Okay, I'm new to working on automatic transmissions. I am in the midst of changing out the EPC solenoid. When I dumped the pan and removed it, this small plastic plug with an o-ring and a small shaft on one end was laying in the drain pan. What is this for and where does it go? I ran out of daylight and will be continuing working on it tomorrow, so if someone has an answer before then that would be awesome!
They're the ear plugs they used in the factories. Transmission assembly was the loudest part so its really common for them to have fallen out and dropped in the pan. It's actually just a plug they used for the trans before installation. It doesn't have to go back in anywhere, just lose it.
Okay, thanks . The trans was supposedly rebuilt/shift kit installed before I got the car, and everything inside looks pretty clean and fresh, but I just found that in the drain pan and couldn't see a place for it to go.
Thanks, I tossed it in the toolbox for a rainy day.
Related Threads
TCCoA Forums
1.5M posts
26.8K members
Since 2002
