-25-2016, 07:42 AM
T6Rocket's Avatar
It shouldn't come back in 6 months. They didn't do a full fluid change.
Al
Previous cars:
T6Rocket is offline
