c-6 problem - TCCoA Forums
post #1 of 6 (permalink) Old 02-28-2010, 09:36 AM Thread Starter
1995 cougar xr7's Avatar
c-6 problem
i have a c-6 in my van, i need to get the fluid warmed up before Drive will work.
i have to idle in D for awhile then it will grab. any ideas?
1995 cougar xr7 is offline
post #2 of 6 (permalink) Old 04-12-2010, 04:20 PM
when was the last time the fluid was changed?
post #3 of 6 (permalink) Old 04-16-2010, 07:19 PM Thread Starter
not that long ago there wasn't a magnet in the pan
post #4 of 6 (permalink) Old 07-27-2011, 01:12 PM
Send a message via Yahoo to Goldthunder
Kinda An Old Thread.....
But what happened?? I have a similar issue with the C6 in my F350. For a couple of days it wouldn't go into any forward gear and yesterday I was fiddling with it and it was going into gear. But I did notice that if I shifted it from Park to 1st gear it would go into gear. After it was warmed up all the way there didn't seem to be any problem. I'm wondering if a fluid change would help the problem. Really don't want to drop the trans....I got the truck really cheap. Once its in gear and driving there's no problems with drivability. Shifts nice and firm.
Goldthunder is offline
post #5 of 6 (permalink) Old 07-27-2011, 08:50 PM
The "no or slow engagement" into gear is often referred to as "morning sickness" in the transmission world. This is caused by hard or broken rubber sealing rings on the clutch apply pistons. Heat and age are the root cause.
The only fix is to rebuild the transmission with all new internal seals (yes, I have known people who don't replace those seal rings).
You can probably baby the transmission along for a while (I babied mine for two years until I got time to rebuild it) as you save for or plan the time to rebuild. If you have a daily driver the I would recommend getting a core and rebuild it and then spend a day swapping the transmissions.
After you get it rebuilt be sure to install a cooler in front of the radiator to lengthen the life of your new transmission.
PaulS1950 is offline
post #6 of 6 (permalink) Old 07-27-2011, 11:00 PM
For confirming that for me. Second time I've heard that seals can cause the problem. Sounds like a trans rebuild is in my future.
